<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[MMM-PushBulletNotifications] Push stream error: Error: certificate has expired]]></title><description><![CDATA[<p dir="auto">Since a couple of days the module wasn’t showing new notifications.</p>
<p dir="auto">Giving a look at the terminal it now displays</p>
<pre><code>[2021-10-02 15:43:21.294] [LOG] [MMM-PushBulletNotifications][Error] 15:43:21.294 - Push stream error: Error: certificate has expired
<p dir="auto">Does anybody know please how to sort it out?</p>
]]></description><link>https://forum.magicmirror.builders/topic/15667/mmm-pushbulletnotifications-push-stream-error-error-certificate-has-expired</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 03:08:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15667.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Oct 2021 13:54:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [MMM-PushBulletNotifications] Push stream error: Error: certificate has expired on Sat, 02 Oct 2021 18:34:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> my upgrade script is a two pass thing</p>
<ol>
<li>
<p dir="auto">test the upgrade, without making any changes. let u know if there are files that would block it. give u opportunity to resolve them</p>
</li>
<li>
<p dir="auto">actually DO the upgrade.   because electron and other things are changing, I also run thru all the modules with package.json files and redo the npm install there (or npm upgrade if they provide one)</p>
</li>
</ol>
<p dir="auto">I do NOT git pull for modules</p>
<p dir="auto">note that in 2.16 (last release) we removed some deprecated libraries.  many modules didn’t document that they were used  so we get black screen problems.</p>
<p dir="auto">my upgrade does not test for that.</p>
]]></description><link>https://forum.magicmirror.builders/post/95089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95089</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Oct 2021 18:34:21 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-PushBulletNotifications] Push stream error: Error: certificate has expired on Sat, 02 Oct 2021 18:24:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks it’s been a while since last time I made something to my MM, but I surely will do it tomorrow with your script!</p>
]]></description><link>https://forum.magicmirror.builders/post/95088</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95088</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Sat, 02 Oct 2021 18:24:51 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-PushBulletNotifications] Push stream error: Error: certificate has expired on Sat, 02 Oct 2021 18:22:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> fun times.  make a copy of the folder,   use my upgrade script.</p>
]]></description><link>https://forum.magicmirror.builders/post/95087</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95087</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Oct 2021 18:22:43 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-PushBulletNotifications] Push stream error: Error: certificate has expired on Sat, 02 Oct 2021 17:33:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank you, but I am worried it <em>might</em> screw up my modules.</p>
<p dir="auto">I haven’t updated since like 2 years or so. 😅</p>
]]></description><link>https://forum.magicmirror.builders/post/95085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95085</guid><dc:creator><![CDATA[Cr4z33]]></dc:creator><pubDate>Sat, 02 Oct 2021 17:33:36 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-PushBulletNotifications] Push stream error: Error: certificate has expired on Sat, 02 Oct 2021 14:00:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cr4z33" aria-label="Profile: cr4z33">@<bdi>cr4z33</bdi></a> install 2.17.1 which has a fix for this<br />
see last post in<br />
<a href="https://forum.magicmirror.builders/topic/15662/v2-17-0">https://forum.magicmirror.builders/topic/15662/v2-17-0</a></p>
]]></description><link>https://forum.magicmirror.builders/post/95082</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95082</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Oct 2021 14:00:50 GMT</pubDate></item></channel></rss>
