<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM in docker container]]></title><description><![CDATA[<p dir="auto">Is it possible to install MM in a docker container? If it is possible, where could I study a guide?<br />
Thank you very much</p>
]]></description><link>https://forum.magicmirror.builders/topic/14793/mm-in-docker-container</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 15:33:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14793.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Mar 2021 09:17:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM in docker container on Sun, 21 Mar 2021 19:09:14 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very very much</p>
]]></description><link>https://forum.magicmirror.builders/post/89748</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89748</guid><dc:creator><![CDATA[blackeaglece]]></dc:creator><pubDate>Sun, 21 Mar 2021 19:09:14 GMT</pubDate></item><item><title><![CDATA[Reply to MM in docker container on Wed, 17 Mar 2021 11:33:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackeaglece" aria-label="Profile: blackeaglece">@<bdi>blackeaglece</bdi></a> see<br />
<a href="https://hub.docker.com/r/karsten13/magicmirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://hub.docker.com/r/karsten13/magicmirror/</a><br />
and<br />
<a href="https://github.com/guysoft/MagicMirrorOS" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/guysoft/MagicMirrorOS</a></p>
]]></description><link>https://forum.magicmirror.builders/post/89583</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89583</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Mar 2021 11:33:47 GMT</pubDate></item><item><title><![CDATA[Reply to MM in docker container on Wed, 17 Mar 2021 10:46:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackeaglece" aria-label="Profile: blackeaglece">@<bdi>blackeaglece</bdi></a> You want to install MM in your own docker container ? or want to use MM as docker container ? there are already many MM docker container in docker registry. search this forum with docker and you will get help.</p>
]]></description><link>https://forum.magicmirror.builders/post/89581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89581</guid><dc:creator><![CDATA[ashishtank]]></dc:creator><pubDate>Wed, 17 Mar 2021 10:46:40 GMT</pubDate></item></channel></rss>
