<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Message: no signal]]></title><description><![CDATA[<p dir="auto">Hi,<br />
for my new magic mirror I have a SyncMaster TA550 monitor / tv. The problem is that after the PIR sensor stops the signal on the screen I have the message: without signal, check the connection …<br />
Can anyone help me how I can disable this message?<br />
Thanks,</p>
]]></description><link>https://forum.magicmirror.builders/topic/14812/message-no-signal</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 15:01:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14812.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Mar 2021 19:52:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Message: no signal on Wed, 24 Mar 2021 20:56:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/george" aria-label="Profile: george">@<bdi>george</bdi></a> i just replied to someone else on discord</p>
<p dir="auto">there are different commands to turn on/off  display devices… and they work in different places<br />
tvservice is a pi only command<br />
<a href="https://www.raspberrypi.org/documentation/raspbian/applications/tvservice.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/raspbian/applications/tvservice.md</a><br />
vcgencmd is one to control the hdmi port (turn off, and display MAY show ‘no input’)<br />
<a href="https://www.raspberrypi.org/documentation/raspbian/applications/vcgencmd.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/raspbian/applications/vcgencmd.md</a><br />
and cec-utils (cec-client) can control the tv on the end of the hdmi cable (for cec compliant devices)<br />
<a href="https://pimylifeup.com/raspberrypi-hdmi-cec/" target="_blank" rel="noopener noreferrer nofollow ugc">https://pimylifeup.com/raspberrypi-hdmi-cec/</a></p>
<p dir="auto">tv service works on pi4 to turn off hdmi port, but not back on.<br />
vcgencmd worked on pi 4, but montior displayed no input, cec-utils worked  turned off/on monitor</p>
<p dir="auto">[11:45 AM]<br />
the PIR module has to use the right commands… I thought NEWPir supported cec-client…  but haven’t tried it…</p>
<p dir="auto">sam — Today at 11:58 AM<br />
New-PIR  does support the CEC commands, and vcgencmd and tvservice…<br />
using mode in the module config screen section   screen: {    }  I think<br />
5 modes are available:</p>
<ul>
<li>mode: 1 - use vgencmd (RPI only)</li>
<li>mode: 2 - use dpms (version RPI)</li>
<li>mode: 3 - use tvservice (RPI only)</li>
<li>mode: 4 - use HDMI CEC</li>
<li>mode: 5 - use dpms (linux version for debian, ubuntu, …)</li>
</ul>
<p dir="auto">my advice to the other user was to logon to the pi via ssh and try the commands as documented in the links  to figure out which on works and then use the mode in the NEW-Pir module config</p>
]]></description><link>https://forum.magicmirror.builders/post/89839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89839</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 24 Mar 2021 20:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to Message: no signal on Wed, 24 Mar 2021 20:18:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> , thanks, but i have no idea how to do it.  Any tips?</p>
]]></description><link>https://forum.magicmirror.builders/post/89837</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89837</guid><dc:creator><![CDATA[George]]></dc:creator><pubDate>Wed, 24 Mar 2021 20:18:27 GMT</pubDate></item><item><title><![CDATA[Reply to Message: no signal on Wed, 24 Mar 2021 14:23:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/george" aria-label="Profile: george">@<bdi>george</bdi></a> NONONO :-) . first try out a bit more.<br />
I think MMM-NewPIR has integrated several possibilities of turning off the monitor or hdmi.<br />
Play with these, you might be successful.<br />
I think my monitor (also a syncmaster) can behave both ways however you swithc it off.</p>
]]></description><link>https://forum.magicmirror.builders/post/89822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89822</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 24 Mar 2021 14:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to Message: no signal on Sun, 21 Mar 2021 09:12:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> , thanks. I will buy another monitor :(</p>
]]></description><link>https://forum.magicmirror.builders/post/89717</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89717</guid><dc:creator><![CDATA[George]]></dc:creator><pubDate>Sun, 21 Mar 2021 09:12:00 GMT</pubDate></item><item><title><![CDATA[Reply to Message: no signal on Sat, 20 Mar 2021 20:07:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/george" aria-label="Profile: george">@<bdi>george</bdi></a> u cannot disable the message, it is part of the tv firmware.</p>
<p dir="auto">this is why you need to use different commands to turn off the TV and NOT the HDMI port.</p>
<p dir="auto">none of my TVs support this capability, so I hide all the modules instead</p>
]]></description><link>https://forum.magicmirror.builders/post/89707</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89707</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 20 Mar 2021 20:07:20 GMT</pubDate></item></channel></rss>
