<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Camera intigration in your Mirror]]></title><description><![CDATA[<p dir="auto">Hey everyone, I use the facerecognition module from paviro to switch between different userprofiles. The softwarepart is ready. Now I would like to build a large bathroom-mirror, preferably wihtout any visible frame.</p>
<ol>
<li>How do you integrate/hide your camera in the frame (if you use one)?</li>
<li>Work the camera behind the mirror glas?</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/topic/1516/camera-intigration-in-your-mirror</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 02:01:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1516.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Jan 2017 10:05:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 31 Jan 2017 12:50:42 GMT]]></title><description><![CDATA[<p dir="auto">Ok, sounds interesting. Can the Face-Recognitiontool and the MMAL-Motion share the camera? If I try to use the Camera with “raspistill” while the Face-Recog-Module is enable, I get an Error.</p>
]]></description><link>https://forum.magicmirror.builders/post/13145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13145</guid><dc:creator><![CDATA[reaper81]]></dc:creator><pubDate>Tue, 31 Jan 2017 12:50:42 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Mon, 30 Jan 2017 14:38:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reaper81" aria-label="Profile: reaper81">@<bdi>reaper81</bdi></a></p>
<p dir="auto">No, the IR-Spot is completely at another place. This spot is mounted  under the room cover above the mirror.</p>
<p dir="auto">I use the cam SW to recognize any motion in the front of the mirror named MOTION-MMAL</p>
<p dir="auto">Take a look for example at</p>
<p dir="auto"><a href="https://embeddedday.com/projects/raspberry-pi/a-step-further/install-motion-mmal/" target="_blank" rel="noopener noreferrer nofollow ugc">https://embeddedday.com/projects/raspberry-pi/a-step-further/install-motion-mmal/</a></p>
<p dir="auto">In the config file you can define how the SW has to work and which commands are executed by the SW.</p>
<p dir="auto">Se also here in this Forum</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/988/motion-detection-with-raspicam-non-module-version/">https://forum.magicmirror.builders/topic/988/motion-detection-with-raspicam-non-module-version/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/13020</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13020</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Mon, 30 Jan 2017 14:38:46 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Mon, 30 Jan 2017 13:52:18 GMT]]></title><description><![CDATA[<p dir="auto">Where do you hide the IR-LEDs? In the Frame? Is there a special Module to use the Camera to disable the mirror or do you just disable all modules, if no face is recognized?</p>
]]></description><link>https://forum.magicmirror.builders/post/13017</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13017</guid><dc:creator><![CDATA[reaper81]]></dc:creator><pubDate>Mon, 30 Jan 2017 13:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Mon, 30 Jan 2017 12:23:00 GMT]]></title><description><![CDATA[<p dir="auto">Hello.</p>
<p dir="auto">My fist step was mounting the IR together with the cam behind the mirror.<br />
Was a  disaster. From that point as the IR is starting, no really good picture was available.</p>
<p dir="auto">After that i mounted the cam without IR and the IR extra outside from the Mirror.</p>
<p dir="auto">The cam is not visible. The IR has his own power supply.<br />
The mirror is enabled and disabled by the cam.</p>
<p dir="auto">The blue/white cable is soldered on a switch (Taster) to be capable to make soft reset to the raspi mirror or to shutdown the raspi mirror. You can set the option in a python script.</p>
<p dir="auto">I planed to install one other switch for a hard reset. I have recognized this switch will also enable the mirror after a shutdown an i didn’t must pull the Raspberry power supply.</p>
<p dir="auto">The red/white one is also a switch (Taster) to enable the "Tagesschau in 100 sek.) with the MMM-Button and the MMM-Podcast modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/13004</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13004</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Mon, 30 Jan 2017 12:23:00 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Mon, 30 Jan 2017 11:47:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> Thanks also from my side. Is the IR-LED-board wired with the camera board? I see no wires for IR-powersupply to the Raspi in your picture. How do you enable/disable your mirror?<br />
Are the camera and the IR-LEDs visible from the other side, through the mirros. And last but not least: What’s the function of the red-white and the blue-white cable?</p>
]]></description><link>https://forum.magicmirror.builders/post/13000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13000</guid><dc:creator><![CDATA[reaper81]]></dc:creator><pubDate>Mon, 30 Jan 2017 11:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 20:29:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svensommer" aria-label="Profile: SvenSommer">@<bdi>SvenSommer</bdi></a></p>
