<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ESP8266 + DHT22 + Thingspeak in magic mirror]]></title><description><![CDATA[<p dir="auto">Hello Guys.</p>
<p dir="auto">Recently i discovered the world of raspberry and Linux. I started with the magic mirror project and now want to extend the functionality. I want to do this with adding extra sensor to the magic mirror. To measure the temperature in different living rooms. I’ve done this  with the following hardware:</p>
<p dir="auto">I’ve set up a ESP8266 with DHT22 sensor on-board in the living room.</p>
<p dir="auto">I’ve successfully configured this with thing speak but i cant seem to find any module or code that can help me out, to read the information from thing speak (api) and show it on the mirror right top side.</p>
<p dir="auto">I hope someone can help me out to make a module that can read multiple channels (temp + humidity in different rooms) from Thing speak and show it on the mirror.</p>
<p dir="auto">Yours, Fabian</p>
]]></description><link>https://forum.magicmirror.builders/topic/1493/esp8266-dht22-thingspeak-in-magic-mirror</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 15:20:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1493.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Jan 2017 16:58:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Mon, 23 Jan 2017 21:07:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tosti007" aria-label="Profile: tosti007">@<bdi>tosti007</bdi></a> Why Thingspeak and not FHEM?</p>
]]></description><link>https://forum.magicmirror.builders/post/12261</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12261</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Mon, 23 Jan 2017 21:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Mon, 23 Jan 2017 17:22:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gelomidor" aria-label="Profile: Gelomidor">@<bdi>Gelomidor</bdi></a> I just realised I made a mistake! Setti your channel to public isn’t secure (anyone would be able to check the states of your lamps ect). Instead you should add the api key to the url by using the same url you would use when it’s public and adding <code>&amp;api_key=YOUR_KEY</code> at the end of the url. Please do update this! (also remove the channel id in the url you usef above in post 6)</p>
]]></description><link>https://forum.magicmirror.builders/post/12221</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12221</guid><dc:creator><![CDATA[tosti007]]></dc:creator><pubDate>Mon, 23 Jan 2017 17:22:02 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Mon, 23 Jan 2017 17:03:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gelomidor" aria-label="Profile: Gelomidor">@<bdi>Gelomidor</bdi></a> ah great! You’re welcome and enjoy it :D</p>
]]></description><link>https://forum.magicmirror.builders/post/12217</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12217</guid><dc:creator><![CDATA[tosti007]]></dc:creator><pubDate>Mon, 23 Jan 2017 17:03:27 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Mon, 23 Jan 2017 17:08:21 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Thank you so much for your help!</p>
<p dir="auto">You’re welcome :D</p>
<p dir="auto">What i dont get it is why are there so many links and why dont all links have a description above it?</p>
<p dir="auto">There are so many links because you have to retrieve every field by itself. They don’t have a description because just defining a field to retrieve doesn’t display it yet, this is done in the output section.</p>
<p dir="auto">Should i only use celsius and humidity?</p>
<p dir="auto">You can use anything you want.</p>
<p dir="auto">Could you also explain what mapping means?</p>
<p dir="auto">Using mapping is a way to translate one value into another. For example you retrieve the state of your lamps and it returns a boolean. Just displaying <code>true</code> or <code>false</code> doesn’t look so nice. <code>on</code> or <code>off</code> would be better and make more sense in a human way. So you could use a mapping to translate that. For the example above the mapping would be:</p>
<pre><code class="language-javascript">mappings: {
    on_off: {
        true: 'on',
        false: 'off',
<p dir="auto">The urls i replace with my urls: <a href="https://api.thingspeak.com/channels/xxxxx/fields/2/last.txt" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.thingspeak.com/channels/xxxxx/fields/2/last.txt</a></p>
<p dir="auto">Don’t forget to make an url for each field.</p>
<p dir="auto">With configure output you mean: if i have multiple fields i have to change that number.</p>
<p dir="auto">No, <code>output</code> configures the way you display your sections (after mapping and formatting) on your mirror.<br />
So for example you have defined 3 urls in the <code>sections</code> value. The first url is the state of your lamps (with a mapping), the second is the humidity in your living room and the third the temperature in your living room. And you want to display it like:</p>
<pre><code>Lamps on
Livingroom 21 degrees 52%
<p dir="auto">Then your output would look like:</p>
<pre><code class="language-javascript">output: [
    ['Lamps','@1'], // use number 1 here because you defined that first in sections
    ['Livingroom','@3','@2'] // you defined temperature as third, but we want to display it first,?so we use @3 first and @2 second
<p dir="auto">Does this explain everything? :)</p>
]]></description><link>https://forum.magicmirror.builders/post/12215</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12215</guid><dc:creator><![CDATA[tosti007]]></dc:creator><pubDate>Mon, 23 Jan 2017 17:08:21 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Mon, 23 Jan 2017 16:59:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tosti007" aria-label="Profile: tosti007">@<bdi>tosti007</bdi></a> I got it all working! thank you for pointing me in the right direction!! :D</p>
