<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Anynet+ HDMI CEC]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’m running into an issue were i’m curious if others are experiencing this.<br />
I have a Samsung CEC+ compatible TV which in combination with MMM-NewPIR works.</p>
<p dir="auto">The strange thing i’m facing that it works most of the time.</p>
<ul>
<li>Countdown from 10 to 0 --&gt; TV goes into standby.</li>
<li>Motion detected after several minutes --&gt; TV turns on.</li>
</ul>
<p dir="auto">When there is like half an hour of <em><strong>no motion</strong></em> i can swing my head in front of the PIR sensor but nothing happens.<br />
The statuslight on the PI defenitly get’s some activity at the moment it gets motion detected.<br />
…</p>
<p dir="auto">I’ve checked al my TV settings and there is no other powersaving mode active… Like none!..</p>
<p dir="auto">Cheers :)<br />
Maurice</p>
]]></description><link>https://forum.magicmirror.builders/topic/15392/anynet-hdmi-cec</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 01:08:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15392.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Aug 2021 18:34:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Wed, 18 Aug 2021 07:14:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Weird. I switched back to a Pi3 and it’s working fine now.<br />
Connected it with a HDMI&lt;&gt;HDMI cable to the HDMI Arc port on the TV. The TV instantly popped up with a CEC connected Raspberry.</p>
<p dir="auto">Left it for over a night and just now it perfectly started.</p>
]]></description><link>https://forum.magicmirror.builders/post/93777</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93777</guid><dc:creator><![CDATA[MDLefevere]]></dc:creator><pubDate>Wed, 18 Aug 2021 07:14:36 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Tue, 17 Aug 2021 20:37:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdlefevere" aria-label="Profile: mdlefevere">@<bdi>mdlefevere</bdi></a></p>
<p dir="auto">Could this be a Pi4 related issue?, or just Samsung?.</p>
<p dir="auto">or HDMI cable?</p>
]]></description><link>https://forum.magicmirror.builders/post/93770</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93770</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Aug 2021 20:37:48 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Tue, 17 Aug 2021 17:12:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdlefevere" aria-label="Profile: mdlefevere">@<bdi>mdlefevere</bdi></a> no idea… CEC doesn’t work from pi3, but does partially from pi4…<br />
not from any other SBC</p>
]]></description><link>https://forum.magicmirror.builders/post/93766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93766</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Aug 2021 17:12:23 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Tue, 17 Aug 2021 16:32:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thanks for the info.</p>
<p dir="auto">I’ve setup a Pi3 with CEC and this seems to be working.<br />
Even after a long time the TV turns on. My Samsung also instantly recognized the Pi3 as a CEC device unlike the Pi4. It had some struggle with the new Pi.</p>
]]></description><link>https://forum.magicmirror.builders/post/93764</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93764</guid><dc:creator><![CDATA[MDLefevere]]></dc:creator><pubDate>Tue, 17 Aug 2021 16:32:09 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Tue, 17 Aug 2021 14:48:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdlefevere" aria-label="Profile: mdlefevere">@<bdi>mdlefevere</bdi></a> no. 0.5 (one half of one watt) is off/standby<br />
blanc screen is on, so 82 or 65 for me…</p>
<p dir="auto">I have not measured power consumption</p>
<p dir="auto">I have 5 SBCs plugged into the same circuit (w the 55in, 4 hdmi ports)<br />
pi0<br />
2 - pi3 (1 runs homeseer to control my lighting)<br />
pi 4<br />
odroid</p>
<p dir="auto">and another pi4 I just got with the 7in touch screen and case</p>
<p dir="auto">and then jetson nano in the hall (with the 43in)</p>
<p dir="auto">and a mac mini<br />
and my intel desktop (never off, but I power off the screens at night when i leave the office)</p>
]]></description><link>https://forum.magicmirror.builders/post/93763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93763</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Aug 2021 14:48:19 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Tue, 17 Aug 2021 14:28:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">You mean 5 in standy of with a blanc screen?.<br />
If that’s the case it’s not worth all the trouble of trying to get CEC to work ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/93762</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93762</guid><dc:creator><![CDATA[MDLefevere]]></dc:creator><pubDate>Tue, 17 Aug 2021 14:28:20 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Tue, 17 Aug 2021 11:42:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdlefevere" aria-label="Profile: mdlefevere">@<bdi>mdlefevere</bdi></a> blank screen when I’m not around.</p>
<p dir="auto">power draw.  the 55 is 82 watts/hour on, .5 off<br />
the 43 is 65w/h on, also .5 off</p>
]]></description><link>https://forum.magicmirror.builders/post/93759</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93759</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 17 Aug 2021 11:42:32 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Tue, 17 Aug 2021 09:51:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">So that will be my next option if i can’t get this to work.</p>
<p dir="auto">Do you switch it completely off at night or do you leave it with a blanc screen 24/7?<br />
You have an estimation of how much power i draws in a day?</p>
]]></description><link>https://forum.magicmirror.builders/post/93757</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93757</guid><dc:creator><![CDATA[MDLefevere]]></dc:creator><pubDate>Tue, 17 Aug 2021 09:51:59 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Mon, 16 Aug 2021 21:40:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdlefevere" aria-label="Profile: mdlefevere">@<bdi>mdlefevere</bdi></a> i don’t cause it doesn’t work…</p>
<p dir="auto">i have tried all the modules, and all the commands</p>
<p dir="auto">i blank the screen, and use my webcam for motion detection</p>
]]></description><link>https://forum.magicmirror.builders/post/93754</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93754</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 16 Aug 2021 21:40:00 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Mon, 16 Aug 2021 19:46:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">What module do you use?.</p>
]]></description><link>https://forum.magicmirror.builders/post/93753</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93753</guid><dc:creator><![CDATA[MDLefevere]]></dc:creator><pubDate>Mon, 16 Aug 2021 19:46:47 GMT</pubDate></item><item><title><![CDATA[Reply to Anynet+ HDMI CEC on Mon, 16 Aug 2021 19:19:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mdlefevere" aria-label="Profile: mdlefevere">@<bdi>mdlefevere</bdi></a> fun…  I have a CEC tv that I can turn on, but not off</p>
]]></description><link>https://forum.magicmirror.builders/post/93751</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93751</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 16 Aug 2021 19:19:54 GMT</pubDate></item></channel></rss>