<p dir="auto"><a href="http://www.ebay.de/sch/sis.html?_nkw=Neu+Night+Vision+Infrared+LED+Board+F%C3%BCr+Rapsberry+Camera+Module+60+Array+3+Light&amp;_id=181557695080&amp;&amp;_trksid=p2057872.m2749.l265" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.ebay.de/sch/sis.html?_nkw=Neu+Night+Vision+Infrared+LED+Board+Für+Rapsberry+Camera+Module+60+Array+3+Light&amp;_id=181557695080&amp;&amp;_trksid=p2057872.m2749.l265</a></p>
<p dir="auto"><img src="/uploads/files/1485289768538-ir-light.jpg" alt="0_1485289766418_IR-Light.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/12368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12368</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Jan 2017 20:29:34 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 20:24:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> ah okay thats V1 so :) Thank you :)</p>
]]></description><link>https://forum.magicmirror.builders/post/12367</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12367</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Tue, 24 Jan 2017 20:24:34 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 20:22:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a></p>
<p dir="auto"><a href="https://www.conrad.de/de/raspberry-pi-kamera-gehaeusemodul-raspberry-pi-622959.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.conrad.de/de/raspberry-pi-kamera-gehaeusemodul-raspberry-pi-622959.html</a></p>
<p dir="auto">Full HD Video Auflösung mit 1080p<br />
Omnivision 5647 CMOS Bildsensor<br />
Maximale Framerate: 30 fps<br />
Integrierter IR-Filter<br />
5 Megapixel</p>
]]></description><link>https://forum.magicmirror.builders/post/12366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12366</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Jan 2017 20:22:33 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 20:21:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a><br />
I’m amazed by the quality of your picture with IR-Light.<br />
What kind of IR lamp are you using?</p>
<p dir="auto">I’m also using a raspi noir camera and integraded like 30 IR-Leds within the mirror to get a brighter picture.<br />
But always have problems with the face recognition. I assume it’s because the pictures used for comparing a black and white and for contrast reasons much darker.</p>
<p dir="auto"><img src="/uploads/files/1485288667186-capture_20161215_184130.jpg" alt="0_1485288663995_capture_20161215_184130.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/12365</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12365</guid><dc:creator><![CDATA[SvenSommer]]></dc:creator><pubDate>Tue, 24 Jan 2017 20:21:55 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 20:12:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> WOW! that is great thank you very much! That helps me immensely :D</p>
<p dir="auto">which camera version are you using? the Pi Noir v2? and which transmision has the mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/12363</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12363</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Tue, 24 Jan 2017 20:12:11 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 19:39:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/andrei20wks" aria-label="Profile: andrei20wks">@<bdi>andrei20wks</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/reaper81" aria-label="Profile: reaper81">@<bdi>reaper81</bdi></a></p>
<p dir="auto">and here some pictures from the Mirror it self.</p>
<p dir="auto"><img src="/uploads/files/1485286549793-img_0782-medium.jpg" alt="0_1485286539361_IMG_0782 (Medium).JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/uploads/files/1485286646404-img_0884-medium.jpg" alt="0_1485286642764_IMG_0884 (Medium).JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/uploads/files/1485286737774-img_0882-medium.jpg" alt="0_1485286735271_IMG_0882 (Medium).JPG" class=" img-fluid img-markdown" /><br />
<img src="/uploads/files/1485286782659-img_0883-medium.jpg" alt="0_1485286777590_IMG_0883 (Medium).JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/12359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12359</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Jan 2017 19:39:52 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 19:38:05 GMT]]></title><description><![CDATA[<p dir="auto">Cool, thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/12357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12357</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 24 Jan 2017 19:38:05 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 19:51:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/andrei20wks" aria-label="Profile: andrei20wks">@<bdi>andrei20wks</bdi></a> , <a class="plugin-mentions-user plugin-mentions-a" href="/user/reaper81" aria-label="Profile: reaper81">@<bdi>reaper81</bdi></a></p>
<p dir="auto">hey Guys, here the desired pictures.</p>
<p dir="auto">Sorry, i forgot to remove the ip.<br />
Here are the pics again.</p>
