<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[npm install stuck]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I’m following the link bellow to install MM<br />
<a href="https://docs.magicmirror.builders/getting-started/installation.html#manual-installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/getting-started/installation.html#manual-installation</a></p>
<p dir="auto">Everything goes right until I type</p>
<pre><code>npm install
<p dir="auto">This process gets stuck midway, I have wanted an hour and nothing has change.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15029/npm-install-stuck</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 10:37:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15029.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 May 2021 20:45:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to npm install stuck on Sat, 08 May 2021 00:21:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/e199504" aria-label="Profile: e199504">@<bdi>e199504</bdi></a></p>
<p dir="auto">Personally, I would use the install script that was created by, and maintained by, <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>. I do a good amount of installations for one reason or another and it’s my go-to installation tool.</p>
<p dir="auto">If you are interested:</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/91327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91327</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 08 May 2021 00:21:24 GMT</pubDate></item></channel></rss>
