<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screencast not showing up on the phone]]></title><description><![CDATA[<p dir="auto">Re: [Screencast not showing up on the phone</p>
<p dir="auto">Hi,<br />
I downloaded the screencast module and its in my module folder. I also added the script to the config/config.js. However when I run my magic mirror there is no option for me to cast to the mirror when I go into youtube. like I might have made a mistake with the configeration part i added to the modules array but it seems to be correct. If anyone could give me some pointers that would be great.<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/15360/screencast-not-showing-up-on-the-phone</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 00:52:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15360.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Aug 2021 21:38:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Screencast not showing up on the phone on Sun, 15 Aug 2021 14:27:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delta-1" aria-label="Profile: delta-1">@<bdi>delta-1</bdi></a> I had similar issue and was the IPAddress and Whitelist setup that was blocking me. Search for those terms, or add your IP explicitly in whitelist and set IPAddress to “0.0.0.0” to test it.</p>
<p dir="auto">I don’t have access to file now as I built for daughter and it’s at hers.<br />
Cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/93708</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93708</guid><dc:creator><![CDATA[jimbydude]]></dc:creator><pubDate>Sun, 15 Aug 2021 14:27:06 GMT</pubDate></item></channel></rss>
