<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM Not Displaying after update]]></title><description><![CDATA[<p dir="auto">Hello, I attempted to update my MagicMirror today via a git pull, and ever since then, my MM will not display.  Here is the Log:</p>
<pre><code>pi@raspberrypi:~ $ cd MagicMirror
magicmirror@2.16.0 start /home/pi/MagicMirror
electron js/electron.js
/home/pi/MagicMirror/node_modules/electron/index.js:14
    throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
    at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
    at Module._compile (internal/modules/cjs/loader.js:654:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
    at Module.load (internal/modules/cjs/loader.js:566:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
    at Function.Module._load (internal/modules/cjs/loader.js:498:3)
    at Module.require (internal/modules/cjs/loader.js:598:17)
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15362/mm-not-displaying-after-update</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 17:48:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15362.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Aug 2021 03:03:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM Not Displaying after update on Wed, 11 Aug 2021 02:53:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you so very much!  It looks like that was the last piece of the puzzle!  I think it is working totally now.  And, believe it or not, the thing that sent me down this entire path in the first place, the PushBulletNotifications module, is now working, too!</p>
<p dir="auto">I will see if anything strange happens over the next few hours, but I think we are good now!</p>
<p dir="auto">Thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/93554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93554</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Wed, 11 Aug 2021 02:53:08 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Tue, 10 Aug 2021 23:41:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> I have seen a few systems that have trouble w pm2.</p>
<p dir="auto">run the fixuppm2 script from my site (last in the list)<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/93549</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93549</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 10 Aug 2021 23:41:33 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Tue, 10 Aug 2021 23:23:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I went ahead and added all of my modules back one on one, and they are working.  Whew.  Now, when I go back out to the raspberrypi prompt in the terminal, and put in,</p>
<p dir="auto">pm2 start MagicMirror, it says it is online, but it does not start.  It says it is online, but it does not start.</p>
<p dir="auto">When I npm start from that folder, however, everything is working.</p>
]]></description><link>https://forum.magicmirror.builders/post/93547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93547</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Tue, 10 Aug 2021 23:23:05 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Tue, 10 Aug 2021 00:14:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Okay, I have cleaned up my config and I am now slowly adding back modules one by one and testing.  I might not finish this tonight, but I still appreciate your help on all of this.</p>
]]></description><link>https://forum.magicmirror.builders/post/93503</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93503</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Tue, 10 Aug 2021 00:14:07 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 23:55:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> no. helper is option, so that is ok</p>
]]></description><link>https://forum.magicmirror.builders/post/93502</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93502</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Aug 2021 23:55:25 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 23:30:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Okay, so when it says 'no helper found for the module, it is missing the node_helper,js, correct?</p>
]]></description><link>https://forum.magicmirror.builders/post/93501</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93501</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Mon, 09 Aug 2021 23:30:41 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 22:17:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> no. look at the messages</p>
]]></description><link>https://forum.magicmirror.builders/post/93497</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93497</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Aug 2021 22:17:25 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 21:58:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> When I run npm start, I just get a black screen.  Does this mean every one of my modules is wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/93496</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93496</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Mon, 09 Aug 2021 21:58:33 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 21:45:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> you can look in the modules without a package.json, to see if they have a node_helper.js, and  if they have one,  check for require(‘???’)</p>
<p dir="auto">where ??? is NOT node_helper</p>
<p dir="auto">if they have those types of require, then they are dependent on mm providing the library</p>
<p dir="auto">request and valid-url<br />
are two we know modules didn’t document.<br />
(because it just worked)</p>
]]></description><link>https://forum.magicmirror.builders/post/93495</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93495</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Aug 2021 21:45:34 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 21:32:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you…quick question, as I have followed your above steps…what if the module does not have the package.json file?  Should I continue with those that do and then to the pm2 to start, or do I need to go back and do something with those modules that do not have the package.json file before I npm start?</p>
]]></description><link>https://forum.magicmirror.builders/post/93493</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93493</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Mon, 09 Aug 2021 21:32:16 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 12:52:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> I would go thru each module folder and  check for package.json file</p>
<p dir="auto">if present do an npm install in each such module folder.</p>
<p dir="auto">I would use npm start in the MagicMirror folder (and ctrl-q on mm screen) til u get it all working, then use pm2 to start</p>
<p dir="auto">so pm2 stop all<br />
then do above, then pm2 start 0<br />
then reboot</p>
]]></description><link>https://forum.magicmirror.builders/post/93481</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93481</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Aug 2021 12:52:57 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 06:21:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you so much for your help on this.  I ran your script, and the MagicMirror was working minus my modules, of course.  I copied over my config file, and only three of my modules displayed.  I rebooted my raspberry pi, and then MagicMirror would not display at all.  Here are the logs:</p>
<pre><code>Use `pm2 show &lt;id|name&gt;` to get more details about an app
pi@raspberrypi:~ $ pm2 logs MagicMirror
[TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
/home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
0|MagicMir | [09.08.2021 01:34.41.419] [LOG]   Connecting socket for: currentweather
0|MagicMir | [09.08.2021 01:34.41.423] [LOG]   Connecting socket for: newsfeed
0|MagicMir | [09.08.2021 01:34.41.425] [LOG]   Starting node helper for: newsfeed
0|MagicMir | [09.08.2021 01:34.41.426] [LOG]   Sockets connected &amp; modules started ...
