<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[es language to uppercase]]></title><description><![CDATA[<p dir="auto">Hi.</p>
<p dir="auto">I was wondering if anyone has ever tried to change the OpenWeather es language data from lower case to upper case?  The clock/calendar modules for example display marzo instead of Marzo, days are in lower case, etc.  She who must be obeyed was “commenting” on it.  Is it possible to translate the es lowercase data to uppercase in translations es.json?  I didn’t think I could because I thought the translated spanish data, plus calendar month starting on Domingo (oops - dom.), was data supplied from the OpenWeather app.  It sure would be easier to do the translation in en.json.  I did try “marzo”: “Marzo”, in the es.json file to no success.  The month/day format is" MMM Do" in the .js so is it possible to do something weird with moment?</p>
<p dir="auto">Wheee!</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14842/es-language-to-uppercase</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 00:36:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14842.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Mar 2021 16:28:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to es language to uppercase on Tue, 30 Mar 2021 18:47:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scumbelly" aria-label="Profile: scumbelly">@<bdi>scumbelly</bdi></a> great solution! css is really powerful!</p>
]]></description><link>https://forum.magicmirror.builders/post/90104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90104</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 30 Mar 2021 18:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to es language to uppercase on Tue, 30 Mar 2021 15:38:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a>,</p>
<p dir="auto">Hi,</p>
<p dir="auto">I went through moment.js looking at ways to capitalize  ‘domingo’ etc.  I could create a function with ‘var str  =’ and ‘var res =’, or do a moment.locale (“es”) define a var for months and days with uppercase and do a moment.UpdateLocale but all involving modifying the .js file.</p>
<p dir="auto">There was a solution editing the /MagicMirror/vendor/node_modules/moment/min/moment-with-locales.js which would change every module.</p>
<p dir="auto">However, this morning I tripped over just adding text-transform: capitalize to the .css for the module.  I updated .clock and calendar_monthly.  It worked.  It’s simple and no messing with moment.locale and the .js</p>
<p dir="auto">I learned some things poking around in moment.js but the .css solution was way easier.</p>
<p dir="auto">Thank you for your insight and suggestions.</p>
<p dir="auto">Cheers!</p>
]]></description><link>https://forum.magicmirror.builders/post/90097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90097</guid><dc:creator><![CDATA[scumbelly]]></dc:creator><pubDate>Tue, 30 Mar 2021 15:38:11 GMT</pubDate></item><item><title><![CDATA[Reply to es language to uppercase on Tue, 30 Mar 2021 11:58:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scumbelly" aria-label="Profile: scumbelly">@<bdi>scumbelly</bdi></a> APIs like openweather usually supply timestamps that get interpeted by moment(). So moment is the one putting out lowercase days/months instead of uppercase, not openweather.<br />
Go through the <a href="https://momentjs.com/docs/" target="_blank" rel="noopener noreferrer nofollow ugc">moment docs</a>, and try to find out if you can somhow manipulate the case.</p>
]]></description><link>https://forum.magicmirror.builders/post/90084</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90084</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 30 Mar 2021 11:58:42 GMT</pubDate></item><item><title><![CDATA[Reply to es language to uppercase on Tue, 30 Mar 2021 11:56:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scumbelly" aria-label="Profile: scumbelly">@<bdi>scumbelly</bdi></a> said in <a href="/post/89998">es language to uppercase</a>:</p>
<p dir="auto">Is it possible to translate the es lowercase data to uppercase in translations es.json?  I didn’t think I could because I thought the translated spanish data, plus calendar month starting on Domingo (oops - dom.), was data supplied from the OpenWeather app.  It sure would be easier to do the translation in en.json.  I did try “marzo”: “Marzo”, in the es.json file to no success.</p>
<p dir="auto">Translations from the translations file only work when they are explicitely called in the source code using the <code>translate</code> function.<br />
Hence, a user cannot decide to translate anything by adding the translation.</p>
]]></description><link>https://forum.magicmirror.builders/post/90083</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90083</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 30 Mar 2021 11:56:17 GMT</pubDate></item><item><title><![CDATA[Reply to es language to uppercase on Sat, 27 Mar 2021 17:49:58 GMT]]></title><description><![CDATA[<p dir="auto">I went through the locales.js and everything was lowercase.</p>
<p dir="auto"><a href="https://momentjs.com/downloads/moment-with-locales.js" target="_blank" rel="noopener noreferrer nofollow ugc">https://momentjs.com/downloads/moment-with-locales.js</a></p>
<p dir="auto">The only thing that I can think of doing was setting the config.js back to en.json and in the clock/calendar.js create a translation string and put that into es.json and leave the month starting on Domingo and not Lunes (like in the English en.json ).  It’s confusing anyway to look at the english calendar with the week starting on Sunday and then you look at the Spanish calendar and it starts on Monday and visually things are off by one.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/90001</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90001</guid><dc:creator><![CDATA[scumbelly]]></dc:creator><pubDate>Sat, 27 Mar 2021 17:49:58 GMT</pubDate></item></channel></rss>
