<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GoogleBirthdaysProvider giving Error]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/14320/mmm-googlebirthdaysprovider-no-red-birthday-cake">MMM-GoogleBirthdaysProvider No red birthday cake</a><img src="/assets/uploads/files/1629152599315-screen-shot-2021-08-16-at-3.22.36-pm.png" alt="Screen Shot 2021-08-16 at 3.22.36 PM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Hi! I am new here, building my first project and I am stuck. I cannot get the googlebirthdaysprovider to work. Here is the config:</p>
<pre><code class="language-{">			module: "calendar",
			header: "Upcoming Birthdays",
				displayRepeatingCountTitle: true,
							url: 'http://localhost:8080/mmm-googlebirthdaysprovider',
							symbol: "birthday-cake",
							repeatingCountTitle: "Birthday",
							color: '#f00',
							colored: true,
							coloredSymbolOnly: true,
		}, code_text
<p dir="auto">it’s gotta be user error – what am I doing wrong? Thank you so much!</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/topic/15394/mmm-googlebirthdaysprovider-giving-error</link><generator>RSS for Node</generator><lastBuildDate>Fri, 14 Aug 2026 19:14:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15394.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Aug 2021 22:28:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GoogleBirthdaysProvider giving Error on Tue, 17 Aug 2021 17:08:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lu-need" aria-label="Profile: lu-need">@<bdi>lu-need</bdi></a></p>
<p dir="auto">Just to make sure, do you have the opening curly bracket before your first line above?  Also, why do you have “code_text” after the comma at the end?</p>
<p dir="auto">I also notice that you use single quote marks instead of double-quotes in the config: block.  I am not sure that matters, but all of the examples use double-quotes.  (Single quotes <em>should</em> work, but there is always the chance that npm, MM, or some other component is expecting double-quotes.)</p>
<p dir="auto">When you say you cannot get it working, does having that block of code in your config.js cause MM not to launch correctly at all?  (Ie., do you get a black screen or the “create a config or check the existng one for errors” message?)  Or does MM launch correctly, and the module does not show up?  Or it shows up, but just has a “Loading” message instead of the expected calendar?</p>
]]></description><link>https://forum.magicmirror.builders/post/93765</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/93765</guid><dc:creator><![CDATA[joey]]></dc:creator><pubDate>Tue, 17 Aug 2021 17:08:22 GMT</pubDate></item></channel></rss>
