<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Setting Default Code Editor]]></title><description><![CDATA[<p dir="auto">Is there a way to set the default code editor in Pi OS? A couple come pre-loaded and I use VS Code. I’d like to set that so it isn’t multiple choice each time.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15141/setting-default-code-editor</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 20:47:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15141.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Jun 2021 12:00:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Setting Default Code Editor on Wed, 16 Jun 2021 12:36:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> <a href="https://www.raspberrypi.org/forums/viewtopic.php?t=254208" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/forums/viewtopic.php?t=254208</a></p>
]]></description><link>https://forum.magicmirror.builders/post/92179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92179</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 16 Jun 2021 12:36:33 GMT</pubDate></item></channel></rss>
