<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[problems with starting]]></title><description><![CDATA[<pre><code>0|mm  | Whoops! There was an uncaught exception...
0|mm  | [2021-03-26 12:14:51.687] [ERROR]
0|mm  | SyntaxError: Unexpected end of JSON input
0|mm  |     at JSON.parse (&lt;anonymous&gt;)
0|mm  |     at Class.getStyleMap (/home/pi/MagicMirror/modules/MMM-GoogleMapsTraffic/node_helper.js:37:46)
0|mm  |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-GoogleMapsTraffic/node_helper.js:22:52)
0|mm  |     at Socket.&lt;anonymous&gt; (/home/pi/MagicMirror/js/node_helper.js:113:11)
0|mm  |     at Socket.emit (events.js:200:13)
0|mm  |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
0|mm  |     at processTicksAndRejections (internal/process/task_queues.js:82:9)
]]></description><link>https://forum.magicmirror.builders/topic/14838/problems-with-starting</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 08:11:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14838.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Mar 2021 09:16:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to problems with starting on Fri, 26 Mar 2021 10:24:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karalica-kir" aria-label="Profile: karalica-kir">@<bdi>karalica-kir</bdi></a><br />
A bit more explanation around all this would be helpful.<br />
You have an issue with the mentioned module MMM-GoogleMapsTraffic.<br />
It wants to read a json input that it cannot understand.<br />
MOst probably from the Google maps API.<br />
SO I would assume somethings wrong with your api key for the google maps api.<br />
But I can only guess.</p>
]]></description><link>https://forum.magicmirror.builders/post/89924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89924</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 26 Mar 2021 10:24:57 GMT</pubDate></item></channel></rss>
