<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[MMM-Remote-Control] Can not access remote control module]]></title><description><![CDATA[<p dir="auto">Hi,<br />
first of all, thank you for this module.<br />
I have whitelisted my iPs. But i get:</p>
<pre><code>Cannot GET /remote.html
]]></description><link>https://forum.magicmirror.builders/topic/1517/mmm-remote-control-can-not-access-remote-control-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 23:40:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1517.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Jan 2017 17:39:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 28 Feb 2024 16:13:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> said in <a href="/post/35167">[MMM-Remote-Control] Can not access remote control module</a>:</p>
<blockquote></blockquote>
<p dir="auto">Thank you so much, also from my side! I spent hours to look for the mistake and it was again the wrong written “address”</p>
]]></description><link>https://forum.magicmirror.builders/post/115975</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/115975</guid><dc:creator><![CDATA[Welle05]]></dc:creator><pubDate>Wed, 28 Feb 2024 16:13:06 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 23:10:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Isn’t  the default <code>localhost</code>?<br />
<a href="https://github.com/MichMich/MagicMirror#general" target="_blank" rel="noopener noreferrer nofollow ugc">General property option</a></p>
<p dir="auto">On my rpi I get the <code>::1</code> IPv6 address</p>
<pre><code>pi@raspberrypi ~ % getent hosts localhost
::1             localhost ip6-localhost ip6-loopback
pi@raspberrypi ~ %
<p dir="auto">Both IPv4 and IPv6 addresses are in my local <code>/etc/hosts</code> file:</p>
<pre><code>pi@raspberrypi ~ % grep localhost /etc/hosts
127.0.0.1       localhost
pi@raspberrypi ~ %
]]></description><link>https://forum.magicmirror.builders/post/65832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65832</guid><dc:creator><![CDATA[OldSunGuy]]></dc:creator><pubDate>Wed, 11 Dec 2019 23:10:33 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 21:07:34 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy hm …  the default according to the API used is 0.0.0.0 if not specified.</p>
<p dir="auto">The typo would make it not specified…</p>
]]></description><link>https://forum.magicmirror.builders/post/65825</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65825</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 21:07:34 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 21:01:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oldsunguy" aria-label="Profile: OldSunGuy">@<bdi>OldSunGuy</bdi></a> said in <a href="/post/65822">[MMM-Remote-Control] Can not access remote control module</a>:</p>
<p dir="auto">address: “0.0.0.0”,</p>
<p dir="auto">what a shit failure.</p>
<p dir="auto">THANKS VERY MUCH!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/65824</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65824</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 21:01:22 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:49:56 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy<br />
config.js has a typo</p>
<pre><code>adresss: “0.0.0.0”,
<p dir="auto">should be.</p>
<pre><code>address: “0.0.0.0”,
]]></description><link>https://forum.magicmirror.builders/post/65822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65822</guid><dc:creator><![CDATA[OldSunGuy]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:49:56 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:37:13 GMT]]></title><description><![CDATA[<p dir="auto">you mean this? 0.0.0.0 or?</p>
<p dir="auto"><img src="https://i.ibb.co/PW6TQSz/Code.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/65821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65821</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:37:13 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:30:47 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy ok. U have two interfaces.</p>
<p dir="auto">What is address: in config.js?</p>
]]></description><link>https://forum.magicmirror.builders/post/65820</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65820</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:30:47 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:28:36 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy said in <a href="/post/65813">[MMM-Remote-Control] Can not access remote control module</a>:</p>
<p dir="auto">ifconfig worked</p>
<p dir="auto"><img src="https://i.ibb.co/9wNFd5h/Code.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">that is “ifconfig”</p>
]]></description><link>https://forum.magicmirror.builders/post/65819</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65819</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:28:36 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:24:53 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy no screen above shows 2 times the command<br />
ipconfig</p>
<p dir="auto">I need you to use</p>
<p dir="auto">ifconfig</p>
<p dir="auto">Windows system uses ipconfig<br />
Linux does not</p>
]]></description><link>https://forum.magicmirror.builders/post/65818</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65818</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:24:53 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:17:23 GMT]]></title><description><![CDATA[<p dir="auto">thats the screen above :)</p>
]]></description><link>https://forum.magicmirror.builders/post/65817</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65817</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:17:23 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:14:53 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy please read and copy/paste</p>
<p dir="auto">sudo ifconfig</p>
<p dir="auto">U are typing iPconfig</p>
<p dir="auto">Not p</p>
]]></description><link>https://forum.magicmirror.builders/post/65816</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65816</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:14:53 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:11:19 GMT]]></title><description><![CDATA[<p dir="auto">dont work</p>
