<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alexa]]></title><description><![CDATA[<p dir="auto">I tried to set up this module for a while and just keep running from one problem to another. I managed to get the authority token and everything properly installed butwhen i go to run the mirror this message comes up:<br />
/home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v11.3-linux-ia32/snowboy.node: undefined symbol: <em>ZN7snowboy13SnowboyDetectC1ERKSsS2</em></p>
<p dir="auto">I am following this guide to install it: <a href="https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.howtogeek.com/423233/how-to-add-alexa-to-your-smart-mirror/</a> and i already tried reinstalling snowboy multiple times which didnt fix the problem. Any help would be appreciated```</p>
]]></description><link>https://forum.magicmirror.builders/topic/15119/alexa</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 18:34:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15119.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Jun 2021 18:34:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alexa on Mon, 14 Nov 2022 21:53:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/antoniop" aria-label="Profile: antoniop">@<bdi>antoniop</bdi></a> use my script which does the install steps from the wiki , plus a couple fixes</p>
<p dir="auto"><a href="https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0</a></p>
<p dir="auto">also see this<br />
<a href="https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working">https://forum.magicmirror.builders/topic/16069/alexa-implementations-now-more-difficult-and-some-features-will-stop-working</a></p>
]]></description><link>https://forum.magicmirror.builders/post/105805</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105805</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 14 Nov 2022 21:53:02 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa on Mon, 14 Nov 2022 21:50:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’m trying to install AwesomeAlexa but the</p>
<pre><code>npm install --only=prod
<p dir="auto">command is giving me an error about ‘snowboy’ . It looks like there is not a file at <a href="https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v93-darwin-x64.tar.gz" target="_blank" rel="noopener noreferrer nofollow ugc">https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v93-darwin-x64.tar.gz</a></p>
<p dir="auto">Did you face a similar problem?<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/105803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/105803</guid><dc:creator><![CDATA[antoniop]]></dc:creator><pubDate>Mon, 14 Nov 2022 21:50:33 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa on Tue, 15 Jun 2021 23:53:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pipifatz" aria-label="Profile: pipifatz">@<bdi>pipifatz</bdi></a> what is the error?</p>
]]></description><link>https://forum.magicmirror.builders/post/92164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92164</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 15 Jun 2021 23:53:11 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa on Tue, 15 Jun 2021 23:01:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for the script but now its throwing a different error sadly but i will keep trying</p>
]]></description><link>https://forum.magicmirror.builders/post/92163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92163</guid><dc:creator><![CDATA[pipifatz]]></dc:creator><pubDate>Tue, 15 Jun 2021 23:01:22 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa on Wed, 09 Jun 2021 19:32:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scumbelly" aria-label="Profile: scumbelly">@<bdi>scumbelly</bdi></a> I have it too. works great</p>
]]></description><link>https://forum.magicmirror.builders/post/92039</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92039</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Jun 2021 19:32:45 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa on Wed, 09 Jun 2021 19:19:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pipifatz" aria-label="Profile: pipifatz">@<bdi>pipifatz</bdi></a></p>
<p dir="auto">I just installed AlexaControl using an Echo Dot 4 with no problems.</p>
<p dir="auto">Hope it can work the same for you.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/92038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92038</guid><dc:creator><![CDATA[scumbelly]]></dc:creator><pubDate>Wed, 09 Jun 2021 19:19:27 GMT</pubDate></item><item><title><![CDATA[Reply to Alexa on Wed, 09 Jun 2021 18:49:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pipifatz" aria-label="Profile: pipifatz">@<bdi>pipifatz</bdi></a> which alexa… Only one I know that works is AwesomeAlexa</p>
<p dir="auto">they have a 14 step install process, I made a script out of it<br />
use this link to download<br />
<p dir="auto">make executable</p>
<p dir="auto">does the entire process, git clone on …<br />
ignore the errors… last step is the only important one</p>
<p dir="auto">I didn’t write the the steps, I just made the script  from the steps in<br />
<a href="https://awesome-alexa.js.org/#/installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://awesome-alexa.js.org/#/installation</a></p>
]]></description><link>https://forum.magicmirror.builders/post/92037</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92037</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Jun 2021 18:49:58 GMT</pubDate></item></channel></rss>
