<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[calendar module: "displayRepeatingCountTitle" doesn't show peoples age]]></title><description><![CDATA[<p dir="auto">I think this is a bug, but not 100% sure.<br />
According to the documentation, I expected setting “displayRepeatingCountTitle: true,” would enable the display of peoples’ age in calendar module, but this doesn’t even work when setting it as default (which worked for “maximumEntries”)</p>
<p dir="auto"><strong>Platform</strong>: ARM7 (Raspberry Pi 3+)<br />
<strong>Node Version</strong>: node@c46f41368c36:/opt/magic_mirror$ node -v<br />
v14.16.1<br />
<strong>MagicMirror Version</strong>: (no<code>package.log</code> in this installation)<br />
2021-04-13_2021-03-04-magicmirroros-buster-armhf-lite-0.2.0</p>
<p dir="auto"><strong>Description</strong>: the configured ics urls link to ics data with valid birthday entries and they are not being displayed on MM’s calendar module, but not their current age as intended by “displayRepeatingCountTitle” (as far as i understood).</p>
<p dir="auto"><strong>Steps to Reproduce</strong>:  base config in “~/magicmirror/mounts/config/config.js”, entry in calendar section (tried module- config- and calendar-context)<br />
&amp;&amp; “docker container restart mm” -&gt; people and the birthday are displayed, but not their age.<br />
Like with the (in this installation) not-working “maximumEntries”, i chose to config this in the default values within the docker container:<br />
“docker exec -it mm /bin/bash” (login to mm container)<br />
node@c46f41368c36:/opt/magic_mirror$ nano mount_ori/modules/default/calendar/calendar.js<br />
<strong>Expected Results</strong>: As shown in several screenshots, there should be the age of the people shown after or before their name.<br />
<strong>Actual Results</strong>: Just name and date are displayed.<br />
<strong>Configuration</strong>: ~/magicmirror/mounts/config/config.js is attached<br />
<strong>Additional Notes</strong>: At least for the calendar module, url’s pointing to localhost:8080 for local ics files don’t work, i had to setup a small (radicale) server and chose the ip address, althought port 8080 is active in this container.<br />
docker ps -a<br />
CONTAINER ID   IMAGE                          COMMAND                  CREATED       STATUS                 PORTS                    NAMES<br />
381f368fe3fd   tomsquest/docker-radicale      “docker-entrypoint.s…”   5 hours ago   Up 4 hours (healthy)   0.0.0.0:5232-&gt;5232/tcp   radicale-net<br />
c46f41368c36   karsten13/magicmirror:latest   “/usr/bin/tini – ./…”   3 days ago    Up 42 minutes          8080/tcp                 mm</p>
<p dir="auto">2021-04-13_2021-03-04-magicmirroros-buster-armhf-lite-0.2.0<br />
edit: there’s “upload file” and “upload image”, while both do accept only images :-S …</p>
 * By Michael Teeuw https://michaelteeuw.nl
 * MIT Licensed.
var config = {
        address: "0.0.0.0",     // Address to listen on, can be:
        port: 8080,
        basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
        ipWhitelist: [],        // Set [] to allow all IP addresses
        useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
        httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
        httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
        language: "de",
        locale: "de-DE",
        timeFormat: 24,
        units: "metric",
                        module: "alert",
                        module: "updatenotification",
                        position: "top_bar"
                        module: "clock",
                        position: "top_left"
                //      header: "Feiertage",
                //      maximumNumberOfDays: "60",
                //      maximumEntries: "60",
                //      fadePoint: "0.75",
                                                symbol: "birthday-cake",
                                                url: "http://192.168.100.243:5232/nf/62eb4074-d257-bc8a-08e8-fdb88236dddc/",
                        module: "compliments",
                        position: "lower_third",
                        module: "weather",
                                type: "current",
                                locationID: "2945024", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                apiKey: "pizgwecjnpnfjhwpiuchpjf3rtgt3rv"
                        module: "weather",
                        header: "Weather Forecast",
                                type: "forecast",
                                apiKey: "pizgwecjnpnfjhwpiuchpjf3rtgt3rv",
                                fade: false,
                                colored: true
                        module: "MMM-Mopidy-MPD",
                        position: "top_right",  // This can be any of the regions.
