<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-AlexaControl Configuration Issue]]></title><description><![CDATA[<p dir="auto">Hi Everyone.</p>
<p dir="auto">I’m trying to setup the MMM-AlexaControl module and I keep getting an config syntax error when I save my Magic Mirror config.js after adding the Notifications.</p>
<p dir="auto">When I run ‘npm run config:check’, it shows a syntax error, stating “Line 101 column 4: Parsing error: Unexpected token notifications”.  I’ve attempted to place the notifications section for the MMM-AlexaControl module in different locations within my MM config.js file, but nothing seems to work.  The MMM-AlexaControl module worked before adding the notification sections.  The module’s Wiki does not state where to add the notifications within the config file.</p>
<p dir="auto">The notifications that I am trying to setup are for the MMM-Pages module.  Below is my config.  Any assistance is greatly appreciated.  Thanks!</p>
<pre><code>
/* Magic Mirror Config
 * By Michael Teeuw https://michaelteeuw.nl
 * MIT Licensed.
 * see https://docs.magicmirror.builders/getting-started/configuration.html#general
 * and https://docs.magicmirror.builders/modules/configuration.html
let config = {
	address: "0.0.0.0", 	// Address to listen on, can be:
	port: 8080,
	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","0.0.0.0"],
	language: "en",
	locale: "en-US",
	timeFormat: 12,
	units: "imperial",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "US Holidays",
						symbol: "calendar-check",
						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
//			module: "compliments",
//			position: "lower_third"
			module: "weather",
				type: "current",
				locationID: "4165637",
				apiKey: "Key Removed from this post"
			module: "weather",
			header: "Weather Forecast",
				type: "forecast",
                        module: 'MMM-AlexaControl',
                        position: 'bottom_right',
                        config:{
                                image: true,
                                height: 75,
                                width: 75,
                                pages: 25,
                                pm2ProcessName: "MagicMirror",
                                vcgencmd: "vcgencmd"
                        notifications: [
                        port: 11100,
                        OnOff: false,
                        notification: ["PAGE_INCREMENT", "payload"]
                        port: 11101,
                        OnOff: false,
                        notification: ["PAGE_DECREMENT", "payload"]
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "New York Times",
						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
            module: 'MMM-page-indicator',
            position: 'bottom_bar',
            pages: 3,
]]></description><link>https://forum.magicmirror.builders/topic/15510/mmm-alexacontrol-configuration-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 02:33:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15510.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Sep 2021 21:34:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-AlexaControl Configuration Issue on Sun, 12 Sep 2021 00:15:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsn0327" aria-label="Profile: jsn0327">@<bdi>jsn0327</bdi></a> the rules</p>
<p dir="auto">things to the left of : do not need quotes<br />
things to the right of : do not need quotes if they are numbers or true/false, otherwise they need quotes</p>
<p dir="auto">if the thing on a line is NOT } or ]<br />
then the line above it must have a trailing comma, aka, more to follow.</p>
<p dir="auto">if u get an unexpected token error, look to the line before, and check for the trailing comma</p>
<p dir="auto">in this case</p>
<pre><code>  vcgencmd: "vcgencmd"
                    notifications: [
]]></description><link>https://forum.magicmirror.builders/post/94417</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94417</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Sep 2021 00:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaControl Configuration Issue on Tue, 14 Sep 2021 02:38:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> The comma fixed it! Thanks! I figured that it had to be something simple that I was overlooking.</p>
]]></description><link>https://forum.magicmirror.builders/post/94487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94487</guid><dc:creator><![CDATA[jsn0327]]></dc:creator><pubDate>Tue, 14 Sep 2021 02:38:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaControl Configuration Issue on Sun, 12 Sep 2021 00:15:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsn0327" aria-label="Profile: jsn0327">@<bdi>jsn0327</bdi></a> the rules</p>
                    notifications: [
]]></description><link>https://forum.magicmirror.builders/post/94417</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94417</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Sep 2021 00:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaControl Configuration Issue on Sat, 11 Sep 2021 23:51:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank for the reply.  I tried it the other way and received the same syntax error when running the config check.  This is how I have it now, and am receiving the following error: <strong>[ERROR] Line 101 column 4: Parsing error: Unexpected token notifications</strong></p>
<p dir="auto">Before I added the notification section, I was able to discover devices with my Echo Spot and control the Magic Mirror through Alexa by turning the virtual switches off and on.  I am now trying to expand the devices that I can control.  I’m sure that I’m missing something simple, but I’ve gone through the installation and configuration instructions on Github and while they are pretty detailed with the basic installation and configuration of the built-in options, they aren’t as detailed when it comes to integrating other modules.</p>
<pre><code>                    module: 'MMM-AlexaControl',
                    config:{
                            image: true,
                            height: 75,
                            width: 75,
                            pages: 25,
                    notifications: [
                    port: 11100,
                    OnOff: false,
]]></description><link>https://forum.magicmirror.builders/post/94416</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94416</guid><dc:creator><![CDATA[jsn0327]]></dc:creator><pubDate>Sat, 11 Sep 2021 23:51:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaControl Configuration Issue on Sat, 11 Sep 2021 23:35:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsn0327" aria-label="Profile: jsn0327">@<bdi>jsn0327</bdi></a> all the module config stuff has to be inside the config:{}</p>
<pre><code> {
         module: 'name',
          config:{
<p dir="auto">u have notifications and other stuff outside the config section</p>
]]></description><link>https://forum.magicmirror.builders/post/94414</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94414</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Sep 2021 23:35:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AlexaControl Configuration Issue on Sat, 11 Sep 2021 23:32:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsn0327" aria-label="Profile: jsn0327">@<bdi>jsn0327</bdi></a> and then after starting mm  u do Alexa discover devices</p>
<p dir="auto">u need one of the older echo or dot.</p>
<p dir="auto">Amazon removed the built-in support for wemo devices in the show, and newer echo devices</p>
]]></description><link>https://forum.magicmirror.builders/post/94413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94413</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Sep 2021 23:32:51 GMT</pubDate></item></channel></rss>
