<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PushBulletNotifications Module issues?]]></title><description><![CDATA[<p dir="auto">Okay, maybe I posted this in the wrong section last time, so I will try it here: I have tried several different things like checking my module, changing the API Token, but for some reason, I cannot get this module to display on my MagicMirror. All of my other modules are fine. I am wondering if I am missing something obvious (I have before). He is my config (Which I did not change from the ReadMe):</p>
<pre><code>{
		module: 'MMM-PushBulletNotifications',
		header: 'Notifications',
		position: 'top_left',	// This can be any of the regions.
			accessToken: "MyToken", //PushBullet API Access Token
			endToEndPassword: null,
			numberOfNotifications: 3,
			filterTargetDeviceName: "",
			showPushesSentToAllDevices: true,
			onlyAllowCommandsFromSourceDevices: [],
			fetchLimitPushBullet: 50,
			showPushes: true,
			showPushesOnLoad: true,
			showDismissedPushes: true,
			showMirroredNotifications: true,
			onlyShowLastNotificationFromApplication: false,
			showIndividualNotifications: false,
			showSMS: true,
			showMessage: true,
			showIcons: true,
			showDateTime: true,
			localesDateTime: 'nl-NL',
			playSoundOnNotificationReceived: true,
			soundFile: 'modules/MMM-PushBulletNotifications/sounds/new-message.mp3',
			maxMsgCharacters: 50,
			maxHeaderCharacters: 32,
			showModuleIfNoNotifications: true,
			noNotificationsMessage: "No new notifications",
			debugMode: false,
<p dir="auto">Any help will be appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15356/pushbulletnotifications-module-issues</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 18:14:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15356.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Aug 2021 09:19:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PushBulletNotifications Module issues? on Mon, 09 Aug 2021 01:19:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks, but of course, I have complicated the issue now.  I discovered that I needed to upgrade my MagicMirror.  Of course, now that I have done that, it is not displaying at all.  I am looking at a previous thread about this in which you helped someone else with that issue and trying to fix this.</p>
<p dir="auto">Thanks again…I could be posting another thread on working through that issue!  Ha.</p>
]]></description><link>https://forum.magicmirror.builders/post/93463</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93463</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Mon, 09 Aug 2021 01:19:23 GMT</pubDate></item><item><title><![CDATA[Reply to PushBulletNotifications Module issues? on Sun, 08 Aug 2021 22:12:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> said in <a href="/post/93454">PushBulletNotifications Module issues?</a>:</p>
<p dir="auto">PushBulletNotifications//MMM-PushbulletNotifications.js</p>
<p dir="auto">the filename must match the folder name which must match the name inside the filename and must match the module name</p>
<p dir="auto">exact case.</p>
<p dir="auto">above the filename has a lowercase b , but the folder has uppercase</p>
]]></description><link>https://forum.magicmirror.builders/post/93457</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93457</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 08 Aug 2021 22:12:19 GMT</pubDate></item><item><title><![CDATA[Reply to PushBulletNotifications Module issues? on Sun, 08 Aug 2021 21:57:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I think I was able to look at the developers window tab.  I see two errors:</p>
<ol>
<li>
<p dir="auto">“Failed to load resource…server responded with a status of 404 (Not Found)”</p>
</li>
<li>
<p dir="auto">“Error on loading script:…PushBulletNotifications//MMM-PushbulletNotifications.js”</p>
</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/93454</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93454</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Sun, 08 Aug 2021 21:57:52 GMT</pubDate></item><item><title><![CDATA[Reply to PushBulletNotifications Module issues? on Sun, 08 Aug 2021 21:46:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ah, I see.  I am not familiar with the developers window, so I am looking into that now.</p>
]]></description><link>https://forum.magicmirror.builders/post/93453</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93453</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Sun, 08 Aug 2021 21:46:27 GMT</pubDate></item><item><title><![CDATA[Reply to PushBulletNotifications Module issues? on Sun, 08 Aug 2021 19:36:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> debug is so you might be able to analyze the debug info to determine the problem<br />
note that you have to open the developers window console tab to see the debug info</p>
<p dir="auto">do you see the header?</p>
]]></description><link>https://forum.magicmirror.builders/post/93441</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93441</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 08 Aug 2021 19:36:35 GMT</pubDate></item><item><title><![CDATA[Reply to PushBulletNotifications Module issues? on Sun, 08 Aug 2021 19:27:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks…I have changed the debugMode to true, but that didnt do the trick…any other suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/post/93440</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93440</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Sun, 08 Aug 2021 19:27:48 GMT</pubDate></item><item><title><![CDATA[Reply to PushBulletNotifications Module issues? on Sun, 08 Aug 2021 11:37:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> do u see the header?</p>
<p dir="auto">change debugMode to true</p>
]]></description><link>https://forum.magicmirror.builders/post/93432</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93432</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 08 Aug 2021 11:37:07 GMT</pubDate></item></channel></rss>
