<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Code a MagicMirror by myself?]]></title><description><![CDATA[<p dir="auto">Hello there!</p>
<p dir="auto">Small details on my person… I’m a software development trainee from germany and we have, due to covid, a project with a PI4.<br />
I instantly thought about a MagicMirror.</p>
<p dir="auto">How should I start? Which language can I use and so on…<br />
Or are there any instructions on how to go along with it?</p>
<p dir="auto">I’m glad about every little help. :) Thanks for reading</p>
]]></description><link>https://forum.magicmirror.builders/topic/15091/code-a-magicmirror-by-myself</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 22:51:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15091.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 May 2021 13:51:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Code a MagicMirror by myself? on Wed, 02 Jun 2021 08:56:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for your answer! I will look behind the documents and try my best to get something going. ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/91848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91848</guid><dc:creator><![CDATA[oddo]]></dc:creator><pubDate>Wed, 02 Jun 2021 08:56:47 GMT</pubDate></item><item><title><![CDATA[Reply to Code a MagicMirror by myself? on Mon, 31 May 2021 14:00:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oddo" aria-label="Profile: oddo">@<bdi>oddo</bdi></a> MagicMirror is written in Javascript, and uses loadable extensions (modules) to display small fragments of content (lots of modules, produces lots of content)</p>
<p dir="auto">each module is essentially an application, focused on the content IT provides.  without knowledge of any other module</p>
<p dir="auto">the documentation on creating a module is here<br />
<a href="https://docs.magicmirror.builders/development/introduction.html#general-advice" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/development/introduction.html#general-advice</a></p>
<p dir="auto">and u can use my sample to start<br />
<a href="https://github.com/sdetweil/SampleModule" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/SampleModule</a></p>
<p dir="auto">read the links in my signature below on how to install a module and making a good config file</p>
<p dir="auto">also see my installation and maintenance scripts for MM<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/91834</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91834</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 31 May 2021 14:00:44 GMT</pubDate></item></channel></rss>