<p dir="auto"><img src="https://i.ibb.co/LzG7ww5/Code.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/65815</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65815</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:10:10 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy not ip, if</p>
]]></description><link>https://forum.magicmirror.builders/post/65814</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65814</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:10:10 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:01:55 GMT]]></title><description><![CDATA[<p dir="auto">ifconfig worked</p>
]]></description><link>https://forum.magicmirror.builders/post/65813</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65813</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:01:55 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 19:56:23 GMT]]></title><description><![CDATA[<p dir="auto">sudo ipconfig</p>
<p dir="auto">sudo: ipconfig: Command not found</p>
<p dir="auto">thats not good :/</p>
]]></description><link>https://forum.magicmirror.builders/post/65811</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65811</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:56:23 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 20:10:28 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy ok. Check the address of the pi</p>
]]></description><link>https://forum.magicmirror.builders/post/65809</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65809</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 20:10:28 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 19:51:50 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://i.ibb.co/Cm7b6hy/Code.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">same :/</p>
]]></description><link>https://forum.magicmirror.builders/post/65808</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65808</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:51:50 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 19:50:40 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy remove after the port.  Let’s make sure default works</p>
]]></description><link>https://forum.magicmirror.builders/post/65807</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65807</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:50:40 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 19:42:11 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://i.ibb.co/0D3Mqzj/Code.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/65806</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65806</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:42:11 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 19:39:14 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy said in <a href="/post/65804">[MMM-Remote-Control] Can not access remote control module</a>:</p>
<p dir="auto">192.168.178.40</p>
<p dir="auto">need the port too</p>
<p dir="auto"><a href="http://192.168.178.40:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.178.40:8080</a> (thats the default port)</p>
]]></description><link>https://forum.magicmirror.builders/post/65805</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65805</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:39:14 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 19:38:21 GMT]]></title><description><![CDATA[<p dir="auto">adress is set on 0.0.0.0<br />
and whitelist []</p>
<p dir="auto">on pi itself same from browser : 192.168.178.40 rejected the connection</p>
]]></description><link>https://forum.magicmirror.builders/post/65804</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65804</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:38:21 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 19:28:39 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy so, steps to debug</p>
<p dir="auto">from another system can u access the mirror itself<br />
<a href="http://ip" target="_blank" rel="noopener noreferrer nofollow ugc">http://ip</a>:port<br />
if no, then either firewall, or mirror config prevents.<br />
address: or whitelist or both</p>
<p dir="auto">if address is localhost, then ONLY apps on the SAME PHYSICAL system can access<br />
if address is 0.0.0.0, then apps can access from any network connection<br />
if address is something else, some specific ip, then apps can only access server thru the hardware adapter that provdes that address. think if u had two network cards, and wanted to restrict access to only one of those cards…</p>
<p dir="auto">now, once you’ve got that<br />
we go to whitelist<br />
now you can constrain access to specific systems on that netwokr, or groups of systems by address range (or applied mask)</p>
<p dir="auto">so, to start I’d do address: “0.0.0.0” and whitelist :[],<br />
means any system from any network</p>
<p dir="auto">can u access the mirror app</p>
<p dir="auto">now can u access the remotecontrol app insde the mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/65803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65803</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:28:39 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 19:00:19 GMT]]></title><description><![CDATA[<p dir="auto">changed something, now webpage shows: my connection has been rejected?</p>
]]></description><link>https://forum.magicmirror.builders/post/65802</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65802</guid><dc:creator><![CDATA[Mr.Gysy]]></dc:creator><pubDate>Wed, 11 Dec 2019 19:00:19 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-Remote-Control] Can not access remote control module on Wed, 11 Dec 2019 18:59:25 GMT]]></title><description><![CDATA[<p dir="auto">@Mr-Gysy sorry, unclear on error you are seeing</p>
]]></description><link>https://forum.magicmirror.builders/post/65801</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/65801</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 11 Dec 2019 18:59:25 GMT</pubDate></item></channel></rss>
