<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM Standby loop _ Unable to access raspberry]]></title><description><![CDATA[<p dir="auto">I’m in a bit of a pickle here.  I have my magic mirror programed to start automatically upon booting of the raspberry pi.  However something happened last night that I can’t explain or get around.</p>
<p dir="auto">When I boot the Pi (4) everything works as expected, but once the mirror starts up the monitors connection to hdmi is cut immediately and I have zero signal.  I have not found a way to get connection to the monitor to be able to troubleshoot.</p>
<p dir="auto">This is definitely a Pi issue, as I tried in a different monitor with the same issue .</p>
<p dir="auto">I am at a loss here.  I have no idea how this happened.   Please.  Any help?</p>
]]></description><link>https://forum.magicmirror.builders/topic/15262/mm-standby-loop-_-unable-to-access-raspberry</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 11:37:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15262.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Jul 2021 12:34:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Wed, 14 Jul 2021 12:32:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Deleting PIR from the config through the remote worked!</p>
<p dir="auto">Thank you Sam.</p>
]]></description><link>https://forum.magicmirror.builders/post/92848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92848</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 14 Jul 2021 12:32:18 GMT</pubDate></item><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Tue, 13 Jul 2021 19:35:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a><br />
Nothing truer has been said.  I’ll give it a go</p>
]]></description><link>https://forum.magicmirror.builders/post/92803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92803</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 13 Jul 2021 19:35:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Tue, 13 Jul 2021 19:18:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> things work reliably until they dont!<br />
if u can thru remote, just add disabled:true,<br />
after the pir module name line</p>
]]></description><link>https://forum.magicmirror.builders/post/92800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92800</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 13 Jul 2021 19:18:52 GMT</pubDate></item><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Tue, 13 Jul 2021 19:06:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Not sure how that happened out of nowhere.  I should delete the PIR module through ssh to see what’s going on then?</p>
<p dir="auto">Unless I can modify the config file through the remote app.  Not sure that’s safe though.</p>
<p dir="auto">N</p>
]]></description><link>https://forum.magicmirror.builders/post/92799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92799</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 13 Jul 2021 19:06:32 GMT</pubDate></item><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Tue, 13 Jul 2021 16:10:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> the pir module has turned off the hdmi port… (as if no motion, time to sleep)</p>
]]></description><link>https://forum.magicmirror.builders/post/92787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92787</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 13 Jul 2021 16:10:16 GMT</pubDate></item><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Tue, 13 Jul 2021 16:09:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/george" aria-label="Profile: george">@<bdi>george</bdi></a></p>
<p dir="auto">I believe the PIR is working fine.  Just not sure why the HDMI connection is immediately lost after the mirror has loaded.</p>
<p dir="auto">Wouldn’t disconnecting the PIR from the Pi correct this?</p>
]]></description><link>https://forum.magicmirror.builders/post/92785</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92785</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 13 Jul 2021 16:09:09 GMT</pubDate></item><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Tue, 13 Jul 2021 15:36:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> , If the PIR sensor does not work, the mirror does not work.</p>
]]></description><link>https://forum.magicmirror.builders/post/92778</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92778</guid><dc:creator><![CDATA[George]]></dc:creator><pubDate>Tue, 13 Jul 2021 15:36:43 GMT</pubDate></item><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Tue, 13 Jul 2021 14:20:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I hope that I have enabled SSH on the raspberry.  I think I had.<br />
I have yet to try accessing the pi yet from SSH, but fingers crossed.</p>
<p dir="auto">Yes. I am using PIR as a motion sensor. I have tried detaching the PIR with no luck.</p>
]]></description><link>https://forum.magicmirror.builders/post/92773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92773</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Tue, 13 Jul 2021 14:20:54 GMT</pubDate></item><item><title><![CDATA[Reply to MM Standby loop _ Unable to access raspberry on Tue, 13 Jul 2021 14:01:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: nneuland">@<bdi>nneuland</bdi></a> use ssh to connect to the pi so u can work on it.</p>
<p dir="auto">do you use pir for motion sense? turn off monitor?</p>
]]></description><link>https://forum.magicmirror.builders/post/92770</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/92770</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 13 Jul 2021 14:01:51 GMT</pubDate></item></channel></rss>
