<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issues with launching]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/12507/mmm-jast-just-another-stock-ticker-new-version-2-0-0">[MMM-JaST] Just another Stock Ticker (new: version 2.0.0)</a></p>
<p dir="auto">It is giving me launch issues and says that there is an issue with the line XXX  in the config launch and then says ‘stocks: [’ (ignore the single quote. I am not sure what I am missing. With the sample stock quotes they should work or are the fake? I have also tried with stocks I want to follow and it still failed.  Any help would be great!!</p>
]]></description><link>https://forum.magicmirror.builders/topic/14890/issues-with-launching</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 07:31:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14890.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Apr 2021 00:14:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issues with launching on Wed, 07 Apr 2021 00:22:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jstr965" aria-label="Profile: jstr965">@<bdi>jstr965</bdi></a> please do</p>
<pre><code>cd ~/MagicMirror
npm run config:check
<p dir="auto">this will syntax check the config file</p>
<p dir="auto">also, could you show more of the errors from when you do</p>
<pre><code>npm start
<p dir="auto">the default behavior for  MM is to keep running,<br />
I wish it would stop</p>
]]></description><link>https://forum.magicmirror.builders/post/90362</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90362</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 07 Apr 2021 00:22:38 GMT</pubDate></item></channel></rss>
