<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a way to show different CSS to different devices, or should I run multiple mirrors?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I was wondering if there is a way to show different layouts of the same MM to different users?</p>
<p dir="auto">My example is that I will have a permanent MM set up, but will also view the content on a phone, TV, and laptop, and I would like it to have formatting correct for each one.  I am using MM as a dashboard, kind of like the old iGoogle homepage.</p>
<p dir="auto">Is there a way to do this via CSS by differentiating user-agents/browsers, or could I run multiple different MMs and then bookmark them individually on each device.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14906/is-there-a-way-to-show-different-css-to-different-devices-or-should-i-run-multiple-mirrors</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 11:20:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14906.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Apr 2021 15:57:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there a way to show different CSS to different devices, or should I run multiple mirrors? on Fri, 09 Apr 2021 17:59:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/causerino" aria-label="Profile: causerino">@<bdi>causerino</bdi></a> yes, see</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/14209/server-client-setup-how-to-force-client-s-custom-css/4?_=16175438725888">https://forum.magicmirror.builders/topic/14209/server-client-setup-how-to-force-client-s-custom-css/4?_=16175438725888</a></p>
]]></description><link>https://forum.magicmirror.builders/post/90494</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90494</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 09 Apr 2021 17:59:58 GMT</pubDate></item></channel></rss>
