<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[add request to modules]]></title><description><![CDATA[<p dir="auto">Appears that two modules I’m using are dead because of “request”</p>
<p dir="auto">How do we add it back into the affected modules?</p>
<p dir="auto">(MMM-CalendarExt2 and MMM-SystemStats, FWIW)</p>
]]></description><link>https://forum.magicmirror.builders/topic/15666/add-request-to-modules</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 05:24:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15666.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Oct 2021 03:21:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to add request to modules on Sun, 03 Oct 2021 20:09:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bert269" aria-label="Profile: bert269">@<bdi>bert269</bdi></a> It’s likely a missing required piece, like it was for me.</p>
<p dir="auto">take a look at logs.</p>
<p dir="auto">if using PM2, I suggest multiple terminal windows to your system, then on one:<br />
<code>pm2 logs</code> and the other <code>pm2 restart MagicMirror</code> (or other name that you use for MagicMirror)</p>
]]></description><link>https://forum.magicmirror.builders/post/95163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95163</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 03 Oct 2021 20:09:51 GMT</pubDate></item><item><title><![CDATA[Reply to add request to modules on Sun, 03 Oct 2021 13:26:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bert269" aria-label="Profile: bert269">@<bdi>bert269</bdi></a> show the errors where you do npm start</p>
<p dir="auto">if you use pm2, then do</p>
<p dir="auto">pm2 logs --lines=100</p>
]]></description><link>https://forum.magicmirror.builders/post/95128</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95128</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 03 Oct 2021 13:26:02 GMT</pubDate></item><item><title><![CDATA[Reply to add request to modules on Sun, 03 Oct 2021 13:25:22 GMT]]></title><description><![CDATA[<p dir="auto">My  is totally messed up now too, after the upgrade from 2.16.<br />
Blank screen.<br />
I tried the upgrade script with “force” but it’s still the same.<br />
THANKS!</p>
]]></description><link>https://forum.magicmirror.builders/post/95127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95127</guid><dc:creator><![CDATA[bert269]]></dc:creator><pubDate>Sun, 03 Oct 2021 13:25:22 GMT</pubDate></item><item><title><![CDATA[Reply to add request to modules on Sat, 02 Oct 2021 22:48:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I have a feeling the update isn’t gonna happen in either of those modules… :)</p>
<p dir="auto">I’d love someone to come up with a better CX2, tho… 😉😉😉</p>
]]></description><link>https://forum.magicmirror.builders/post/95102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95102</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 02 Oct 2021 22:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to add request to modules on Sat, 02 Oct 2021 06:35:43 GMT]]></title><description><![CDATA[<p dir="auto">the module author should add an updated package.json to the module</p>
<p dir="auto">And migrate to something else</p>
<p dir="auto">also</p>
<p dir="auto">rrule-alt<br />
valid-url</p>
]]></description><link>https://forum.magicmirror.builders/post/95073</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95073</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Oct 2021 06:35:43 GMT</pubDate></item><item><title><![CDATA[Reply to add request to modules on Sat, 02 Oct 2021 06:34:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: bkeyport">@<bdi>bkeyport</bdi></a> said in <a href="/post/95069">add request to modules</a>:</p>
<p dir="auto">in the module folder</p>
<p dir="auto">if the module does NOT  have a package.json file do</p>
<pre><code>npm init -y
<p dir="auto">and then for all cases do</p>
<pre><code>npm install request -- save
]]></description><link>https://forum.magicmirror.builders/post/95072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95072</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Oct 2021 06:34:11 GMT</pubDate></item><item><title><![CDATA[Reply to add request to modules on Sat, 02 Oct 2021 03:35:56 GMT]]></title><description><![CDATA[<p dir="auto">Nevermind, I got it figured out.</p>
<p dir="auto"><code>npm install request</code> in the directory after the regular npm install.</p>
<p dir="auto">Likely gonna have to keep doing it, though. :|</p>
]]></description><link>https://forum.magicmirror.builders/post/95070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95070</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 02 Oct 2021 03:35:56 GMT</pubDate></item></channel></rss>
