<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar Date Formats Not Working.]]></title><description><![CDATA[<p dir="auto">Module  =  Calendar<br />
Issue  =  Trying to get the date format is DD/MM/YYYY currently in default even when specified not to. Don’t know if I am incorrectly specifying.<br />
Current Module Config  =  {<br />
module: “calendar”,<br />
header: “My Calendar”,<br />
position: “top_left”,<br />
config: {<br />
maximumEntries: “6”,<br />
maximumNumberOfDays: “7”,<br />
wrapEvents: “true”,<br />
maxTitleLines: “2”,<br />
fadePoint: “1”,<br />
dateFormat: “Do MMM”,<br />
hideTime: “true”,<br />
fetchInterval: “60000”,<br />
calendars: [<br />
{<br />
symbol: “calendar-check”,<br />
url: “webcal://p39-caldav.icloud.com/published/2/MTExNjgwMjM2NTExMTE2OIZFb1PsCmMo3ecwDd6H7xOGtd_rniDwbBvisBnUUbTo”<br />
},<br />
{<br />
url: “webcal://p39-caldav.icloud.com/published/2/MTExNjgwMjM2NTExMTE2OIZFb1PsCmMo3ecwDd6H7xPI-y3Ntq2MNAzfi5poNWuySmEYsiAGaraNGLnR7zZorrG5xXn8wrtERNCCDMDMxcw”<br />
}<br />
]<br />
}<br />
}</p>
]]></description><link>https://forum.magicmirror.builders/topic/14921/calendar-date-formats-not-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 20:21:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14921.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Apr 2021 15:31:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar Date Formats Not Working. on Tue, 13 Apr 2021 09:06:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tippon" aria-label="Profile: tippon">@<bdi>tippon</bdi></a><br />
Thanks this now working perfectly.</p>
]]></description><link>https://forum.magicmirror.builders/post/90603</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90603</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 13 Apr 2021 09:06:30 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Date Formats Not Working. on Tue, 13 Apr 2021 01:24:41 GMT]]></title><description><![CDATA[<p dir="auto">@jack_barnard I’ve got mine setup like this:</p>
<pre><code>        timeFormat: 'absolute',
        dateFormat: 'DD/MM/YYYY',
        fullDayEventDateFormat: 'DD/MM/YYYY',
<p dir="auto">Hope this helps :)</p>
]]></description><link>https://forum.magicmirror.builders/post/90595</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90595</guid><dc:creator><![CDATA[Tippon]]></dc:creator><pubDate>Tue, 13 Apr 2021 01:24:41 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Date Formats Not Working. on Mon, 12 Apr 2021 16:45:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks for pointing me in the right direction but I don’t understand the moments formating for dates could you explain further on how to setup the correct format?</p>
]]></description><link>https://forum.magicmirror.builders/post/90582</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90582</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 12 Apr 2021 16:45:48 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Date Formats Not Working. on Mon, 12 Apr 2021 16:41:37 GMT]]></title><description><![CDATA[<p dir="auto">@jack_barnard <a href="https://devhints.io/moment" target="_blank" rel="noopener noreferrer nofollow ugc">https://devhints.io/moment</a></p>
<p dir="auto"><a href="https://docs.magicmirror.builders/modules/calendar.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/calendar.html</a></p>
<p dir="auto">there are also fullDayEventDateFormat</p>
]]></description><link>https://forum.magicmirror.builders/post/90581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90581</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 12 Apr 2021 16:41:37 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Date Formats Not Working. on Mon, 12 Apr 2021 16:19:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks that has helped a bit but the date still won’t display in DD/MM/YYYY which should the value be for dateFormat: “”?</p>
]]></description><link>https://forum.magicmirror.builders/post/90580</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90580</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 12 Apr 2021 16:19:47 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar Date Formats Not Working. on Mon, 12 Apr 2021 15:40:55 GMT]]></title><description><![CDATA[<p dir="auto">@jack_barnard must use tineFormat: ‘absolute’ to turn on those controls</p>
]]></description><link>https://forum.magicmirror.builders/post/90579</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90579</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 12 Apr 2021 15:40:55 GMT</pubDate></item></channel></rss>
