<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Go Big ! Samsung TV]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">So i finished my first project and want to go bigger. Let’s say BIG!.<br />
I have a spare Samsung 46" TV (UE46ES6340)</p>
<p dir="auto">With my first project i managed to get the screen to go into sleep mode and wake up with a PIR sensor.<br />
This big boy doesn’t want that.</p>
<p dir="auto">I know, ofcourse it’s a tv. So when there is no signal it just says “There is no signal”<br />
Is there, or does anyone know of a way, to put the TV into stand-by if the signal drops and turn it back on when there is signal on the HDMI port (it has CEC+ support)</p>
<p dir="auto">Cheerz :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/15379/go-big-samsung-tv</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 10:35:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15379.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Aug 2021 08:20:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Go Big ! Samsung TV on Mon, 16 Aug 2021 08:05:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/solelo" aria-label="Profile: solelo">@<bdi>solelo</bdi></a></p>
<p dir="auto">I will. But at the moment it’s turned sideways on a bed ;)<br />
The screen res. of this monitor is 1920x1080 which is the same as the monitor i have so there is no extra space. It’s just that my parents can read it :P</p>
<p dir="auto">When all is finished and i like it, it might swap it for a 4K monitor to add some more features into it.</p>
]]></description><link>https://forum.magicmirror.builders/post/93738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93738</guid><dc:creator><![CDATA[MDLefevere]]></dc:creator><pubDate>Mon, 16 Aug 2021 08:05:39 GMT</pubDate></item><item><title><![CDATA[Reply to Go Big ! Samsung TV on Mon, 16 Aug 2021 00:12:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdlefevere" aria-label="Profile: mdlefevere">@<bdi>mdlefevere</bdi></a> can you share some pics of your project? I’ve been using a 27 monitor and want to upgrade to a bigger tv since TVs are extra cheap right now. I could get a 50" for about $4-500.</p>
]]></description><link>https://forum.magicmirror.builders/post/93725</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93725</guid><dc:creator><![CDATA[SoleLo]]></dc:creator><pubDate>Mon, 16 Aug 2021 00:12:24 GMT</pubDate></item><item><title><![CDATA[Reply to Go Big ! Samsung TV on Fri, 13 Aug 2021 15:17:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I have to admit I don’t follow every post anymore. I’ve build my mirror like 3 years ago and it’s working the same way it was build ever since. The relay/scripts solution just works without any issues.<br />
So it seems the CEC solution is good for the Pi4 but on a Pi3 the relay solution is better.</p>
]]></description><link>https://forum.magicmirror.builders/post/93655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93655</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Fri, 13 Aug 2021 15:17:03 GMT</pubDate></item><item><title><![CDATA[Reply to Go Big ! Samsung TV on Fri, 13 Aug 2021 12:48:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: madscientist">@<bdi>madscientist</bdi></a> we talk about CEC all over this site. usually related to the PIR sensor modules, which use one of the 5 commands used to turn on/off the display.</p>
<p dir="auto">as I’ve said a few times (maybe 50), my CEC compliant tv will turn on  but not off. only on a pi 4.</p>
]]></description><link>https://forum.magicmirror.builders/post/93644</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93644</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 13 Aug 2021 12:48:46 GMT</pubDate></item><item><title><![CDATA[Reply to Go Big ! Samsung TV on Fri, 13 Aug 2021 11:37:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdlefevere" aria-label="Profile: mdlefevere">@<bdi>mdlefevere</bdi></a> Oh, very cool. I wasn’t aware that you could power on/off a TV using HDMI-CEC. I really should keep that in mind the next time this topic comes up. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/93642</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93642</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Fri, 13 Aug 2021 11:37:17 GMT</pubDate></item><item><title><![CDATA[Reply to Go Big ! Samsung TV on Fri, 13 Aug 2021 11:07:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: MadScientist">@<bdi>MadScientist</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/macg" aria-label="Profile: MacG">@<bdi>MacG</bdi></a></p>
<p dir="auto">Thanks for helping!. I like the ideas.<br />
After some searching i found something interesting!.</p>
<p dir="auto">At <a href="https://pimylifeup.com/raspberrypi-hdmi-cec/" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> page they have a tutorial for using HDMI-CEC.<br />
Following this tutorial it was exactly what i was looking for.</p>
<p dir="auto">Except the time the TV needs to start it works like a champ :)</p>
]]></description><link>https://forum.magicmirror.builders/post/93641</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93641</guid><dc:creator><![CDATA[MDLefevere]]></dc:creator><pubDate>Fri, 13 Aug 2021 11:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to Go Big ! Samsung TV on Fri, 13 Aug 2021 10:42:22 GMT]]></title><description><![CDATA[<p dir="auto">My first idea would be to use the Raspberry Pi as an infrared transmitter using <a href="https://www.lirc.org/html/index.html" target="_blank" rel="noopener noreferrer nofollow ugc">LIRC</a> and send the appropriate ON/OFF commands to the TV.</p>
<p dir="auto">The second is that there are remote apps for cell phones. So there is also a Samsung TV network remote control protocol. This could also be used to control the TV. On Github, you can find some information about TCP/IP connections with “samsung remote”.</p>
]]></description><link>https://forum.magicmirror.builders/post/93640</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93640</guid><dc:creator><![CDATA[MacG]]></dc:creator><pubDate>Fri, 13 Aug 2021 10:42:22 GMT</pubDate></item><item><title><![CDATA[Reply to Go Big ! Samsung TV on Fri, 13 Aug 2021 08:35:26 GMT]]></title><description><![CDATA[<p dir="auto">You could use a relay that triggers the power button of your TV. Or, if the TV turns on automatically once it gets power from the wall, you could use the relay to turn on/cut off electricity to the TV. I use the latter for my mirror.</p>
<p dir="auto">There is an excellent guide by <a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a>  <a href="https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app?_=1628843557059">here</a> including wiring and scripts. Have a look.</p>
]]></description><link>https://forum.magicmirror.builders/post/93638</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93638</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Fri, 13 Aug 2021 08:35:26 GMT</pubDate></item></channel></rss>