0|MagicMir | [09.08.2021 01:34.42.061] [LOG]   Launching application.
0|MagicMir | [09.08.2021 01:34.49.566] [LOG]   Shutting down server...
0|MagicMir | [09.08.2021 01:36.01.706] [LOG]   Starting MagicMirror: v2.16.0
0|MagicMir | [09.08.2021 01:37.27.498] [LOG]   [SIGINT] Received. Shutting down server...
0|MagicMir | [09.08.2021 01:37.29.125] [LOG]   Starting MagicMirror: v2.16.0
0|MagicMir | [09.08.2021 02:01.15] [LOG]   [SIGINT] Received. Shutting down server...
0|MagicMir | [09.08.2021 02:01.17.151] [LOG]   Starting MagicMirror: v2.16.0
0|MagicMir | [09.08.2021 02:06.47.453] [LOG]   [SIGINT] Received. Shutting down server...
0|MagicMir | [09.08.2021 02:06.49.001] [LOG]   Starting MagicMirror: v2.16.0
0|MagicMir | [09.08.2021 02:07.10.237] [LOG]   [SIGINT] Received. Shutting down server...
0|MagicMir | [09.08.2021 02:07.11.810] [LOG]   Starting MagicMirror: v2.16.0
/home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:778:12)
0|MagicMir | [09.08.2021 02:07.11.831] [ERROR] Whoops! There was an uncaught exception...
0|MagicMir | [09.08.2021 02:07.11.835] [ERROR] TypeError: Cannot read property 'on' of undefined
0|MagicMir |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/js/electron.js:98:5)
0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:1072:14)
0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1101:10)
0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:937:32)
0|MagicMir |     at Object.&lt;anonymous&gt; (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:75:21)
0|MagicMir | [09.08.2021 02:07.11.837] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMir | [09.08.2021 02:07.11.839] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
<p dir="auto">I do have an internet connection working, so that is not the issue…you see anything?</p>
<p dir="auto">Thanks again.</p>
]]></description><link>https://forum.magicmirror.builders/post/93476</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93476</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Mon, 09 Aug 2021 06:21:19 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 04:27:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks, I am doing this now.  Will respond back when I finish…</p>
]]></description><link>https://forum.magicmirror.builders/post/93473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93473</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Mon, 09 Aug 2021 04:27:03 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 04:22:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a>  (a lot or lines ) aka 100</p>
<p dir="auto">So, this is another case where to update didn’t work well… as electron didn’t get upgraded, but messed up …</p>
<p dir="auto">SO…</p>
<p dir="auto">ugly recovery</p>
<p dir="auto">rename the MagiMirror/modules/default folder to default2<br />
rename the MM folder to something else</p>
<p dir="auto">install MM again<br />
(Use my script) see <a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a><br />
verify it works</p>
<p dir="auto">then copy the savedMagicMirror/modules folder over the MagicMirror folder</p>
<p dir="auto">cp -r -p ~/oldMMname/modules ~/Magicmirror/modules</p>
<p dir="auto">and then copy your old config,js to the new MM/config folder</p>
<p dir="auto">test it out</p>
<p dir="auto">Now, its still possible to have the module not found problem.</p>
<p dir="auto">I am going to bed now, but in case</p>
<p dir="auto">if u find module not found, take the name (valid-url, request) and do npm install ??? while in the MM folder</p>
<p dir="auto">my upgrade script MIGHT have helped avoid all this… (I say might, cause I haven’t seen it myself, but I never upgrade  manually)</p>
]]></description><link>https://forum.magicmirror.builders/post/93472</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93472</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Aug 2021 04:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 04:15:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I executed that command, and it returned a LOT of results.</p>
<pre><code>pi@raspberrypi:~ $ pm2 logs --lines=100
[TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
/home/pi/.pm2/pm2.log last 100 lines:
PM2        | [2021-08-08T22:29:56.400Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:29:56.447Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:29:59.262Z] PM2 log: App [mm] with id [0] and pid [855], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:29:59.268Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:29:59.281Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:01.122Z] PM2 log: App [mm] with id [0] and pid [932], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:01.127Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:01.138Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:02.980Z] PM2 log: App [mm] with id [0] and pid [962], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:02.984Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:02.995Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:04.800Z] PM2 log: App [mm] with id [0] and pid [992], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:04.805Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:04.816Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:06.749Z] PM2 log: App [mm] with id [0] and pid [1010], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:06.753Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:06.764Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:08.579Z] PM2 log: App [mm] with id [0] and pid [1040], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:08.586Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:08.598Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:10.468Z] PM2 log: App [mm] with id [0] and pid [1070], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:10.473Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:10.484Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:12.511Z] PM2 log: App [mm] with id [0] and pid [1088], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:12.514Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:12.525Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:14.368Z] PM2 log: App [mm] with id [0] and pid [1128], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:14.371Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:14.381Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:16.296Z] PM2 log: App [mm] with id [0] and pid [1158], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:16.300Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:16.311Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:39.892Z] PM2 log: App [mm] with id [0] and pid [1188], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:39.895Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:39.906Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:41.774Z] PM2 log: App [mm] with id [0] and pid [1208], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:41.779Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:41.789Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:43.634Z] PM2 log: App [mm] with id [0] and pid [1226], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:43.637Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:43.648Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:45.549Z] PM2 log: App [mm] with id [0] and pid [1259], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:45.553Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:45.563Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:47.471Z] PM2 log: App [mm] with id [0] and pid [1289], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:47.476Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:47.487Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:47.852Z] PM2 log: Stopping app:mm id:0
PM2        | [2021-08-08T22:30:47.936Z] PM2 log: App [mm] with id [0] and pid [1313], exited with code [0] via signal [SIGINT]
PM2        | [2021-08-08T22:30:48.032Z] PM2 log: pid=1313 msg=process killed
PM2        | [2021-08-08T22:30:48.037Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:48.048Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:49.923Z] PM2 log: App [mm] with id [0] and pid [1334], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:49.928Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:49.938Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:51.823Z] PM2 log: App [mm] with id [0] and pid [1352], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:51.826Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:51.839Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:53.696Z] PM2 log: App [mm] with id [0] and pid [1382], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:53.701Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:53.711Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:55.542Z] PM2 log: App [mm] with id [0] and pid [1400], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:55.546Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:55.562Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:57.487Z] PM2 log: App [mm] with id [0] and pid [1430], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:57.492Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:57.502Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:30:59.380Z] PM2 log: App [mm] with id [0] and pid [1460], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:30:59.384Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:30:59.394Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:01.224Z] PM2 log: App [mm] with id [0] and pid [1478], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:01.227Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:01.238Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:03.115Z] PM2 log: App [mm] with id [0] and pid [1508], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:03.118Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:03.128Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:04.939Z] PM2 log: App [mm] with id [0] and pid [1538], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:04.943Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:04.952Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:06.819Z] PM2 log: App [mm] with id [0] and pid [1556], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:06.822Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:06.832Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:08.698Z] PM2 log: App [mm] with id [0] and pid [1586], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:08.701Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:08.712Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:10.517Z] PM2 log: App [mm] with id [0] and pid [1604], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:10.520Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:10.530Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:12.460Z] PM2 log: App [mm] with id [0] and pid [1634], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:12.464Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:12.474Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:14.300Z] PM2 log: App [mm] with id [0] and pid [1664], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:14.304Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:14.318Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:16.267Z] PM2 log: App [mm] with id [0] and pid [1682], exited with code [1] via signal [SIGINT]
