<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Countdown module with Ical support]]></title><description><![CDATA[<p dir="auto">I’ll start by saying that I have zero coding knowledge. I’m searching for a module that will act as a countdown clock to the next event on a google calendar/Ical calendar.  After passing an event, the countdown should begin counting down to the next event on the calendar.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15601/countdown-module-with-ical-support</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 02:14:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15601.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Sep 2021 16:41:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Countdown module with Ical support on Fri, 24 Sep 2021 13:22:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> right… but as the calendar broadcasts its events, a minor addition to a countdown  module to use that info could be the ticket</p>
]]></description><link>https://forum.magicmirror.builders/post/94825</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94825</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Sep 2021 13:22:40 GMT</pubDate></item><item><title><![CDATA[Reply to Countdown module with Ical support on Fri, 24 Sep 2021 12:08:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickred896" aria-label="Profile: nickred896">@<bdi>nickred896</bdi></a> There are countdown modules…just use one of them.  I know you’ll have to enter the date yourself but as of yet I do not believe that anyone has created what you’re looking for.</p>
]]></description><link>https://forum.magicmirror.builders/post/94823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/94823</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 24 Sep 2021 12:08:37 GMT</pubDate></item></channel></rss>
