<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After Update to 2.15, MM ist black.]]></title><description><![CDATA[<p dir="auto">Hey, I just updated my MagicMirror to V 2.15.<br />
Now I have a Black screen and the Terminal got me some errors:</p>
<p dir="auto">Maybe someone could give me a hint, or should I downgrade back t 2.14</p>
<p dir="auto">[28.05.2021 12:22.53.756] [LOG]   Loading module helpers …<br />
[28.05.2021 12:22.53.759] [LOG]   Initializing new module helper …<br />
[28.05.2021 12:22.53.761] [LOG]   Module helper loaded: updatenotification<br />
[28.05.2021 12:22.53.763] [LOG]   No helper found for module: clock.<br />
[28.05.2021 12:22.53.765] [LOG]   Initializing new module helper …<br />
[28.05.2021 12:22.53.767] [LOG]   Module helper loaded: MMM-DarkSkyForecast<br />
[28.05.2021 12:22.53.769] [LOG]   No helper found for module: MMM-Homematic.<br />
[28.05.2021 12:22.53.771] [LOG]   No helper found for module: MMM-EasyBack.<br />
[28.05.2021 12:22.53.776] [LOG]   Initializing new module helper …<br />
[28.05.2021 12:22.53.780] [LOG]   Module helper loaded: newsfeed<br />
[28.05.2021 12:22.53.790] [ERROR] App threw an error during load<br />
[28.05.2021 12:22.53.812] [ERROR] Error: Cannot find module ‘valid-url’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js</li>
<li>/home/pi/MagicMirror/js/app.js</li>
<li>/home/pi/MagicMirror/js/electron.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
<li>at Module._resolveFilename (internal/modules/cjs/loader.js:798:15)<br />
at Function…/lib/common/reset-search-paths.ts.Module._resolveFilename (electron/js2c/browser_init.js:7718:16)<br />
at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)<br />
at Module._load (internal/modules/cjs/loader.js:691:27)<br />
at Function.Module._load (electron/js2c/asar.js:748:26)<br />
at Module.require (internal/modules/cjs/loader.js:853:19)<br />
at require (internal/modules/cjs/helpers.js:74:18)<br />
at Object. (/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js:3:18)<br />
at Module._compile (internal/modules/cjs/loader.js:968:30)<br />
at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10)<br />
[28.05.2021 12:22.53.822] [ERROR] Whoops! There was an uncaught exception…<br />
[28.05.2021 12:22.53.835] [ERROR] Error: Cannot find module ‘valid-url’<br />
Require stack:</li>
at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10) {<br />
code: ‘MODULE_NOT_FOUND’,<br />
requireStack: [<br />
‘/home/pi/MagicMirror/modules/MMM-CalendarExt2/node_helper.js’,<br />
‘/home/pi/MagicMirror/js/app.js’,<br />
‘/home/pi/MagicMirror/js/electron.js’,<br />
‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,<br />
undefined<br />
]<br />
}<br />
[28.05.2021 12:22.53.845] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
[28.05.2021 12:22.53.848] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a><br />
[28.05.2021 12:22.54.416] [LOG]   Launching application.<br />
[28.05.2021 12:22.54.496] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”.  It will change to be “true” in Electron 9.  For more information please check <a href="https://github.com/electron/electron/issues/18397" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/electron/electron/issues/18397</a></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/15083/after-update-to-2-15-mm-ist-black</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 12:34:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15083.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 May 2021 10:26:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After Update to 2.15, MM ist black. on Fri, 28 May 2021 11:45:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thebassfly" aria-label="Profile: thebassfly">@<bdi>thebassfly</bdi></a> said in <a href="/post/91764">After Update to 2.15, MM ist black.</a>:</p>
<p dir="auto">Cannot find module ‘valid-url’</p>
<p dir="auto">this library was removed from mm in 2.15 because of security risks.</p>
<p dir="auto">some module u are using is using it, but did not declare it in their package.json file dependencies section</p>
<p dir="auto">do</p>
<p dir="auto">cd MagicMirror<br />
npm install valid-url</p>
]]></description><link>https://forum.magicmirror.builders/post/91766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91766</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 28 May 2021 11:45:05 GMT</pubDate></item></channel></rss>
