<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-XPlanet]]></title><description><![CDATA[<p dir="auto">Bonjour à tous,<br />
J’ai essayé d’installer le module MMM-Xplanet qui je trouve est assez sympa (<a href="https://github.com/Eldeiss/MMM-Xplanet" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Eldeiss/MMM-Xplanet</a>)<br />
Je rencontre hélas ces erreurs :<br />
E: Impossible d’ouvrir le fichier verrou /var/lib/dpkg/lock-frontend - open (13: Permission non accordée)<br />
E: Impossible d’obtenir le verrou de dpkg (/var/lib/dpkg/lock-frontend). Avez-vous les droits du superutilisateur ?<br />
Avez-vous une idée?<br />
Merci d’avance ;)</p>
]]></description><link>https://forum.magicmirror.builders/topic/14791/mmm-xplanet</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 23:02:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14791.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Mar 2021 17:21:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-XPlanet on Thu, 18 Mar 2021 19:09:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mahateo" aria-label="Profile: mahateo">@<bdi>mahateo</bdi></a> Super! Merci beaucoup 😉!!!<br />
![0_1616094523995_IMG_20210318_200051.jpg](Envoi en cours 100%)</p>
]]></description><link>https://forum.magicmirror.builders/post/89650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89650</guid><dc:creator><![CDATA[RocoJo]]></dc:creator><pubDate>Thu, 18 Mar 2021 19:09:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-XPlanet on Wed, 17 Mar 2021 16:46:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rocojo" aria-label="Profile: rocojo">@<bdi>rocojo</bdi></a> salut je vien de tester de mettre le module. il fonctionne pour ton erreur tu mets " sudo apt-get install xplanet " .<br />
Une fois fais tu va dans ton fichier module. donc cd MagicMirroir/modules/MMM-Xplanet et la je tape la commande "  chmod -R +rw img/ ".</p>
<p dir="auto">puis le reste des commandes. en esperant avoir pu taider.</p>
]]></description><link>https://forum.magicmirror.builders/post/89596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89596</guid><dc:creator><![CDATA[Mahateo]]></dc:creator><pubDate>Wed, 17 Mar 2021 16:46:00 GMT</pubDate></item></channel></rss>
