<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[problems with hot word]]></title><description><![CDATA[<p dir="auto">[2021-03-26 09:53:46.150] [LOG]    [HOTWORD] begins.<br />
[2021-03-26 09:53:46.524] [LOG]    [HOTWORD] Detector starts listening.<br />
[2021-03-26 09:53:49.333] [LOG]    [HOTWORD:LPCM16] arecord: main:828: audio open error: No such file or folder<br />
[2021-03-26 09:53:49.838] [LOG]    [HOTWORD] Final Result: { detected: false }</p>
<p dir="auto">I can’t find this module on GitHub and reinstall it correctly</p>
]]></description><link>https://forum.magicmirror.builders/topic/14836/problems-with-hot-word</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 03:55:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14836.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Mar 2021 07:05:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to problems with hot word on Fri, 26 Mar 2021 13:05:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karalica-kir" aria-label="Profile: Karalica-Kir">@<bdi>Karalica-Kir</bdi></a> : I have deprecied this module, last year. I code another very more simple</p>
<p dir="auto">Now, I think you use a very old source (When i close MMM-Hotword it’s the v2.4.0… and you use v1)</p>
<p dir="auto">Good luck for using it ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/89935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89935</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Fri, 26 Mar 2021 13:05:44 GMT</pubDate></item><item><title><![CDATA[Reply to problems with hot word on Fri, 26 Mar 2021 11:47:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karalica-kir" aria-label="Profile: karalica-kir">@<bdi>karalica-kir</bdi></a> missing man</p>
<p dir="auto">npm install man<br />
then retry to install smowboy</p>
]]></description><link>https://forum.magicmirror.builders/post/89929</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89929</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 26 Mar 2021 11:47:02 GMT</pubDate></item><item><title><![CDATA[Reply to problems with hot word on Fri, 26 Mar 2021 10:36:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karalica-kir" aria-label="Profile: karalica-kir">@<bdi>karalica-kir</bdi></a><br />
Some dependencies of this module are outdated.</p>
<p dir="auto">Snowball did not install. There is an instruction in the README on github. Have you had a look at that?</p>
<p dir="auto">When you fail to install snowboy itself.</p>
<pre><code>cd ~/MagicMirror/modules/MMM-Hotword
npm install --save snowboy   # Sometimes it could fail, retry again.
<p dir="auto">If you doubt errors are caused by different node.JS version, you can try to &gt;compile it by yourself.</p>
<pre><code>cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
<p dir="auto">If there is no special errors(except some warnings), you can use it. test it with &gt;serveronly mode.</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/post/89926</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89926</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 26 Mar 2021 10:36:57 GMT</pubDate></item><item><title><![CDATA[Reply to problems with hot word on Fri, 26 Mar 2021 08:53:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bravooscar" aria-label="Profile: bravooscar">@<bdi>bravooscar</bdi></a> i can’t understand what’s wrong</p>
<pre><code>pi@Pi:~/MagicMirror/modules $ cd MMM-Hotword
pi@Pi:~/MagicMirror/modules/MMM-Hotword $ npm install
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated hawk@3.1.3: This module moved to @hapi/hawk. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated hoek@2.16.3: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated cryptiles@2.0.5: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
npm WARN deprecated sntp@1.0.9: This module moved to @hapi/sntp. Please make sure to switch over as this distribution is no longer supported and may contain bugs and critical security issues.
npm WARN deprecated boom@2.10.1: This version has been deprecated in accordance with the hapi support policy (hapi.im/support). Please upgrade to the latest version to get the best features, bug fixes, and security patches. If you are unable to upgrade at this time, paid support is available for older versions (hapi.im/commercial).
&gt; snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
&gt; node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.24.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
internal/modules/cjs/loader.js:638
    throw err;
Error: Cannot find module 'nan'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    at Module.require (internal/modules/cjs/loader.js:692:17)
    at require (internal/modules/cjs/helpers.js:25:18)
    at [eval]:1:1
    at Script.runInThisContext (vm.js:122:20)
    at Object.runInThisContext (vm.js:329:38)
    at Object.&lt;anonymous&gt; ([eval]-wrapper:6:22)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
    at evalScript (internal/bootstrap/node.js:590:27)
    throw err;
    at [eval]:1:1
gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
gypgyp ERR! configure error
 ERR! gyp configure errorERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
gyp
ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System Linux 5.10.17-v7+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm"
gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
gypgyp ERR! node -v v10.24.0
gyp ERR! node-gyp -v v5.1.0
gyp  ERR! not ok
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm' (1)
node-pre-gyp ERR! stack     at ChildProcess.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
node-pre-gyp ERR! System Linux 5.10.17-v7+
node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
node-pre-gyp ERR! node -v v10.24.0
node-pre-gyp ERR! node-pre-gyp -v v0.6.39
node-pre-gyp ERR! not ok
npm WARN MMM-Hotword@1.0.0 No repository field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the snowboy@1.3.1 install script.
npm ERR!     /home/pi/.npm/_logs/2021-03-26T08_43_05_897Z-debug.log
]]></description><link>https://forum.magicmirror.builders/post/89918</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89918</guid><dc:creator><![CDATA[Karalica-Kir]]></dc:creator><pubDate>Fri, 26 Mar 2021 08:53:17 GMT</pubDate></item><item><title><![CDATA[Reply to problems with hot word on Fri, 26 Mar 2021 07:59:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karalica-kir" aria-label="Profile: karalica-kir">@<bdi>karalica-kir</bdi></a> said in <a href="/post/89916">problems with hot word</a>:</p>
<p dir="auto">HOTWORD</p>
<p dir="auto">I dont know the module by there is a module with the same name on GitHub:</p>
<p dir="auto"><a href="https://github.com/lixiljp/MMM-Hotword" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/lixiljp/MMM-Hotword</a></p>
]]></description><link>https://forum.magicmirror.builders/post/89917</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89917</guid><dc:creator><![CDATA[BravoOscar]]></dc:creator><pubDate>Fri, 26 Mar 2021 07:59:22 GMT</pubDate></item></channel></rss>
