<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need help creating CSS for newsfeed]]></title><description><![CDATA[<p dir="auto">I’d like the newsfeed to appear in the lower right corner of my MM.  I have it set to bottom_right, but that simply left justifies it.  I also have word wrap enabled.</p>
<p dir="auto">In short, I’d like it appear in a box similar to weather or the calendar, with both the article title and description wrapping as needed.  I realize that I likely have to reduce the font to accomplish that as well.</p>
<p dir="auto">Can anyone give me a head start?</p>
<p dir="auto">CheapDad</p>
]]></description><link>https://forum.magicmirror.builders/topic/15009/need-help-creating-css-for-newsfeed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 01:43:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15009.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 May 2021 21:35:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need help creating CSS for newsfeed on Sat, 01 May 2021 22:36:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cheapdad" aria-label="Profile: cheapdad">@<bdi>cheapdad</bdi></a> well, its only a start</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1619795022054">https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1619795022054</a></p>
<p dir="auto">css is an enormous topic… this is the fastest way to see what works… (altho because it changes the topic, its hard to work on some of it… )<br />
<a href="https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1611671889049">https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1611671889049</a></p>
<p dir="auto">you will need to change  the width of the surrounding elements.</p>
<p dir="auto">newsfeed already provides a couple css styles (which you can override in custom.css</p>
]]></description><link>https://forum.magicmirror.builders/post/91203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91203</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 01 May 2021 22:36:28 GMT</pubDate></item></channel></rss>