PM2        | [2021-08-08T22:31:16.274Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
PM2        | [2021-08-08T22:31:16.285Z] PM2 log: App name:mm id:0 online
PM2        | [2021-08-08T22:31:17.278Z] PM2 log: Stopping app:mm id:0
PM2        | [2021-08-08T22:31:17.350Z] PM2 log: App [mm] with id [0] and pid [1718], exited with code [0] via signal [SIGINT]
PM2        | [2021-08-08T22:31:17.443Z] PM2 log: pid=1718 msg=process killed
/home/pi/.pm2/logs/mm-out.log last 100 lines:
0|mm       |
0|mm       | &gt; magicmirror@2.16.0 start /home/pi/MagicMirror
0|mm       | &gt; electron js/electron.js
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
0|mm       |
/home/pi/.pm2/logs/mm-error.log last 100 lines:
0|mm       | /home/pi/MagicMirror/node_modules/electron/index.js:14
0|mm       |     throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
0|mm       |     ^
0|mm       |
0|mm       | Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
0|mm       |     at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
0|mm       |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
0|mm       |     at Module._compile (internal/modules/cjs/loader.js:654:30)
0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
0|mm       |     at Module.load (internal/modules/cjs/loader.js:566:32)
0|mm       |     at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:498:3)
0|mm       |     at Module.require (internal/modules/cjs/loader.js:598:17)
0|mm       |     at require (internal/modules/cjs/helpers.js:11:18)
0|mm       |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
0|mm       | npm ERR! code ELIFECYCLE
0|mm       | npm ERR! errno 1
0|mm       | npm ERR! magicmirror@2.16.0 start: `electron js/electron.js`
0|mm       | npm ERR! Exit status 1
0|mm       | npm ERR!
0|mm       | npm ERR! Failed at the magicmirror@2.16.0 start script.
0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
0|mm       |
0|mm       | npm ERR! A complete log of this run can be found in:
0|mm       | npm ERR!     /home/pi/.npm/_logs/2021-08-09T02_31_10_490Z-debug.log
0|mm       |     ^
0|mm       |
0|mm       | npm ERR!
0|mm       |
0|mm       | npm ERR!     /home/pi/.npm/_logs/2021-08-09T02_31_12_433Z-debug.log
0|mm       |     ^
0|mm       |
0|mm       | npm ERR!
0|mm       |
0|mm       | npm ERR!     /home/pi/.npm/_logs/2021-08-09T02_31_14_271Z-debug.log
0|mm       |     ^
0|mm       |
0|mm       | npm ERR!
0|mm       |
0|mm       | npm ERR!     /home/pi/.npm/_logs/2021-08-09T02_31_16_238Z-debug.log
<p dir="auto">Is this trying to find a needle in a haystack?</p>
]]></description><link>https://forum.magicmirror.builders/post/93471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93471</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Mon, 09 Aug 2021 04:15:34 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 04:02:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> sometimes the module need refresh too…</p>
<p dir="auto">AND</p>
<p dir="auto">we have been having a bunch of module failures because we removed a couple dead libraries that modules didn’t document they used</p>
<p dir="auto">So, where u start MM</p>
<p dir="auto">npm start<br />
or pm2 (if pm2 then use the command pm2 logs --lines=100)</p>
<p dir="auto">look at the startup messages and see if u see</p>
<p dir="auto">module not found</p>
]]></description><link>https://forum.magicmirror.builders/post/93470</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93470</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Aug 2021 04:02:49 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 04:00:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yes.  I read that a little bit after I did the pull, so, could the issue be that I didnt do it right after?  I did try to run MM again before I read that you needed to do the install…</p>
]]></description><link>https://forum.magicmirror.builders/post/93469</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93469</guid><dc:creator><![CDATA[Achilles]]></dc:creator><pubDate>Mon, 09 Aug 2021 04:00:52 GMT</pubDate></item><item><title><![CDATA[Reply to MM Not Displaying after update on Mon, 09 Aug 2021 03:56:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/achilles" aria-label="Profile: achilles">@<bdi>achilles</bdi></a> and u did npm install after the pull?</p>
]]></description><link>https://forum.magicmirror.builders/post/93468</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93468</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Aug 2021 03:56:09 GMT</pubDate></item></channel></rss>
