<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM & Home Assistant (HASS)]]></title><description><![CDATA[<p dir="auto">I am finalising my first MagicMirror and was adding the MMM-PIR-Sensor module and had an idea I thought I’d share as it works so well!</p>
<p dir="auto">I have HASS (<a href="https://www.home-assistant.io/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.home-assistant.io/</a>  ) so decided to use a microwave presence detector and add a ESPHome node (<a href="https://esphome.io/#" target="_blank" rel="noopener noreferrer nofollow ugc">https://esphome.io/#</a>  ) so added a D1 Mini ESPHome node. The output of the microwave sensor now goes to the D1 Mini, which then sends a logic signal to the MM. The ESPHome node also has a number of temperature monitors and a humidity monitor and also gives fine-grained control over things like quiet times etc.</p>
<p dir="auto">Not only does this give me yet more control of the PIR function of the mirror, it also allows me to use the sensor as part of my overall home presence detection, and force off times at night by programming the ESPHome node.</p>
<p dir="auto">For those running both, it is well worth having a look at combining them.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15218/mm-home-assistant-hass</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 16:51:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15218.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Jul 2021 09:19:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM & Home Assistant (HASS) on Tue, 31 Aug 2021 06:56:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> <a href="https://letyshops.com/r/aliexpress-ww-97c9f222e4cc" target="_blank" rel="noopener noreferrer nofollow ugc">https://letyshops.com/r/aliexpress-ww-97c9f222e4cc</a> I got it from this seller on AliExpress as I found it to be the cheapest</p>
]]></description><link>https://forum.magicmirror.builders/post/94112</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94112</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Tue, 31 Aug 2021 06:56:17 GMT</pubDate></item><item><title><![CDATA[Reply to MM & Home Assistant (HASS) on Tue, 31 Aug 2021 00:02:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ivanov_d" aria-label="Profile: ivanov_d">@<bdi>ivanov_d</bdi></a> due tell where did you find a zigbee human detector?   I’m VERY interested!</p>
]]></description><link>https://forum.magicmirror.builders/post/94105</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94105</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 31 Aug 2021 00:02:00 GMT</pubDate></item><item><title><![CDATA[Reply to MM & Home Assistant (HASS) on Mon, 30 Aug 2021 17:42:30 GMT]]></title><description><![CDATA[<p dir="auto">I had this set-up for quite a while now, but I have it configured a bit different. I have a ZigBee human body detector in the bathroom integrated with HA and based on the input I remotely control MM via HA automations.</p>
]]></description><link>https://forum.magicmirror.builders/post/94096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94096</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Mon, 30 Aug 2021 17:42:30 GMT</pubDate></item><item><title><![CDATA[Reply to MM & Home Assistant (HASS) on Thu, 15 Jul 2021 19:25:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/soubhik-khan" aria-label="Profile: soubhik-khan">@<bdi>soubhik-khan</bdi></a> Hi. With my face, I don’t do videos - and you can thank me for that!</p>
<p dir="auto">Seriously, start with ESPHome on HASS - get an ESPHome node working with a PIR or MW sensor and an LED output. Once you’ve got that working separately to MM, you are ready to connect the two.</p>
<p dir="auto">At that point, connect the LED output pin (the 3V3 login pin) to the MM GPIO pin and configure the PIR module on MM as normal.</p>
<p dir="auto">That’s it - they are now connected and you can programme HASS, the ESPHome node and MM as you need.</p>
<p dir="auto">Hope that helps.</p>
]]></description><link>https://forum.magicmirror.builders/post/92883</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92883</guid><dc:creator><![CDATA[RGN01]]></dc:creator><pubDate>Thu, 15 Jul 2021 19:25:16 GMT</pubDate></item><item><title><![CDATA[Reply to MM & Home Assistant (HASS) on Thu, 15 Jul 2021 05:35:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rgn01" aria-label="Profile: rgn01">@<bdi>rgn01</bdi></a> sounds exciting! I just got home assistant yesterday, still in the learning curve! Just wondering how to control the MM with home assistant. Currently I have a PIR sensor attached to the MM gpio which controls the display.<br />
Is it possible to make a short video demo of your project and share? I’m very interested to learn!</p>
]]></description><link>https://forum.magicmirror.builders/post/92865</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92865</guid><dc:creator><![CDATA[soubhik-khan]]></dc:creator><pubDate>Thu, 15 Jul 2021 05:35:44 GMT</pubDate></item><item><title><![CDATA[Reply to MM & Home Assistant (HASS) on Sun, 04 Jul 2021 11:41:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rgn01" aria-label="Profile: rgn01">@<bdi>rgn01</bdi></a> If anyone is interested I’ll share the ESPHome code.</p>
]]></description><link>https://forum.magicmirror.builders/post/92486</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92486</guid><dc:creator><![CDATA[RGN01]]></dc:creator><pubDate>Sun, 04 Jul 2021 11:41:16 GMT</pubDate></item></channel></rss>
