<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[For My Nightstand]]></title><description><![CDATA[<p dir="auto">Took a little tweaking but here is 7" monitor and Pi in a combo case/stand. Should work well.<img src="/assets/uploads/files/1623030434746-bedside-time-and-weather1.jpg" alt="Bedside Time and Weather1.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/15108/for-my-nightstand</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 14:23:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15108.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Jun 2021 01:47:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to For My Nightstand on Sun, 13 Jun 2021 20:52:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doppelganger" aria-label="Profile: doppelganger">@<bdi>doppelganger</bdi></a> It isn’t really that bad.<br />
Unfortunately that was an early Fathers Day gift and now at fathers, so I can’t show the exact configuration .</p>
<p dir="auto">But for instance, the below gives you shadows and radiused corners. I just copied from the CSS on <a class="plugin-mentions-user plugin-mentions-a" href="/user/piranha1605" aria-label="Profile: Piranha1605">@<bdi>Piranha1605</bdi></a> Black Boxes example and dropped it in my custom.css file.<br />
Just delete modules you don’t have, add ones you do have.<br />
For me that meant deleting newsfeed, compliments and both the weatherforecast and currentweather since the weather module takes place of current and forecast.</p>
<p dir="auto">/**</p>
<ul>
<li>module.color_border_shadow<br />
*/<br />
.module.clock,<br />
.module.calendar,<br />
.module.newsfeed,<br />
.module.weatherforecast,<br />
.module.currentweather,<br />
.module.compliments {<br />
padding:8px;<br />
border-radius: 10px;<br />
box-shadow: 0 2em 6em #000;<br />
background: transparent;<br />
}</li>
</ul>
<p dir="auto">So mine is:<br />
module.clock<br />
module.calendar<br />
module.weather<br />
module.MMM-SmartWebDisplay {<br />
padding:8px;<br />
border-radius: 15px;<br />
}</p>
<p dir="auto">The iFrame was a roll of dice on my part but it worked with no problems</p>
<p dir="auto">I increased border-radius:  to 15px (I think) but may be 12px and got more of a radius than in the original example.</p>
<p dir="auto">I copy/pasted his header from the #3 example neomorphism to get the headers on the weather and calendar to get shadowed look. Clock has no header so no effect.</p>
]]></description><link>https://forum.magicmirror.builders/post/92113</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92113</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Sun, 13 Jun 2021 20:52:32 GMT</pubDate></item><item><title><![CDATA[Reply to For My Nightstand on Sun, 13 Jun 2021 18:50:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> , “Biggest challenge was having to adjust font sizes, padding, height x width…” That’s the reason I gave up on the 7" screen till I learned more.  I just finished a 24" MM. Even so, I just pulled the 7" raspi screen outta storage and will see what I can learn. Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/92108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92108</guid><dc:creator><![CDATA[doppelganger]]></dc:creator><pubDate>Sun, 13 Jun 2021 18:50:13 GMT</pubDate></item><item><title><![CDATA[Reply to For My Nightstand on Sun, 13 Jun 2021 17:42:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doppelganger" aria-label="Profile: doppelganger">@<bdi>doppelganger</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/doppelganger" aria-label="Profile: doppelganger">@<bdi>doppelganger</bdi></a> I copy/pasted several CSS items courtesy of <a class="plugin-mentions-user plugin-mentions-a" href="/user/piranha1605" aria-label="Profile: Piranha1605">@<bdi>Piranha1605</bdi></a> in the Custom CSS Showcase<br />
Located in Custom CSS here–&gt;  css-experiments-for-newbies<br />
Modules are default weather and clock modules.  Radar is an  iFrame module, MMM-SmartWebDisplay courtesy <a class="plugin-mentions-user plugin-mentions-a" href="/user/agp42" aria-label="Profile: AgP42">@<bdi>AgP42</bdi></a><br />
Deleted a bunch of the preloaded modules in  a fresh MM2 install as it is a jumbled up mess with stuff piled on top of each other with default sizes that won’t work on 7" Pi screen.<br />
After doing what amounted to copy/paste of sections of CSS in either dark or light theme ( don’t recall which but they are approx. same other than color) then started swapping out color codes  to see what was appealing to me.  Pulling up a hex color picker site will provide hex codes to experiment with.<br />
Biggest challenge was having to adjust font sizes, padding, height x width of iFrame primarily to get everything to fit.<br />
Some folks not a fan of VNC that comes with Pi OS but I find it invaluable when  working on GUI stuff like this.</p>
]]></description><link>https://forum.magicmirror.builders/post/92106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92106</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Sun, 13 Jun 2021 17:42:17 GMT</pubDate></item><item><title><![CDATA[Reply to For My Nightstand on Sun, 13 Jun 2021 16:03:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> , What modules are you using, especially to get the time/temp/ calendar to pop/highlight like that? Now that I see your MM, I’m thinking I’ll put another together on the spare 7" display I’ve got.</p>
]]></description><link>https://forum.magicmirror.builders/post/92104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92104</guid><dc:creator><![CDATA[doppelganger]]></dc:creator><pubDate>Sun, 13 Jun 2021 16:03:32 GMT</pubDate></item></channel></rss>
