<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mirror size]]></title><description><![CDATA[<p dir="auto">So. Getting ready to order the mirror for my build and I wanted to check the size before I do. Do I need the mirror to sit completely flush against the screen or can it over lap a bit sitting on that metal edge around the screen?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14798/mirror-size</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 12:43:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14798.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Mar 2021 15:59:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mirror size on Wed, 07 Jul 2021 07:57:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stalker401" aria-label="Profile: stalker401">@<bdi>stalker401</bdi></a> Flush would be perfect but you can go bigger. You would probably notice a slight border effect. My mirror is considerably bigger than the screen and you can really notice the screen through the mirror. Upgrade due…</p>
]]></description><link>https://forum.magicmirror.builders/post/92608</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92608</guid><dc:creator><![CDATA[matt216]]></dc:creator><pubDate>Wed, 07 Jul 2021 07:57:27 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror size on Wed, 07 Jul 2021 05:38:53 GMT]]></title><description><![CDATA[<p dir="auto">As a general rule, a vanity mirror should measure several inches fewer than your vanity sink area. For example a 30 in.  <a href="https://www.imessageapp.one/" target="_blank" rel="noopener noreferrer nofollow ugc">iMessage App</a> wide vanity should be paired with a 26-28 in. wide mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/92600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92600</guid><dc:creator><![CDATA[walternataly]]></dc:creator><pubDate>Wed, 07 Jul 2021 05:38:53 GMT</pubDate></item></channel></rss>