<p dir="auto">With normal LED spots<br />
<img src="/uploads/files/1485287395141-cam_pic_light.jpg" alt="0_1485287390831_CAM_PIC_Light.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">No Light and IR-Spot<br />
<img src="/uploads/files/1485287415059-cam_pic_no_ir.jpg" alt="0_1485287411094_CAM_PIC_NO_IR.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">With IR-Light<br />
<img src="/uploads/files/1485287430945-cam_pic_ir.jpg" alt="0_1485287428016_CAM_PIC_IR.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/12356</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12356</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Jan 2017 19:51:14 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 15:35:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> what about the v2 camera? the one with IR. does that work behind the mirror? have you tested it so far?</p>
]]></description><link>https://forum.magicmirror.builders/post/12322</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12322</guid><dc:creator><![CDATA[andrei20wks]]></dc:creator><pubDate>Tue, 24 Jan 2017 15:35:33 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 14:35:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a></p>
<p dir="auto">yes i do this how is said, lather when i’m back home.</p>
]]></description><link>https://forum.magicmirror.builders/post/12315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12315</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Jan 2017 14:35:55 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 14:23:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> I´m also interested to see the difference between the camera mounted in the frame or mounted behind the glass :) Is it possilbe to share some pics of the camera feed? :)</p>
]]></description><link>https://forum.magicmirror.builders/post/12312</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12312</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Tue, 24 Jan 2017 14:23:50 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 13:05:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a><br />
Yes, sure. It solve many of my task build on my mirror.</p>
<p dir="auto">security cam with IR_LED’s for night-view possibilities, Motion detection, enabling/disabling mirror, facial recognition -&gt; profile switcher.</p>
<p dir="auto">Maybe other options lather with other ideas from the community.</p>
]]></description><link>https://forum.magicmirror.builders/post/12305</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12305</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Jan 2017 13:05:23 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 12:49:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a><br />
So are you happy with your NoIR camera behind the mirror glass?<br />
I am still unsure if I should buy one or if I skip this. On the other hand I am tempted to do so and integrate it into my mirror design right at the beginning.</p>
]]></description><link>https://forum.magicmirror.builders/post/12304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12304</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 24 Jan 2017 12:49:15 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 12:01:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reaper81" aria-label="Profile: reaper81">@<bdi>reaper81</bdi></a></p>
<p dir="auto">I must search for some pictures at my phone or i send you new pictures lather in the evening!</p>
]]></description><link>https://forum.magicmirror.builders/post/12303</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12303</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Jan 2017 12:01:55 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 10:45:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lolobyte" aria-label="Profile: lolobyte">@<bdi>lolobyte</bdi></a> There are pictures of your frame (front and back)?</p>
]]></description><link>https://forum.magicmirror.builders/post/12298</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12298</guid><dc:creator><![CDATA[reaper81]]></dc:creator><pubDate>Tue, 24 Jan 2017 10:45:53 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 10:25:06 GMT]]></title><description><![CDATA[<p dir="auto">Yes pi noir works behind the glass.<br />
I’ts a bit darker but you can recognize the persons or other objects in the front of the mirror.</p>
<p dir="auto">My Mirror is on a wooden plate and i drilled a hole for the cam.</p>
]]></description><link>https://forum.magicmirror.builders/post/12297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12297</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Tue, 24 Jan 2017 10:25:06 GMT</pubDate></item><item><title><![CDATA[Reply to Camera intigration in your Mirror on Tue, 24 Jan 2017 10:07:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I did not test but some users report the NoIR camera works behind the mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/12296</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12296</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Tue, 24 Jan 2017 10:07:56 GMT</pubDate></item></channel></rss>
