<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I want to use api as a voice command using Google Assistant Module.]]></title><description><![CDATA[<p dir="auto">I want to use api to display information about Google Maps, bus information, and subways when I say certain words using recipe in Google Assistant module.<br />
Please help me.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15388/i-want-to-use-api-as-a-voice-command-using-google-assistant-module</link><generator>RSS for Node</generator><lastBuildDate>Fri, 14 Aug 2026 13:30:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15388.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Aug 2021 07:58:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I want to use api as a voice command using Google Assistant Module. on Mon, 16 Aug 2021 17:52:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/93747">I want to use api as a voice command using Google Assistant Module.</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikan" aria-label="Profile: rikan">@<bdi>rikan</bdi></a> correct. this is where mm is NOT a web browser.</p>
<p dir="auto">u need some module to display the web page content.  mmm-iframe maybe</p>
<p dir="auto">Use recipe for open GA browser ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/93748</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93748</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Mon, 16 Aug 2021 17:52:45 GMT</pubDate></item><item><title><![CDATA[Reply to I want to use api as a voice command using Google Assistant Module. on Mon, 16 Aug 2021 14:39:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rikan" aria-label="Profile: rikan">@<bdi>rikan</bdi></a> correct. this is where mm is NOT a web browser.</p>
]]></description><link>https://forum.magicmirror.builders/post/93747</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93747</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 16 Aug 2021 14:39:38 GMT</pubDate></item><item><title><![CDATA[Reply to I want to use api as a voice command using Google Assistant Module. on Mon, 16 Aug 2021 13:36:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djboob66" aria-label="Profile: djboob66">@<bdi>djboob66</bdi></a> If I use a link to a web page to give a voice command, the page will not appear on the screen.<br />
Do I need to use MMM-pages to bring up web pages on the screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/93745</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93745</guid><dc:creator><![CDATA[rikan]]></dc:creator><pubDate>Mon, 16 Aug 2021 13:36:47 GMT</pubDate></item><item><title><![CDATA[Reply to I want to use api as a voice command using Google Assistant Module. on Mon, 16 Aug 2021 10:05:02 GMT]]></title><description><![CDATA[<p dir="auto">I don,t think GAv3 has that capability? You could find the map as a web page have the map in MMM-Widget as fullscreen in MMM-pages and have GAv3 change to that page say with a command “maps train subway” I have my Cal as one page as well weather as other and so on. So when I wish to view weather I give the voice command “display weather” and it goes to that page. Do you have a link to what you wish to display?<br />
<img src="/assets/uploads/files/1629108116179-weather.png" alt="weather.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/93740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93740</guid><dc:creator><![CDATA[DJBOOB66]]></dc:creator><pubDate>Mon, 16 Aug 2021 10:05:02 GMT</pubDate></item></channel></rss>
