<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Display Control Board]]></title><description><![CDATA[<p dir="auto">I pulled a display off a MS surface.</p>
<p dir="auto">Display PN: VVX11F037N00</p>
<p dir="auto">Resolution:  1920x1280<br />
Voltage:  3.3<br />
Signal:  MIPI (4 data lanes) , 40 pins Connector<br />
Panel Type:  a-Si TFT-LCD , LCM</p>
<p dir="auto"><a href="https://www.panelook.com/VVX11F037N00_Panasonic_11_LCM_overview_25444.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.panelook.com/VVX11F037N00_Panasonic_11_LCM_overview_25444.html</a></p>
<p dir="auto">I’ve done some googling without any clear answer.</p>
<p dir="auto">What display controller board do I need?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14789/display-control-board</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 05:47:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14789.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Mar 2021 16:44:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Display Control Board on Tue, 23 Mar 2021 06:18:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi…Some more up to date Samsung LED-LCDs and LCDs with 240Hz processor have separate tests for FRC (movement upconverter/T-con) and principle board from administration menu, yet no entrance if TV will not catalyst and menus aren’t usable.</p>
]]></description><link>https://forum.magicmirror.builders/post/89789</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89789</guid><dc:creator><![CDATA[AveDalang]]></dc:creator><pubDate>Tue, 23 Mar 2021 06:18:13 GMT</pubDate></item><item><title><![CDATA[Reply to Display Control Board on Wed, 17 Mar 2021 12:43:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: madscientist">@<bdi>madscientist</bdi></a></p>
<p dir="auto">Here is an image of the back of the display.</p>
<p dir="auto">The ribbon cable is 35pin.</p>
<p dir="auto"><img src="/assets/uploads/files/1615985028710-image.jpeg" alt="Image.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/89585</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89585</guid><dc:creator><![CDATA[muggerrudd]]></dc:creator><pubDate>Wed, 17 Mar 2021 12:43:59 GMT</pubDate></item><item><title><![CDATA[Reply to Display Control Board on Wed, 17 Mar 2021 07:03:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/muggerrudd" aria-label="Profile: muggerrudd">@<bdi>muggerrudd</bdi></a><br />
Hmm, I have no experience with those displays. All I can see from your link is that it has a MIPI interface, instead of LVDS for regular LCD panels.<br />
I did some 3 minutes google research and found mainly LCD+MIPI controller sets. On AliExpress I found single MIPI controllers but I don’t know what to look for when buying those.</p>
<p dir="auto">Please let us know if you find out more. I think that could be interesting for others (and me).</p>
]]></description><link>https://forum.magicmirror.builders/post/89576</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89576</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Wed, 17 Mar 2021 07:03:33 GMT</pubDate></item><item><title><![CDATA[Reply to Display Control Board on Tue, 16 Mar 2021 19:39:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/muggerrudd" aria-label="Profile: muggerrudd">@<bdi>muggerrudd</bdi></a></p>
<p dir="auto">The cable coming from the assembly is a 35pin. Im assuming this is proprietary since the display has the screen and touch panel combined to a pcb.</p>
]]></description><link>https://forum.magicmirror.builders/post/89554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89554</guid><dc:creator><![CDATA[muggerrudd]]></dc:creator><pubDate>Tue, 16 Mar 2021 19:39:09 GMT</pubDate></item></channel></rss>