]]></description><link>https://forum.magicmirror.builders/post/12214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12214</guid><dc:creator><![CDATA[Gelomidor]]></dc:creator><pubDate>Mon, 23 Jan 2017 16:59:39 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Mon, 23 Jan 2017 18:31:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tosti007" aria-label="Profile: tosti007">@<bdi>tosti007</bdi></a> Thank you so much for your help! I was so close. everything you describe i did except for making it public.:D The url gives the correct value. What i dont get it is why are there so many links and why dont all links have a description above it? Should i only use celsius and humidity? Could you also explain what mapping means?</p>
<pre><code>{
    format: '%.1f',
    url: 'https://www.dirk-melchers.de/echo.php?text=22.54',
    format: '%d%%',
    url: 'https://www.dirk-melchers.de/echo.php?text=59.1',
    format: '%s',
    mapping: 'temperature',
    url: 'https://www.dirk-melchers.de/echo.php?text=2',
    format: '%d',
    url: 'https://www.dirk-melchers.de/echo.php?text=62.1',
    format: 'Lights %s',
    mapping: 'on_off',
    url: 'https://www.dirk-melchers.de/echo.php?text=true',
<p dir="auto">The urls i replace with my urls: <a href="https://api.thingspeak.com/channels/12345/fields/12345/last.txt" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.thingspeak.com/channels/12345/fields/12345/last.txt</a><br />
Like this one for the humidity.<br />
With configure output you mean: if i have multiple fields i have to change that number. In my case, just for beginning:</p>
<p dir="auto"><code>[Livingroom','@1','@2'],</code></p>
<p dir="auto">Too bad im at work and cant configure my raspberry. But this feels like it should work. :)</p>
<hr />
<p dir="auto"><strong>Note from admin:</strong> please use Markup when posting code.</p>
]]></description><link>https://forum.magicmirror.builders/post/12164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12164</guid><dc:creator><![CDATA[Gelomidor]]></dc:creator><pubDate>Mon, 23 Jan 2017 18:31:56 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Mon, 23 Jan 2017 17:18:55 GMT]]></title><description><![CDATA[<p dir="auto">Alright so I read it partially and as I understand it you have to do it in a few steps:<br />
First you have to <a href="https://nl.mathworks.com/help/thingspeak/create-a-channel.html" target="_blank" rel="noopener noreferrer nofollow ugc">create a channel</a> and <a href="https://nl.mathworks.com/help/thingspeak/channel-settings.html" target="_blank" rel="noopener noreferrer nofollow ugc">configure it</a> <s>(don’t forget to set it to public)</s>. <strong>Important:</strong> don’t set it to public as this is not secure! Use the api key you have from the channel instead! You can use the api key by adding <code>&amp;api_key=YOUR_KEY</code> at the end of the url you would use when the channel is public!</p>
<p dir="auto">The <a href="https://github.com/Tuxdiver/MMM-Rest" target="_blank" rel="noopener noreferrer nofollow ugc">REST module</a> accepts only single values from the URL. So you cannot get the whole feed at once. What you will have to do instead is retrieve only one field as text. How to do that can be found <a href="https://nl.mathworks.com/help/thingspeak/get-channel-field-feed.html" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> under <code>Get Last Entry in a Field Feed</code> and then <code>Text</code>.<br />
So having configured a channel, having the right URL for the field you want with the api key in it (you can test if it’s correct by going to the URL yourself and you should see only a single value) the last thing for you to do is configure the module.<br />
How to do that can be found it the module’s <a href="https://github.com/Tuxdiver/MMM-Rest/blob/master/README.md" target="_blank" rel="noopener noreferrer nofollow ugc">README.md</a>. Don’t forget to configure <code>output</code> aswell, else you won’t see anything on screen. Hope this is what you are looking for, if it still doesn’t work or you have any other questions don’t hesitate to ask/let me know!</p>
]]></description><link>https://forum.magicmirror.builders/post/12147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12147</guid><dc:creator><![CDATA[tosti007]]></dc:creator><pubDate>Mon, 23 Jan 2017 17:18:55 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Sun, 22 Jan 2017 22:04:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gelomidor" aria-label="Profile: Gelomidor">@<bdi>Gelomidor</bdi></a> I will give it a read and let you know when I know more :)</p>
]]></description><link>https://forum.magicmirror.builders/post/12104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12104</guid><dc:creator><![CDATA[tosti007]]></dc:creator><pubDate>Sun, 22 Jan 2017 22:04:42 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Sun, 22 Jan 2017 20:00:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tosti007" aria-label="Profile: tosti007">@<bdi>tosti007</bdi></a> Hi, thank you for the reply. I’ve saw that one and tried it but it just sas: MMM-Rest loading… I’ve tried all kinds of urls, but i’m afraid that im too un-experienced to get it to work. Is there any chance that you can guide me to set it up correctly?</p>
<p dir="auto">My appreciation would be big! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/12089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12089</guid><dc:creator><![CDATA[Gelomidor]]></dc:creator><pubDate>Sun, 22 Jan 2017 20:00:58 GMT</pubDate></item><item><title><![CDATA[Reply to ESP8266 + DHT22 + Thingspeak in magic mirror on Sun, 22 Jan 2017 17:35:40 GMT]]></title><description><![CDATA[<p dir="auto">I gave it a really quick look and noticed that they have a REST API. There is already a module for that <a href="https://forum.magicmirror.builders/topic/561/mmm-rest">here</a>. Hope that this is what you are looking for!</p>
]]></description><link>https://forum.magicmirror.builders/post/12058</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12058</guid><dc:creator><![CDATA[tosti007]]></dc:creator><pubDate>Sun, 22 Jan 2017 17:35:40 GMT</pubDate></item></channel></rss>
