<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black screen after update - reason layer 8!]]></title><description><![CDATA[<p dir="auto">Hello,<br />
since today my MM got a black screen.<br />
When I start with " npm start dev" I got the following error</p>
<pre><code>[2021-04-02 14:27:32.741] [LOG]    Initializing new module helper ...
[2021-04-02 14:27:32.745] [LOG]    Module helper loaded: MMM-DarkSkyForecast
[2021-04-02 14:27:33.532] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'digest-fetch'
Require stack:
- /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
- /home/pi/MagicMirror/modules/default/calendar/node_helper.js
[2021-04-02 14:27:33.535] [LOG]    Loading module helpers ...
<p dir="auto">In the update notes I can see the following</p>
<p dir="auto"><em>Replaced deprecated request package with node-fetch and digest-fetch.<br />
Refactored calendar fetcher.</em></p>
<p dir="auto">“npm rebuild” in the calendar module doesn´t help.</p>
<p dir="auto">It would be wonderful if someone could help me.</p>
<p dir="auto">Thank you in advance.<br />
Lars</p>
]]></description><link>https://forum.magicmirror.builders/topic/14872/black-screen-after-update-reason-layer-8</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 02:43:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14872.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Apr 2021 12:38:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black screen after update - reason layer 8! on Fri, 02 Apr 2021 13:13:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok, I understand. Then I have to update it manualy in future. Thanks again for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/90226</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90226</guid><dc:creator><![CDATA[Klinge]]></dc:creator><pubDate>Fri, 02 Apr 2021 13:13:52 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen after update - reason layer 8! on Fri, 02 Apr 2021 13:09:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klinge" aria-label="Profile: klinge">@<bdi>klinge</bdi></a> nothing I am aware of… not reliable, u change 1 file and the pull will fail</p>
]]></description><link>https://forum.magicmirror.builders/post/90225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90225</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Apr 2021 13:09:45 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen after update - reason layer 8! on Fri, 02 Apr 2021 13:08:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> But unfortunately I´m a lazy dog. There is nothing automated?</p>
]]></description><link>https://forum.magicmirror.builders/post/90224</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90224</guid><dc:creator><![CDATA[Klinge]]></dc:creator><pubDate>Fri, 02 Apr 2021 13:08:50 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen after update - reason layer 8! on Fri, 02 Apr 2021 13:05:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klinge" aria-label="Profile: klinge">@<bdi>klinge</bdi></a> automated is trouble…   and recommended is trouble</p>
<p dir="auto">thats why I wrote my script<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts#update-to-next-magicmirror-version-from-an-existing-magicmirror-installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts#update-to-next-magicmirror-version-from-an-existing-magicmirror-installation</a></p>
<p dir="auto">but it is manual</p>
]]></description><link>https://forum.magicmirror.builders/post/90223</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90223</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Apr 2021 13:05:12 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen after update - reason layer 8! on Fri, 02 Apr 2021 13:02:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> That´s it. Thank you for your quick help.</p>
<p dir="auto">The worst part is that I had the same problem before and did it wrong again.</p>
<p dir="auto">The problem is that I run a cronjob at night where the update is triggered automatically via git “pull &amp;&amp; npm install”. And you had already mentioned with my last problem that this is stinky.</p>
<p dir="auto">Maybe you have another tip for me on how to best set up an automated update.</p>
<p dir="auto">Thanks a lot.</p>
]]></description><link>https://forum.magicmirror.builders/post/90222</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90222</guid><dc:creator><![CDATA[Klinge]]></dc:creator><pubDate>Fri, 02 Apr 2021 13:02:13 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen after update - reason layer 8! on Fri, 02 Apr 2021 12:43:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klinge" aria-label="Profile: klinge">@<bdi>klinge</bdi></a> after git pull, did u do npm install to update ?</p>
]]></description><link>https://forum.magicmirror.builders/post/90221</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90221</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 02 Apr 2021 12:43:01 GMT</pubDate></item></channel></rss>
