<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-CalendarExt2 showing daily in columns]]></title><description><![CDATA[<p dir="auto">I’ve had a good look round and a play with the different views.<br />
I’m really wanting a daily  view where each day is a column of information, very much like the example for MMM-CalendarExt.<br />
When I use the daily view for MMM-CalendarExt2 it stacks the days on top of each other, see image.<br />
<img src="https://i.ibb.co/h70cvF6/Screenshot-2021-06-16-at-13-54-24.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">How can I get them to be next to each other?</p>
]]></description><link>https://forum.magicmirror.builders/topic/15142/mmm-calendarext2-showing-daily-in-columns</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 21:25:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15142.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Jun 2021 13:13:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-CalendarExt2 showing daily in columns on Wed, 23 Jun 2021 18:43:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris_d" aria-label="Profile: chris_d">@<bdi>chris_d</bdi></a> Sometimes little bugs like that happen. Usually, it just takes a refresh to fix.</p>
<p dir="auto">Glad to see it’s working.</p>
]]></description><link>https://forum.magicmirror.builders/post/92301</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92301</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Wed, 23 Jun 2021 18:43:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 showing daily in columns on Wed, 23 Jun 2021 06:59:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris_d" aria-label="Profile: chris_d">@<bdi>chris_d</bdi></a> And just to report that todays “shuffle” has resolved the issue.<br />
No idea what was going on there, possibly some caching. but I now have things working great. Thanks all.</p>
]]></description><link>https://forum.magicmirror.builders/post/92294</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92294</guid><dc:creator><![CDATA[chris_d]]></dc:creator><pubDate>Wed, 23 Jun 2021 06:59:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 showing daily in columns on Tue, 22 Jun 2021 06:59:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ellings3n" aria-label="Profile: ellings3n">@<bdi>ellings3n</bdi></a> said in <a href="/post/92271">MMM-CalendarExt2 showing daily in columns</a>:</p>
<p dir="auto">then you:</p>
<p dir="auto">Thanks.<br />
In an interesting development today the “today” section now has content but the “Saturday” content is blank, so it’s something to do with the number of columns.  Will plug away at it and see if I can sort it.<br />
If I add a slotCount: “6”, I get the 6th column, but the 5th is still blank.<br />
Most strange…</p>
]]></description><link>https://forum.magicmirror.builders/post/92276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92276</guid><dc:creator><![CDATA[chris_d]]></dc:creator><pubDate>Tue, 22 Jun 2021 06:59:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 showing daily in columns on Mon, 21 Jun 2021 16:27:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris_d" aria-label="Profile: chris_d">@<bdi>chris_d</bdi></a></p>
<p dir="auto">Good to see that everything worked out in the end! :)</p>
<p dir="auto">Regards your new problem, I’m as clueless as you :(<br />
I use the same view (with no issues) so I’ll post my config in case I have something different settings then you:</p>
<pre><code>name: "Oversikt",
mode: "daily",
type: "row",
position: "bottom_bar",
slotCount: "5",
locale: "en",
hideOverflow: false,
filterPassedEvent: true,
calendars: ["Aktiviteter","Mat"],
<ul>
<li>Ellings3n</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/92271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92271</guid><dc:creator><![CDATA[Ellings3n]]></dc:creator><pubDate>Mon, 21 Jun 2021 16:27:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 showing daily in columns on Mon, 21 Jun 2021 10:38:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ellings3n" aria-label="Profile: ellings3n">@<bdi>ellings3n</bdi></a> said in <a href="/post/92185">MMM-CalendarExt2 showing daily in columns</a>:</p>
<p dir="auto">type: “row”,</p>
<p dir="auto">Greetings indeed :-)<br />
That has worked great thank you.<br />
I had some formatting issues, but I was trying to constrain it into the wrong region, now fixed.!</p>
<p dir="auto">I’ve run into another issue, in that it’s stopped displaying events “today”<br />
In the example screenshot here, there should be three events. The calendars are displaying events on other days.<br />
<img src="https://i.ibb.co/tYgKBk5/Screenshot-2021-06-21-at-11-23-42.png" alt="alt text" class=" img-fluid img-markdown" /><br />
Any ideas why “today” is not displaying?</p>
]]></description><link>https://forum.magicmirror.builders/post/92269</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92269</guid><dc:creator><![CDATA[chris_d]]></dc:creator><pubDate>Mon, 21 Jun 2021 10:38:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 showing daily in columns on Thu, 17 Jun 2021 08:03:09 GMT]]></title><description><![CDATA[<p dir="auto">Greetings :)</p>
<p dir="auto">New to Magicmirror but I found some example code in the author’s module folder that did the job for me at least.<br />
Link: <a href="https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/master/docs/examples/klaernie.md" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-CalendarExt2</a></p>
<p dir="auto">If you scroll down on the page, you will find the code for config and css changes.</p>
<p dir="auto">In theory the following lines to daily view config should fix it for you I guess(did for me):</p>
<pre><code>type: "row",
slotCount: "5",
]]></description><link>https://forum.magicmirror.builders/post/92185</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92185</guid><dc:creator><![CDATA[Ellings3n]]></dc:creator><pubDate>Thu, 17 Jun 2021 08:03:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-CalendarExt2 showing daily in columns on Wed, 16 Jun 2021 19:25:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris_d" aria-label="Profile: chris_d">@<bdi>chris_d</bdi></a> This module is on life support. The author abandoned MagicMirror - however, as I maintain one of his projects, I have a bit of insight into how he does things - the control over how things are displayed is almost 100% CSS.</p>
<p dir="auto">Look into the module’s css file for clues.</p>
<p dir="auto">Hopefully, we can get someone who is good with CSS to help you.</p>
]]></description><link>https://forum.magicmirror.builders/post/92181</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92181</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Wed, 16 Jun 2021 19:25:45 GMT</pubDate></item></channel></rss>
