<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[eaddress in use]]></title><description><![CDATA[<p dir="auto">Hey, do have a blank screen. and the logs show:</p>
<p dir="auto">/home/pi/.pm2/logs/mm-error.log last 15 lines:<br />
0|mm       | [01.09.2021 18:00.08.684] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a><br />
0|mm       | [01.09.2021 18:09.09.021] [ERROR] Whoops! There was an uncaught exception…<br />
0|mm       | [01.09.2021 18:09.09.036] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080<br />
0|mm       |     at Server.setupListenHandle [as _listen2] (net.js:1313:16)<br />
0|mm       |     at listenInCluster (net.js:1361:12)<br />
0|mm       |     at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7)<br />
0|mm       |     at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8) {<br />
0|mm       |   code: ‘EADDRINUSE’,<br />
0|mm       |   errno: ‘EADDRINUSE’,<br />
0|mm       |   syscall: ‘listen’,<br />
0|mm       |   address: ‘127.0.0.1’,<br />
0|mm       |   port: 8080<br />
0|mm       | }<br />
0|mm       | [01.09.2021 18:09.09.038] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
0|mm       | [01.09.2021 18:09.09.039] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a></p>
<p dir="auto">this is with a clean install of Magicmirror and the sample.config.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15456/eaddress-in-use</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 14:12:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15456.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Sep 2021 17:37:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to eaddress in use on Tue, 07 Sep 2021 18:25:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: bkeyport">@<bdi>bkeyport</bdi></a></p>
<p dir="auto">As the new system is running, I did change the port !</p>
<p dir="auto">Thx !</p>
]]></description><link>https://forum.magicmirror.builders/post/94288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94288</guid><dc:creator><![CDATA[Binog]]></dc:creator><pubDate>Tue, 07 Sep 2021 18:25:40 GMT</pubDate></item><item><title><![CDATA[Reply to eaddress in use on Mon, 06 Sep 2021 20:14:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a></p>
<p dir="auto">As well as the sample config is documented, I’m shocked that the port line is blank.</p>
<p dir="auto">I’d totally have it:</p>
<pre><code>port: 8080 // Change this! Recommended over 60000 to avoid conflict
<p dir="auto">But, hey, I’m just a hack, ya know? 😉</p>
]]></description><link>https://forum.magicmirror.builders/post/94273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94273</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Mon, 06 Sep 2021 20:14:53 GMT</pubDate></item><item><title><![CDATA[Reply to eaddress in use on Mon, 06 Sep 2021 12:47:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: bkeyport">@<bdi>bkeyport</bdi></a> 1st thing I do is change the port always :)</p>
]]></description><link>https://forum.magicmirror.builders/post/94256</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94256</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 06 Sep 2021 12:47:38 GMT</pubDate></item><item><title><![CDATA[Reply to eaddress in use on Sun, 05 Sep 2021 08:28:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/binog" aria-label="Profile: binog">@<bdi>binog</bdi></a> That is a pity. We could probably have found the issue and save your current state prior to the issue. Hope it is running fine now though.</p>
]]></description><link>https://forum.magicmirror.builders/post/94228</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94228</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Sun, 05 Sep 2021 08:28:36 GMT</pubDate></item><item><title><![CDATA[Reply to eaddress in use on Sun, 05 Sep 2021 08:06:55 GMT]]></title><description><![CDATA[<p dir="auto">Thank You, Nickthebeer and BKeyport</p>
<p dir="auto">I’ll try in future, I finally decided to reinstall the whole system.</p>
]]></description><link>https://forum.magicmirror.builders/post/94226</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94226</guid><dc:creator><![CDATA[Binog]]></dc:creator><pubDate>Sun, 05 Sep 2021 08:06:55 GMT</pubDate></item><item><title><![CDATA[Reply to eaddress in use on Sun, 05 Sep 2021 06:20:16 GMT]]></title><description><![CDATA[<p dir="auto">Can you run the following commands from the CLI to check if anything is using that port</p>
<pre><code>sudo netstat -punta | grep LIST
sudo netstat -punta | grep 8080
]]></description><link>https://forum.magicmirror.builders/post/94224</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94224</guid><dc:creator><![CDATA[nickthebeer]]></dc:creator><pubDate>Sun, 05 Sep 2021 06:20:16 GMT</pubDate></item><item><title><![CDATA[Reply to eaddress in use on Sat, 04 Sep 2021 10:24:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/binog" aria-label="Profile: binog">@<bdi>binog</bdi></a> Even though it’s fixed, there could be another issue - something else running on port 8080. I always change the default ports… 60001, 60002, etc. Less mess.</p>
]]></description><link>https://forum.magicmirror.builders/post/94210</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94210</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 04 Sep 2021 10:24:29 GMT</pubDate></item><item><title><![CDATA[Reply to eaddress in use on Sat, 04 Sep 2021 06:29:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a><br />
Thank You for reply ! None the less, there was no other instance running, I double checked it, nore was an instance under npm running. I finally decided to format the card and start over,… thx</p>
]]></description><link>https://forum.magicmirror.builders/post/94209</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94209</guid><dc:creator><![CDATA[Binog]]></dc:creator><pubDate>Sat, 04 Sep 2021 06:29:01 GMT</pubDate></item><item><title><![CDATA[Reply to eaddress in use on Fri, 03 Sep 2021 17:58:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/binog" aria-label="Profile: binog">@<bdi>binog</bdi></a> said in <a href="/post/94199">eaddress in use</a>:</p>
<p dir="auto">EADDRINUSE</p>
<p dir="auto">The <code>EADDRINUSE</code> error usually means that another instance of the mirror is running. If you start the mirror with pm2, you can do a pm2 list to show the current processes that are running under pm2. You can then stop that process with <code> pm2 stop #id</code> or <code>process stop all</code>.  Then you should be able to start the mirror again.</p>
]]></description><link>https://forum.magicmirror.builders/post/94200</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94200</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Fri, 03 Sep 2021 17:58:59 GMT</pubDate></item></channel></rss>
