<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-awesome-alexa Error]]></title><description><![CDATA[<p dir="auto">Hey, I’m having problems with the Alexa installation.</p>
<p dir="auto">$ cd ~/MagicMirror/modules # Navigate to module folder<br />
$ git clone <a href="https://github.com/dolanmiu/MMM-awesome-alexa.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/dolanmiu/MMM-awesome-alexa.git</a> # Clone this repository<br />
$ cd MMM-awesome-alexa # go into the module directory<br />
$ npm install --only=prod # Install depdendencies<br />
$ cd node_modules<br />
$ rm -rf snowboy # Remove the installed snowboy<br />
$ git clone <a href="https://github.com/Kitt-AI/snowboy.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Kitt-AI/snowboy.git</a> # Manually get snowboy from git<br />
$ cd snowboy # Go into the /snowboy directory<br />
$ rm -rf node_modules<br />
$ npm install nan --save # Make sure you install this in the /snowboy directory<br />
$ npm install node-pre-gyp@0.12.0 --save # Make sure you install this in the /snowboy directory<br />
$ npm install # Make sure you install in the /snowboy directory<br />
$ npm run prepublish # Make sure you run this in the /snowboy directory<br />
$ npm install --save-dev electron-rebuild # Make sure you install this in the /snowboy directory<br />
<img src="/assets/uploads/files/1625942962055-bild_2021-07-10_204921.png" alt="Bild_2021-07-10_204921.png" class=" img-fluid img-markdown" /> $ npm install nan # Make sure you install this in the /snowboy directory<br />
$ ./node_modules/.bin/electron-rebuild # Build snowboy to your device specifications, in the /snowboy directory</p>
]]></description><link>https://forum.magicmirror.builders/topic/15247/mmm-awesome-alexa-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 03:41:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15247.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Jul 2021 18:51:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-awesome-alexa Error on Sat, 10 Jul 2021 19:53:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/massivearts-0" aria-label="Profile: massivearts-0">@<bdi>massivearts-0</bdi></a> wherever you want… doesn’t matter<br />
I make a folder called temp  to put temp things in</p>
]]></description><link>https://forum.magicmirror.builders/post/92704</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92704</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 10 Jul 2021 19:53:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa Error on Sat, 10 Jul 2021 19:40:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/92702">MMM-awesome-alexa Error</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/massivearts-0" aria-label="Profile: massivearts-0">@<bdi>massivearts-0</bdi></a> use my script to do all that , too many chances for copy/paste or retype errors</p>
<p dir="auto"><a href="https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0</a></p>
<p dir="auto">download, make executable and then run it…</p>
<p dir="auto">doesn’t matter where u download or execute, it does the whole thing…</p>
<p dir="auto">clones the module.  etc</p>
<p dir="auto">ignore the errors til the last line</p>
<p dir="auto">Where should I put this?</p>
]]></description><link>https://forum.magicmirror.builders/post/92703</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92703</guid><dc:creator><![CDATA[MassiveArts 0]]></dc:creator><pubDate>Sat, 10 Jul 2021 19:40:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-awesome-alexa Error on Sat, 10 Jul 2021 19:03:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/massivearts-0" aria-label="Profile: massivearts-0">@<bdi>massivearts-0</bdi></a> use my script to do all that , too many chances for copy/paste or retype errors</p>
]]></description><link>https://forum.magicmirror.builders/post/92702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92702</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 10 Jul 2021 19:03:42 GMT</pubDate></item></channel></rss>
