<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My MM set up now need help with Wifi]]></title><description><![CDATA[<p dir="auto">Firstly this forum has been a great help and so much learning from the topics. but now I am looking for help in enabling wifi on my RPI 3 B+. I tried for 2 days and decided to hook up with RJ45 cable to at least get the MM working. I have managed to set up everything but now I don’t have a choice but to set up wifi. Any help will be appreciated.</p>
<p dir="auto">Am very pleased with what I have achieved by going through the topics. Thank you to all</p>
<p dir="auto"><img src="/assets/uploads/files/1618575794915-screen-shot-2021-04-14-at-11.02.21-pm-resized.png" alt="Screen Shot 2021-04-14 at 11.02.21 PM.png" class="img-markdown  img-fluid" /> <img src="/assets/uploads/files/1618575811564-screen-shot-2021-04-14-at-7.56.58-pm-resized.png" alt="Screen Shot 2021-04-14 at 7.56.58 PM.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/14945/my-mm-set-up-now-need-help-with-wifi</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 06:13:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14945.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Apr 2021 12:24:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Sun, 18 Apr 2021 04:34:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i tried GB, US and IN</p>
]]></description><link>https://forum.magicmirror.builders/post/90815</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90815</guid><dc:creator><![CDATA[miniashman]]></dc:creator><pubDate>Sun, 18 Apr 2021 04:34:48 GMT</pubDate></item><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Sat, 17 Apr 2021 19:04:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miniashman" aria-label="Profile: miniashman">@<bdi>miniashman</bdi></a>  hm… what country?</p>
]]></description><link>https://forum.magicmirror.builders/post/90800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90800</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 17 Apr 2021 19:04:25 GMT</pubDate></item><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Sat, 17 Apr 2021 18:08:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i did try that with the latest but would not let me set WIFI country as it was greyed out. I tried multiple images and must have read various posts to figure out. spent a week trying to get the wifi working but had to give up and used a network cable. Now that I have set up the MM I am trying again to set up wifi. you are right so many old posts (some without dates) so am trying everything right now just to get it working. Any post you can direct me to have a look?</p>
]]></description><link>https://forum.magicmirror.builders/post/90798</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90798</guid><dc:creator><![CDATA[miniashman]]></dc:creator><pubDate>Sat, 17 Apr 2021 18:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Sat, 17 Apr 2021 12:18:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miniashman" aria-label="Profile: miniashman">@<bdi>miniashman</bdi></a> why did u add the file on the original image?   that is very old instructions.</p>
<p dir="auto">can u do with just the latest pi os image<br />
boot and try to connect using the menu on the toolbar</p>
]]></description><link>https://forum.magicmirror.builders/post/90790</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90790</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 17 Apr 2021 12:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Sat, 17 Apr 2021 06:35:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thgmirror" aria-label="Profile: thgmirror">@<bdi>thgmirror</bdi></a> thank you. but that didnt work either. I did add that file when I created the original image. I also tried again after getting MM working. Also checked the file by</p>
<pre><code>sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
<p dir="auto">any my wifi set up is there.</p>
]]></description><link>https://forum.magicmirror.builders/post/90781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90781</guid><dc:creator><![CDATA[miniashman]]></dc:creator><pubDate>Sat, 17 Apr 2021 06:35:17 GMT</pubDate></item><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Fri, 16 Apr 2021 14:01:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miniashman" aria-label="Profile: miniashman">@<bdi>miniashman</bdi></a><br />
Try this, maybe it helps:<br />
shutdown your pi, take the sd-card out, put it in a card-reader and plug it in a windows-PC. Copy an empty file called ssh (with no extension, take care your PC shows all extensions) and also a file named wpa_supplicant.conf into the root-directory of the SD-card<br />
The file wpa_supplicant.conf needs the following content, of course with your credentials:</p>
<p dir="auto">country=EN<br />
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev<br />
update_config=1<br />
network={<br />
ssid=“thenameofyournetwork”<br />
psk=“yourpassword”<br />
key_mgmt=WPA-PSK<br />
}</p>
<p dir="auto">Put it back into your RPI and boot.</p>
<p dir="auto">Thomas</p>
]]></description><link>https://forum.magicmirror.builders/post/90766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90766</guid><dc:creator><![CDATA[thgmirror]]></dc:creator><pubDate>Fri, 16 Apr 2021 14:01:25 GMT</pubDate></item><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Fri, 16 Apr 2021 12:38:17 GMT]]></title><description><![CDATA[<p dir="auto">I remember going through this when i was setting up. Didn’t help as when I try this, the result is this.</p>
<p dir="auto">pi@raspberry:/ $ sudo iwlist wlan0 scan<br />
wlan0     Interface doesn’t support scanning.<br />
pi@raspberry:/ $</p>
]]></description><link>https://forum.magicmirror.builders/post/90763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90763</guid><dc:creator><![CDATA[miniashman]]></dc:creator><pubDate>Fri, 16 Apr 2021 12:38:17 GMT</pubDate></item><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Fri, 16 Apr 2021 12:34:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> Thank you for quick reply.  Doing it now.<br />
:beer_mug:  Cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/90762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90762</guid><dc:creator><![CDATA[miniashman]]></dc:creator><pubDate>Fri, 16 Apr 2021 12:34:42 GMT</pubDate></item><item><title><![CDATA[Reply to My MM set up now need help with Wifi on Fri, 16 Apr 2021 12:31:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/miniashman" aria-label="Profile: miniashman">@<bdi>miniashman</bdi></a> <a href="https://www.electronicshub.org/setup-wifi-raspberry-pi-3/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.electronicshub.org/setup-wifi-raspberry-pi-3/</a></p>
<p dir="auto">;)</p>
]]></description><link>https://forum.magicmirror.builders/post/90761</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/90761</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 16 Apr 2021 12:31:16 GMT</pubDate></item></channel></rss>
