<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt2 Site can't be reached]]></title><description><![CDATA[<p dir="auto">hello, I can’t display my calendar, it works with the basic calendar but not with MMM-CalendarExt2, I used the code example, but magic mirror shows me “This site can’t be reached”, I have the same with MMM-CalendarExt.<br />
For information, I work with a raspberry pi zero W.<br />
Could someone help me please ?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14820/mmm-calendarext2-site-can-t-be-reached</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 14:01:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14820.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Mar 2021 12:39:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt2 Site can't be reached on Wed, 06 Oct 2021 00:44:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robwaddell" aria-label="Profile: robwaddell">@<bdi>robwaddell</bdi></a> localhost means on this machine…</p>
<p dir="auto">none of your urls should point to localhost</p>
<p dir="auto">can u show us the calendars definition from this module…   u can change some of the characters in the mangled name,   try not to leave out any lines…</p>
]]></description><link>https://forum.magicmirror.builders/post/95305</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95305</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 06 Oct 2021 00:44:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 Site can't be reached on Wed, 06 Oct 2021 00:41:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marc-rosay" aria-label="Profile: marc-rosay">@<bdi>marc-rosay</bdi></a> I can not get this to work.  I’ve tried the npm install valid-url<br />
and I still get a white screen that says local host refused to connect</p>
]]></description><link>https://forum.magicmirror.builders/post/95304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95304</guid><dc:creator><![CDATA[robwaddell]]></dc:creator><pubDate>Wed, 06 Oct 2021 00:41:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 Site can't be reached on Mon, 22 Mar 2021 17:59:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I found the solution,<br />
thank you !<br />
i had to install valid-url :</p>
<pre><code>npm install valid-url
]]></description><link>https://forum.magicmirror.builders/post/89786</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89786</guid><dc:creator><![CDATA[Marc Rosay]]></dc:creator><pubDate>Mon, 22 Mar 2021 17:59:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 Site can't be reached on Mon, 22 Mar 2021 17:39:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> here is the errors it gives, but i’m not sure to understand…</p>
<pre><code>0|mmstart  | [22.03.2021 18:32.13.033] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'valid-url'
0|mmstart  | [22.03.2021 18:32.13.084] [ERROR] Whoops! There was an uncaught exception...
0|mmstart  | [22.03.2021 18:32.13.139] [ERROR] { Error: Cannot find module 'valid-url'
0|mmstart  |     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
0|mmstart  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
0|mmstart  |     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
0|mmstart  |     at Module.require (internal/modules/cjs/loader.js:690:17)
0|mmstart  |     at require (internal/modules/cjs/helpers.js:25:18)
0|mmstart  |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js:3:18)
0|mmstart  |     at Module._compile (internal/modules/cjs/loader.js:776:30)
0|mmstart  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
0|mmstart  |     at Module.load (internal/modules/cjs/loader.js:653:32)
0|mmstart  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12) code: 'MODULE_NOT_FOUND' }
0|mmstart  | [22.03.2021 18:32.13.149] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|mmstart  | [22.03.2021 18:32.13.159] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|mmstart  |
0|mmstart  |
0|mmstart  | X.Org X Server 1.20.4
0|mmstart  | X Protocol Version 11, Revision 0
0|mmstart  | Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
0|mmstart  | Current Operating System: Linux raspberrypi 4.19.97+ #1294 Thu Jan 30 13:10:54 GMT 2020 armv6l
0|mmstart  | Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1600 bcm2708_fb.fbheight=900 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:EA:17:C7 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
0|mmstart  | Build Date: 05 June 2019  12:49:54PM
0|mmstart  | xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
0|mmstart  | Current version of pixman: 0.36.0
0|mmstart  |    Before reporting problems, check http://wiki.x.org
0|mmstart  |    to make sure that you have the latest version.
0|mmstart  | Markers: (--) probed, (**) from config file, (==) default setting,
0|mmstart  |    (++) from command line, (!!) notice, (II) informational,
0|mmstart  |    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
0|mmstart  | (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar 22 18:32:36 2021
0|mmstart  | (==) Using system config directory "/usr/share/X11/xorg.conf.d"
0|mmstart  | [589:589:0322/183259.671712:ERROR:gl_implementation.cc(282)] Failed to load libGLESv2.so.2: libGLESv2.so.2: cannot open shared object file: No such file or directory
0|mmstart  | [589:589:0322/183259.829795:ERROR:viz_main_impl.cc(176)] Exiting GPU process due to errors during initialization
0|mmstart  | [547:893:0322/183307.059505:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
0|mmstart  | [547:893:0322/183307.082801:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
0|mmstart  | [547:893:0322/183307.111738:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
0|mmstart  | Fontconfig error: Cannot load default config file
]]></description><link>https://forum.magicmirror.builders/post/89785</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89785</guid><dc:creator><![CDATA[Marc Rosay]]></dc:creator><pubDate>Mon, 22 Mar 2021 17:39:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 Site can't be reached on Mon, 22 Mar 2021 17:00:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marc-rosay" aria-label="Profile: marc-rosay">@<bdi>marc-rosay</bdi></a> is there any message in the window where u start MM?  npm start or pm2 start??</p>
<p dir="auto">if pm2, then use the pm2 logs --lines=?? ?? is a number, default 15</p>
]]></description><link>https://forum.magicmirror.builders/post/89784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89784</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 22 Mar 2021 17:00:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 Site can't be reached on Mon, 22 Mar 2021 16:45:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank you for the help !<br />
it doesn’t work with this :<br />
<a href="https://www.google.com/calendar/ical/ovb564thnod82u5c4njut98728%40group.calendar.google.com/public/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.google.com/calendar/ical/ovb564thnod82u5c4njut98728%40group.calendar.google.com/public/basic.ics</a><br />
this is the url in the example</p>
]]></description><link>https://forum.magicmirror.builders/post/89783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89783</guid><dc:creator><![CDATA[Marc Rosay]]></dc:creator><pubDate>Mon, 22 Mar 2021 16:45:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 Site can't be reached on Mon, 22 Mar 2021 12:59:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marc-rosay" aria-label="Profile: marc-rosay">@<bdi>marc-rosay</bdi></a>  can u show us the url you use?</p>
<p dir="auto">change some characters near the end so it doesn’t work</p>
]]></description><link>https://forum.magicmirror.builders/post/89770</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89770</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 22 Mar 2021 12:59:11 GMT</pubDate></item></channel></rss>
