<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Homebridge and MM?]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I’m considering a smart Home project using HomeKit, and I really want to include a magic mirror, so I thought about including homebridge,</p>
<p dir="auto">Has anyone else done this successfully?</p>
<p dir="auto">Did you have to put the homebridge on a separate raspberry pi or can they both go on the same pi?</p>
<p dir="auto">I’m mostly interested in voice control to turn the monitor on and off via Siri.  (And adding other devices to homebridge like a vacuum. )</p>
<p dir="auto">Any other thoughts or ideas gratefully received.</p>
<p dir="auto">Thank you</p>
]]></description><link>https://forum.magicmirror.builders/topic/14887/homebridge-and-mm</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 03:43:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14887.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Apr 2021 21:09:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Homebridge and MM? on Sun, 11 Apr 2021 04:42:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oberfragger" aria-label="Profile: oberfragger">@<bdi>oberfragger</bdi></a> thank you for mentioning pihole it sounds really useful, I’ll add it to my project scope :D</p>
]]></description><link>https://forum.magicmirror.builders/post/90531</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90531</guid><dc:creator><![CDATA[Roger 0]]></dc:creator><pubDate>Sun, 11 Apr 2021 04:42:40 GMT</pubDate></item><item><title><![CDATA[Reply to Homebridge and MM? on Sun, 11 Apr 2021 04:35:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shagui2211" aria-label="Profile: shagui2211">@<bdi>shagui2211</bdi></a> thank you I wasn’t sure if I was being a little crazy… did you manage to get HomeKit and MM to interact via homebridge? Any tips or advice? I’m  looking for a way to change what’s on the MM in relation to who is using it, maybe an nfc nearby or something triggering the screen to turn on and show that persons page or the can just use the mirror…</p>
]]></description><link>https://forum.magicmirror.builders/post/90530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90530</guid><dc:creator><![CDATA[Roger 0]]></dc:creator><pubDate>Sun, 11 Apr 2021 04:35:53 GMT</pubDate></item><item><title><![CDATA[Reply to Homebridge and MM? on Fri, 09 Apr 2021 17:15:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roger-0" aria-label="Profile: roger-0">@<bdi>roger-0</bdi></a> Dont forget pihole. But if youre using homebridge and piHole (everthing  network related), i suggest LAN.</p>
<p dir="auto">Its really annoying when you open Home in the iPhone and have “Aktualisierung” in red for 1-2 seconds. But givi it a try…!</p>
]]></description><link>https://forum.magicmirror.builders/post/90491</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90491</guid><dc:creator><![CDATA[OberfragGER]]></dc:creator><pubDate>Fri, 09 Apr 2021 17:15:43 GMT</pubDate></item><item><title><![CDATA[Reply to Homebridge and MM? on Fri, 09 Apr 2021 16:47:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/roger-0" aria-label="Profile: roger-0">@<bdi>roger-0</bdi></a></p>
<p dir="auto">Hello, I have magic mirror, plex server and homebrige on the same unit. And the truth is going really well. Yes. No problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/90489</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90489</guid><dc:creator><![CDATA[shagui2211]]></dc:creator><pubDate>Fri, 09 Apr 2021 16:47:42 GMT</pubDate></item></channel></rss>