                                hostname: "vox",
                                port: 6600
                        module: "newsfeed",
                        position: "top_center",
                                feeds: [
                                                title: "BS Bekanntmachungen",
                                                url: "https://www.braunschweig.de/rss/bekanntmachungen.php?sp%3Aout=rss"
                                                title: "BS Veranstaltungen",
                                                url: "https://www.braunschweig.de/rss/blickpunkte.php?sp%3Aout=rss"
                                                title: "FAZ",
                                                url: "https://www.faz.net/rss/aktuell/"
                                showSourceTitle: true,
                                showPublishDate: true,
                                broadcastNewsFeeds: true,
                                broadcastNewsUpdates: true,
                                updateInterval: 15000
]]></description><link>https://forum.magicmirror.builders/topic/15040/calendar-module-displayrepeatingcounttitle-doesn-t-show-peoples-age</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 11:29:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15040.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 May 2021 14:09:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to calendar module: "displayRepeatingCountTitle" doesn't show peoples age on Wed, 12 May 2021 16:37:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/91428">calendar module: "displayRepeatingCountTitle" doesn't show peoples age</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thefoster" aria-label="Profile: thefoster">@<bdi>thefoster</bdi></a> I’m just repeating what the code is expecting… I added the ’     years’  just to demonstrate a string as required.</p>
<p dir="auto">i didn’t get that requirement from the documentation</p>
<p dir="auto">I don’t know where the firstYear comes from… event is a manipulated object after parsing not just the text as shown in the ics.   this is yearly repeating  events only, so maybe firstYear comes from the start of the repeating event   (but if u make it oh, since feb of this year then the count will be wrong for anyone born before then …)</p>
<p dir="auto">but, if you don’t supply a template for the title string, you get nothing</p>
<p dir="auto">Thanks, indeed even the string " " (one blank) makes the year appear, without the need for “firstYear” in ICS.<br />
I think now i can switch to finish the MM hardware :)<br />
Again trhanks for the fast reply and solution :-D</p>
]]></description><link>https://forum.magicmirror.builders/post/91429</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91429</guid><dc:creator><![CDATA[thefoster]]></dc:creator><pubDate>Wed, 12 May 2021 16:37:47 GMT</pubDate></item><item><title><![CDATA[Reply to calendar module: "displayRepeatingCountTitle" doesn't show peoples age on Wed, 12 May 2021 16:31:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thefoster" aria-label="Profile: thefoster">@<bdi>thefoster</bdi></a> I’m just repeating what the code is expecting… I added the ’     years’  just to demonstrate a string as required.</p>
]]></description><link>https://forum.magicmirror.builders/post/91428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91428</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 May 2021 16:31:25 GMT</pubDate></item><item><title><![CDATA[Reply to calendar module: "displayRepeatingCountTitle" doesn't show peoples age on Wed, 12 May 2021 16:24:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/91426">calendar module: "displayRepeatingCountTitle" doesn't show peoples age</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thefoster" aria-label="Profile: thefoster">@<bdi>thefoster</bdi></a> said in <a href="/post/91422">calendar module: "displayRepeatingCountTitle" doesn't show peoples age</a>:</p>
<p dir="auto">displayRepeatingCountTitle</p>
<p dir="auto">thanks…  had never heard of this option before</p>
<p dir="auto">the CODE says</p>
<p dir="auto">get the value of the property  “repeatingCountTitle” from the block of config for this calendar url</p>
<pre><code>   displayRepeatingCountTitle: true,
           repeatingCountTitle: "   years",
<p dir="auto">I don’t need the string “years” and set  “displayRepeatingCountTitle: true,” like this (tried setting this in calendars and module as well).<br />
Or is a string “needed” to display the number?</p>
<p dir="auto">1and IF that string is NOT “” (the default) AND the event has a ‘firstYear’   attribute,<br />
THEN calculate and prepend the number to the string you provided…</p>
<p dir="auto">Uh, really?<br />
My ics does not contain that (‘firstYear’) attribute, just the common DTSTART (equals birthday date),DTEND ,RRULE etc., which is enough for my other software (e.g. KDE kontact) to calculate and display  the contacts ages in the calendar.<br />
This is how all entries in the ics file look like:</p>
<pre><code>BEGIN:VEVENT
DTSTAMP:20210511T194132Z
X-KDE-KABC-BIRTHDAY:YES
X-KDE-KABC-EMAIL-1:ttest@gmx.de
X-KDE-KABC-NAME-1:Terry Test
X-KDE-KABC-UID-1:3af4c44b-2086-489a-96a4-859e1fe1cdc1
CREATED:20201018T170728Z
UID:3af4c44b-2086-489a-96a4-859e1fe1cdc1_KABC_Birthday
LAST-MODIFIED:20210511T194132Z
SUMMARY:Terry Test
CATEGORIES:Geburtstag
RRULE:FREQ=YEARLY
DTSTART;VALUE=DATE:19720706
DTEND;VALUE=DATE:19720707
TRANSP:TRANSPARENT
END:VEVENT
<p dir="auto">as for MM loading cal from local file, it will but, the web server starts at MagicMirror, so the files have to be further down the tree… typically we use the module folder</p>
<pre><code>http://localhost:8080/modules/default/calendar/????.ics
<p dir="auto">I tried copying to/referencing from modules folder …<br />
Maybe i try that later to omit the extra server (although a caldav/carddav server is nice anyway)</p>
]]></description><link>https://forum.magicmirror.builders/post/91427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91427</guid><dc:creator><![CDATA[thefoster]]></dc:creator><pubDate>Wed, 12 May 2021 16:24:59 GMT</pubDate></item><item><title><![CDATA[Reply to calendar module: "displayRepeatingCountTitle" doesn't show peoples age on Wed, 12 May 2021 16:02:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thefoster" aria-label="Profile: thefoster">@<bdi>thefoster</bdi></a> said in <a href="/post/91422">calendar module: "displayRepeatingCountTitle" doesn't show peoples age</a>:</p>
<p dir="auto">and IF that string is NOT “” (the default) AND the event has a ‘firstYear’   attribute,<br />
]]></description><link>https://forum.magicmirror.builders/post/91426</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91426</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 May 2021 16:02:51 GMT</pubDate></item></channel></rss>
