<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Desktop working gadgets]]></title><description><![CDATA[<p dir="auto">My desktop clock? calendar? whatever…<br />
<img src="/assets/uploads/files/1632230620946-img_0283.png" alt="IMG_0283.png" class=" img-fluid img-markdown" /></p>
<ul>
<li>RPI 4B</li>
<li>1920x480 Touch LCD /w case unit from AliExpress.</li>
</ul>
<p dir="auto"><img src="/assets/uploads/files/1632230626064-img_0286.png" alt="IMG_0286.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">with some modules modification and scripts, it could become a 9to5 office gadget.</p>
<p dir="auto">I need some more angled plugs for a better look, anyway 90% done.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15564/desktop-working-gadgets</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 04:17:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15564.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Sep 2021 13:28:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Desktop working gadgets on Wed, 13 Oct 2021 10:19:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marcelino" aria-label="Profile: marcelino">@<bdi>marcelino</bdi></a> The panel has a dedicated control board that has HDMI(for video and sound, yes, that cased-kit includes also stereo speaker set) and micro-USB(for power and touch input)</p>
]]></description><link>https://forum.magicmirror.builders/post/95500</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95500</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Wed, 13 Oct 2021 10:19:41 GMT</pubDate></item><item><title><![CDATA[Reply to Desktop working gadgets on Fri, 01 Oct 2021 07:50:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: mmrize">@<bdi>mmrize</bdi></a> Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/95027</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95027</guid><dc:creator><![CDATA[cyberdie]]></dc:creator><pubDate>Fri, 01 Oct 2021 07:50:25 GMT</pubDate></item><item><title><![CDATA[Reply to Desktop working gadgets on Thu, 30 Sep 2021 14:29:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyberdie" aria-label="Profile: cyberdie">@<bdi>cyberdie</bdi></a></p>
<p dir="auto"><a href="https://de.aliexpress.com/item/1005002732234671.html?spm=a2g0o.productlist.0.0.5a045ed9cvmuqn&amp;algo_pvid=dc097697-dee9-4607-80f2-02824dfbd531&amp;algo_exp_id=dc097697-dee9-4607-80f2-02824dfbd531-1&amp;pdp_ext_f=%7B%22sku_id%22%3A%2212000021901092684%22%7D" target="_blank" rel="noopener noreferrer nofollow ugc">https://de.aliexpress.com/item/1005002732234671.html?spm=a2g0o.productlist.0.0.5a045ed9cvmuqn&amp;algo_pvid=dc097697-dee9-4607-80f2-02824dfbd531&amp;algo_exp_id=dc097697-dee9-4607-80f2-02824dfbd531-1&amp;pdp_ext_f={"sku_id"%3A"12000021901092684"}</a></p>
<p dir="auto">This is the almost same product I purchased but from a different seller.  There could be a no-touch version or without a case or even without a controller.  (If you select touch-version, you have to check the compatible controller).  Anyway, hundreds of sellers are selling these items, so you need to invest time to find a best price.</p>
<p dir="auto">1920X480  HSD088IPW1 might be the only panel that has this size. Usually, it seems to be able to be <strong>powered from RPI4 USB3 directly without an external power source.</strong> A bigger panel wouldn’t. That’s why I chose this.</p>
<p dir="auto">Some LCD cased versions might have holes to fasten RPI on the backside.</p>
<p dir="auto">Additionally, you need some accessories;</p>
<ul>
<li><code>mini HDMI(Controller) - micro HDMI(RPI4) Cable</code>. (I recommend angled plug with ribbon cable)</li>
<li><code>USB 3(RPI4) - micro USB(Controller) Cable</code>. (angled plug too.)</li>
<li>Of course, an RPI4 power source be needed. (LCD will drain the power so I recommend the original RPI4 power adapter or equivalent.)</li>
</ul>
<p dir="auto">To use with RPI, you need some modification.</p>
<ul>
<li>You might need to set a screen resolution profile.  Default screen direction and resolution was 480x1920 vertical. So I need to find a way to rotate it.<br />
I cannot remember what I’ve tried at this moment. :) (many trials and fails ^^) Anyway you can google it, I believe. <a href="https://raspberrypi.stackexchange.com/questions/117084/how-to-configure-a-non-regular-display-1920x480-cet-for-pi3-and-pi4-running-ra" target="_blank" rel="noopener noreferrer nofollow ugc">link</a> might be the one of them. Or, in RPI4, Just screen setting menu would be enough. (I cannot remember what I’ve done.)</li>
<li>(on touch version) After the success of the screen rotation, I bumped to another issue, the touchscreen coordination is not rotated. But I cannot find a way, so…<br />
I just rotated my MM screen itself instead of above screen rotation &amp; touch-coord rotation.</li>
</ul>
<p dir="auto">That’s all.</p>
]]></description><link>https://forum.magicmirror.builders/post/95000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95000</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 30 Sep 2021 14:29:18 GMT</pubDate></item><item><title><![CDATA[Reply to Desktop working gadgets on Thu, 30 Sep 2021 13:48:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyberdie" aria-label="Profile: cyberdie">@<bdi>cyberdie</bdi></a> he will have to provide that. no idea.  but one could search Ali</p>
]]></description><link>https://forum.magicmirror.builders/post/94999</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94999</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 30 Sep 2021 13:48:11 GMT</pubDate></item><item><title><![CDATA[Reply to Desktop working gadgets on Thu, 30 Sep 2021 13:28:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> You are right :beaming_face_with_smiling_eyes:<br />
What about the link?</p>
]]></description><link>https://forum.magicmirror.builders/post/94998</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94998</guid><dc:creator><![CDATA[cyberdie]]></dc:creator><pubDate>Thu, 30 Sep 2021 13:28:17 GMT</pubDate></item><item><title><![CDATA[Reply to Desktop working gadgets on Thu, 30 Sep 2021 13:25:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyberdie" aria-label="Profile: cyberdie">@<bdi>cyberdie</bdi></a> u can see the black ribbon cable from the pi to the display in the photos above</p>
]]></description><link>https://forum.magicmirror.builders/post/94997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94997</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 30 Sep 2021 13:25:30 GMT</pubDate></item><item><title><![CDATA[Reply to Desktop working gadgets on Thu, 30 Sep 2021 13:19:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: mmrize">@<bdi>mmrize</bdi></a> It’s awesome!<br />
Is the display directly connected to the Pi or does it need some kind of controller?<br />
Could you share the link to aliexpress item?<br />
Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/post/94996</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94996</guid><dc:creator><![CDATA[cyberdie]]></dc:creator><pubDate>Thu, 30 Sep 2021 13:19:28 GMT</pubDate></item><item><title><![CDATA[Reply to Desktop working gadgets on Tue, 21 Sep 2021 14:46:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: mmrize">@<bdi>mmrize</bdi></a> Nice!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/94716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94716</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Tue, 21 Sep 2021 14:46:22 GMT</pubDate></item></channel></rss>
