<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-WOTD]]></title><description><![CDATA[<p dir="auto">Word of the day Module for your mirror!</p>
<p dir="auto"><img src="/assets/uploads/files/1615600082062-1.png" alt="1.png" class="img-markdown  img-fluid" /></p>
<p dir="auto">See README for instructions</p>
<h1>Download:</h1>
<p dir="auto"><a href="https://github.com/cowboysdude/WWW-WOTD" target="_blank" rel="noopener noreferrer nofollow ugc">Download Here</a></p>
<h2>Version 1.0.0</h2>
]]></description><link>https://forum.magicmirror.builders/topic/14773/mmm-wotd</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 01:55:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14773.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Mar 2021 01:52:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-WOTD on Wed, 16 Nov 2022 01:43:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sam-thanks. It does load now. I’ll have to go back and [re-]learn some css to get it to fit in with the other modules, as it is way too tall, but this is progress. Thanks again</p>
]]></description><link>https://forum.magicmirror.builders/post/105829</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105829</guid><dc:creator><![CDATA[JohnGalt]]></dc:creator><pubDate>Wed, 16 Nov 2022 01:43:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WOTD on Wed, 16 Nov 2022 01:37:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johngalt" aria-label="Profile: JohnGalt">@<bdi>JohnGalt</bdi></a> the repo name is right …</p>
<p dir="auto">maybe the git repo inside is wrong</p>
<p dir="auto">do this</p>
<p dir="auto">git clone <a href="https://github.com/cowboysdude/MMM-WOTD" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/MMM-WOTD</a> MMM-WOTD</p>
]]></description><link>https://forum.magicmirror.builders/post/105828</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105828</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 16 Nov 2022 01:37:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WOTD on Wed, 16 Nov 2022 01:14:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Did you intend to call this module “WWW-WOTD” instead of the standard “MMM-…” ??</p>
<p dir="auto">I downloaded it, it installed itself as “WWW-WOTD” and it does not run. I did not delve into the code, but suspect the non-standard name may be spread through the code.</p>
<p dir="auto">Any thoughts?</p>
]]></description><link>https://forum.magicmirror.builders/post/105827</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105827</guid><dc:creator><![CDATA[JohnGalt]]></dc:creator><pubDate>Wed, 16 Nov 2022 01:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WOTD on Fri, 10 Sep 2021 11:29:31 GMT]]></title><description><![CDATA[<p dir="auto">V2 is out!</p>
<p dir="auto">Changes have been done to conform with the non use of request :)<br />
It uses Axios now.</p>
<p dir="auto">All updates files including new package.json file are there.</p>
<p dir="auto"><a href="https://github.com/cowboysdude/WWW-WOTD" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/WWW-WOTD</a></p>
<p dir="auto"><img src="/assets/uploads/files/1631273344971-wotd.png" alt="WOTD.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/post/94343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94343</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 10 Sep 2021 11:29:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WOTD on Sat, 03 Apr 2021 14:35:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> : you have set an error when you have created the repository …<br />
why WWW-WOTD ?<br />
in your module, you have Set MMM-WOTD</p>
<p dir="auto">So that why <a class="plugin-mentions-user plugin-mentions-a" href="/user/lxne" aria-label="Profile: lxne">@<bdi>lxne</bdi></a> have an issue (nodule not found)</p>
<p dir="auto">And an error on the <code>getDom</code> function</p>
<pre><code class="language-js">    getDom: function() {
      if(this.loaded == true){
        var wotd = this.wotd[0];
        var wordTable = document.createElement('div');
        if (this.config.style == 'narrow') {
            wordTable.classList.add('narrow');
        } else {
            wordTable.classList.add('wide');
        var wordTR = document.createElement('tr');
        var word = document.createElement('td');
        word.classList.add('bright', 'small');
        word.setAttribute('style', 'background:' + this.config.wbackground);
        word.innerHTML = "Word  ";
        wordTR.appendChild(word);
        var word2 = document.createElement('td');
        word2.classList.add('small');
        word2.setAttribute("style", "color:" + this.config.word + "; background-color: " + this.config.dbackground + ";");
        word2.innerHTML = wotd.word;
        wordTR.appendChild(word2);
        wordTable.appendChild(wordTR);
        var wordTR2 = document.createElement('tr');
        var wordd = document.createElement('td');
        wordd.classList.add('bright', 'small');
        wordd.setAttribute('style', 'background:' + this.config.wbackground);
        wordd.innerHTML = "Meaning  ";
        wordTR2.appendChild(wordd);
        var wordd2 = document.createElement('td');
        wordd2.classList.add('small');
        wordd2.setAttribute('style', 'color:' + this.config.definition + '; background-color: ' + this.config.dbackground + ';');
        wordd2.innerHTML = wotd.definition;
        wordTR2.appendChild(wordd2);
        wordTable.appendChild(wordTR2);
        var wordTR3 = document.createElement('tr');
        var wordf = document.createElement('td');
        wordf.classList.add('bright', 'small');
        wordf.setAttribute('style', 'background:' + this.config.wbackground);
        wordf.innerHTML = "Say  ";
        wordTR3.appendChild(wordf);
        var wordf2 = document.createElement('td');
        wordf2.setAttribute('style', 'color:' + this.config.say + '; background-color: ' + this.config.dbackground + ';');
        wordf2.classList.add('small');
        wordf2.innerHTML = wotd.pronunciation;
        wordTR3.appendChild(wordf2);
        wordTable.appendChild(wordTR3);
        wrapper.appendChild(wordTable);
      return wrapper;
<ul>
<li>wow … tr/td tag like win95 ???, i think, you can do better !</li>
<li>I have corrected your error… you have not created the Dom on first request</li>
<li>package.json missing ! (if an user do npm install … it will install MagicMirror !)</li>
</ul>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lxne" aria-label="Profile: lxne">@<bdi>lxne</bdi></a>: for a temp resolve, just rename WWW-WOTD in modules directory  to MMM-WOTD</p>
]]></description><link>https://forum.magicmirror.builders/post/90264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90264</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Sat, 03 Apr 2021 14:35:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WOTD on Fri, 02 Apr 2021 19:41:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I have updated my MagicMirror to 2.15.0 and then installed MMM-WOTD but I do not get any output. My MM runs with quite a view modules but MMM-WOTD won’t show up.</p>
<p dir="auto">According to my telegram-bot these modules are installed (MMM-WOTD is not among those):</p>
<p dir="auto">alert<br />
MMM-pages<br />
MMM-UpdateNotification<br />
MMM-TelegramBot<br />
MMM-Volume<br />
MMM-Tools<br />
MMM-GoogleAssistant<br />
MMM-Assistant2Display<br />
clock<br />
MMM-DWD-WarnWeather<br />
calendar<br />
MMM-MplayerRadio<br />
MMM-MusicOnDemand<br />
MMM-Weather<br />
MMM-DarkSkyForecast<br />
newsfeed<br />
MMM-NewsFeed<br />
MMM-GroveGestures</p>
<p dir="auto">In the log I can only find one line regarding MMM-WOTD and it says: [02.04.2021 21:28.53.261] [LOG]   No helper found for module: MMM-WOTD.</p>
<p dir="auto">Any idea what might be the problem?</p>
<p dir="auto">Best wishes.</p>
]]></description><link>https://forum.magicmirror.builders/post/90240</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90240</guid><dc:creator><![CDATA[lxne]]></dc:creator><pubDate>Fri, 02 Apr 2021 19:41:04 GMT</pubDate></item></channel></rss>
