<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Home Assistant Toggle?]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I’m new to MagicMirror but can see me enjoying it a LOT , once I get my head around everything that is. Oh, and please accept my apologies if this post is in the wrong place :)</p>
<p dir="auto">What got me in to the idea of a MagicMirror is this video on YT - <a href="https://www.youtube.com/watch?v=QBJH3s0cIJE&amp;t=4s" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=QBJH3s0cIJE&amp;t=4s</a></p>
<p dir="auto">They use a ‘toggle’ in the bottom right corner to switch between MM and Home Assistant, but unfortunately he doesn’t explain how to do this. I’ve looked on this forum, and googled everything I can think of but no luck.</p>
<p dir="auto">Does anybody know? This would be great for me as I have a dashboard for HA and if I can switch between the two quickly like this it would be amazing!!</p>
<p dir="auto">Any help would be appreciated :)<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/15415/home-assistant-toggle</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 07:18:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15415.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Aug 2021 18:56:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Home Assistant Toggle? on Sun, 29 Aug 2021 08:16:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bendonahue" aria-label="Profile: bendonahue">@<bdi>bendonahue</bdi></a> I’ve set it up here with MQTT.<br />
I wrote a small guide on the HA forum:<br />
<a href="https://community.home-assistant.io/t/magicmirror-integration-into-home-assistant-with-mqtt/177246/15" target="_blank" rel="noopener noreferrer nofollow ugc">https://community.home-assistant.io/t/magicmirror-integration-into-home-assistant-with-mqtt/177246/15</a></p>
]]></description><link>https://forum.magicmirror.builders/post/94002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94002</guid><dc:creator><![CDATA[fribse]]></dc:creator><pubDate>Sun, 29 Aug 2021 08:16:04 GMT</pubDate></item><item><title><![CDATA[Reply to Home Assistant Toggle? on Sun, 29 Aug 2021 07:18:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bendonahue" aria-label="Profile: bendonahue">@<bdi>bendonahue</bdi></a> It looks like he’s using the <a href="https://github.com/shbatm/MMM-OnScreenMenu" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-OnScreenMenu</a> module. I don’t know how he’s using it, but he’s probably hiding/showing Home Assistant as some sort of embedded module or webpage.</p>
<p dir="auto">Possibly his Home Assistant page is inside an iFrame using the <a href="https://github.com/alberttwong/MMM-iFrame" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-iFrame</a> module and he’s using a toggle to show/hide the iFrame (as per the show/hide clock example in the <a href="https://github.com/shbatm/MMM-OnScreenMenu" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-OnScreenMenu</a> module). This might explain the white ‘border’ that appears on the right &amp; bottom of his HA controls page.</p>
<p dir="auto">There will be some HA dashboard cards don’t like being inside an iFrame so may not work correctly.</p>
]]></description><link>https://forum.magicmirror.builders/post/94000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94000</guid><dc:creator><![CDATA[smithbill17]]></dc:creator><pubDate>Sun, 29 Aug 2021 07:18:35 GMT</pubDate></item></channel></rss>
