<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM- Remote Control help]]></title><description><![CDATA[<p dir="auto">Can anyone explain the ip modifications needed to the config file for the Remote Control module?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14996/mmm-remote-control-help</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 07:41:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14996.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Apr 2021 13:39:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM- Remote Control help on Sun, 02 May 2021 14:51:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/digidadbod" aria-label="Profile: digidadbod">@<bdi>digidadbod</bdi></a></p>
<p dir="auto">That’s great.  Thank you for the tip</p>
]]></description><link>https://forum.magicmirror.builders/post/91221</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91221</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Sun, 02 May 2021 14:51:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Sun, 02 May 2021 04:23:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> just want to let you know; depending on how good your router is, you should be able to get it set up on a separate IOT network if desired. I forget exactly how I set mine up but it was either by allowing specific IP addresses to talk to each other one way, or a combo of that and enebling mDNS of some sorts (which is something I think you have to enable for things like Google speaker on an adjacent local network).  Obviously, you will find better info on a forum dedicated to your router…</p>
]]></description><link>https://forum.magicmirror.builders/post/91205</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91205</guid><dc:creator><![CDATA[DigiDadbod]]></dc:creator><pubDate>Sun, 02 May 2021 04:23:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Thu, 29 Apr 2021 00:02:59 GMT]]></title><description><![CDATA[<p dir="auto">:grinning_face_with_sweat:</p>
]]></description><link>https://forum.magicmirror.builders/post/91145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91145</guid><dc:creator><![CDATA[CheapDad]]></dc:creator><pubDate>Thu, 29 Apr 2021 00:02:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Wed, 28 Apr 2021 22:02:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Nailed it!  That was exactly the issue.</p>
<p dir="auto">Thank you Sam.  SOLVED</p>
]]></description><link>https://forum.magicmirror.builders/post/91143</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91143</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 28 Apr 2021 22:02:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Wed, 28 Apr 2021 12:25:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> had someone the other day have pi on guest wifi while phone was on family wifi…</p>
]]></description><link>https://forum.magicmirror.builders/post/91132</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91132</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 28 Apr 2021 12:25:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Wed, 28 Apr 2021 12:15:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thanks Sam.  Oddly turning off firewall is yielding the same results.</p>
<p dir="auto">Not sure the problem…</p>
]]></description><link>https://forum.magicmirror.builders/post/91131</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91131</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 28 Apr 2021 12:15:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Wed, 28 Apr 2021 00:08:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> ok, so it’s a networking problem</p>
<p dir="auto">u said windows… I always turn off the firewall for a while</p>
]]></description><link>https://forum.magicmirror.builders/post/91129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91129</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 28 Apr 2021 00:08:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Wed, 28 Apr 2021 00:03:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> sadly no</p>
<p dir="auto">This site can’t be reachedCheck if there is a typo in ip.<br />
If spelling is correct, try running Windows Network Diagnostics.<br />
DNS_PROBE_FINISHED_NXDOMAIN</p>
]]></description><link>https://forum.magicmirror.builders/post/91128</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91128</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 28 Apr 2021 00:03:30 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Tue, 27 Apr 2021 23:53:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> can u connect to mm</p>
<p dir="auto"><a href="http://ip:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://ip:8080</a></p>
]]></description><link>https://forum.magicmirror.builders/post/91127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91127</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 27 Apr 2021 23:53:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Tue, 27 Apr 2021 23:47:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thanks for the help.  []</p>
<p dir="auto">This site can’t be <a href="http://reached192.168.xxx.xxx" target="_blank" rel="noopener noreferrer nofollow ugc">reached192.168.xxx.xxx</a> took too long to respond.<br />
Try:</p>
<p dir="auto">Checking the connection<br />
Checking the proxy and the firewall<br />
Running Windows Network Diagnostics<br />
ERR_CONNECTION_TIMED_OUT</p>
]]></description><link>https://forum.magicmirror.builders/post/91126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91126</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 27 Apr 2021 23:47:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Tue, 27 Apr 2021 23:13:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> 1st let’s take everything out</p>
]]></description><link>https://forum.magicmirror.builders/post/91125</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91125</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 27 Apr 2021 23:13:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Tue, 27 Apr 2021 23:09:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">This is what  have in my ipWhitelist</p>
<p dir="auto">ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “ffff:192.168.XXX.XXX”], // Set [] to allow all IP addresses</p>
<p dir="auto">I have xxx’d my actual ip address.</p>
]]></description><link>https://forum.magicmirror.builders/post/91124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91124</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 27 Apr 2021 23:09:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Tue, 27 Apr 2021 23:01:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> did u remove everything from ipWhitelist?</p>
]]></description><link>https://forum.magicmirror.builders/post/91123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91123</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 27 Apr 2021 23:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Tue, 27 Apr 2021 22:46:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thank you for the reply.  After adjusting the address to “0.0.0.0” and adding my IP, I’m in a holding pattern of blank screen and curser, and no connection to the <a href="http://192.168.xxx.xxx:8080/remote.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.xxx.xxx:8080/remote.html</a> website.</p>
<p dir="auto">“This site can’t be reached”</p>
]]></description><link>https://forum.magicmirror.builders/post/91122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91122</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 27 Apr 2021 22:46:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM- Remote Control help on Tue, 27 Apr 2021 14:05:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a>  the address and ipWhilelist fields control   what clients can connect to MagicMirror</p>
<p dir="auto">address set to “localhost”, means only apps INSIDE the same machine can connect</p>
<p dir="auto">changing to “0.0.0.0” (all adapters)  means SOME systems outside the MM machine can connect,<br />
and ipWhitelist give a list of address masks to test if those systems are allowed</p>
<p dir="auto">for easy access , and no security for anyone on your local lan/wifi), address:“0.0.0.0” and ipWhiltelist:[]  will allow anyone on your lan/wifi to connect to the MagicMirror application</p>
]]></description><link>https://forum.magicmirror.builders/post/91116</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91116</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 27 Apr 2021 14:05:47 GMT</pubDate></item></channel></rss>
