<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NPM COMMAND NOT FOUND]]></title><description><![CDATA[<pre><code>0|MagicMir | /home/pi/MagicMirror/installers/mm.sh: satır 3: npm: komut yok
<p dir="auto">pm2 got errored and here its the logs</p>
]]></description><link>https://forum.magicmirror.builders/topic/15451/npm-command-not-found</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 08:07:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15451.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Sep 2021 17:26:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Sat, 25 Sep 2021 21:03:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> I don’t know either</p>
]]></description><link>https://forum.magicmirror.builders/post/94860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94860</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 25 Sep 2021 21:03:08 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Sat, 25 Sep 2021 20:00:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I can’t fix it :(</p>
]]></description><link>https://forum.magicmirror.builders/post/94858</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94858</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Sat, 25 Sep 2021 20:00:31 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Sat, 25 Sep 2021 17:39:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>pi@raspberrypi:~ $ sudo npm uninstall npm -g
sudo: npm: komut bulunamadı
pi@raspberrypi:~ $ npm
-bash: npm: komut yok
pi@raspberrypi:~ $ npm install
pi@raspberrypi:~ $ npm unstall
<p dir="auto">npm command not founded. thats strange right?</p>
]]></description><link>https://forum.magicmirror.builders/post/94850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94850</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Sat, 25 Sep 2021 17:39:09 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Sat, 25 Sep 2021 17:19:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> ok. I would use sudo to uninstall npm<br />
then install it again without.</p>
<p dir="auto">google search how to uninstall npm.</p>
]]></description><link>https://forum.magicmirror.builders/post/94849</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94849</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 25 Sep 2021 17:19:35 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Sat, 25 Sep 2021 17:18:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I didn’t install the MagicMirror with sudo. I accidently update the npm with sudo command and than this error shows up. Do I still need to reinstall?</p>
]]></description><link>https://forum.magicmirror.builders/post/94848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94848</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Sat, 25 Sep 2021 17:18:54 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Sat, 25 Sep 2021 17:15:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> rename the mm folder to something else.</p>
<p dir="auto">run my script</p>
<p dir="auto">see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/94847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94847</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 25 Sep 2021 17:15:08 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Sat, 25 Sep 2021 17:12:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Help me more please. How can i reinstall</p>
]]></description><link>https://forum.magicmirror.builders/post/94845</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94845</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Sat, 25 Sep 2021 17:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Thu, 02 Sep 2021 18:49:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uok825" aria-label="Profile: uok825">@<bdi>uok825</bdi></a> did u install with sudo?</p>
<p dir="auto">do not do that</p>
<p dir="auto">reinstall as normal user</p>
]]></description><link>https://forum.magicmirror.builders/post/94176</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94176</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 02 Sep 2021 18:49:48 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Thu, 02 Sep 2021 18:29:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/swvalenti" aria-label="Profile: swvalenti">@<bdi>swvalenti</bdi></a></p>
<pre><code>-bash: /usr/local/bin/npm: Böyle bir dosya ya da dizin yok
<p dir="auto">No such a file or folder</p>
]]></description><link>https://forum.magicmirror.builders/post/94175</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94175</guid><dc:creator><![CDATA[uok825]]></dc:creator><pubDate>Thu, 02 Sep 2021 18:29:54 GMT</pubDate></item><item><title><![CDATA[Reply to NPM COMMAND NOT FOUND on Thu, 02 Sep 2021 18:14:36 GMT]]></title><description><![CDATA[<p dir="auto">try</p>
<pre><code>npm link pm2
]]></description><link>https://forum.magicmirror.builders/post/94174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94174</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Thu, 02 Sep 2021 18:14:36 GMT</pubDate></item></channel></rss>
