<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-AQI stopped working]]></title><description><![CDATA[<p dir="auto">In recent days, the MMM-AQI module on my MM2 has stopped working.  I’ve checked my token on the World AQI website and it delivers the correct data so that part’s OK.  Can anyone suggest other things to check?  The module depends on “request” that’s been deprecated.  Could that be an issue?  Thanks for any suggestions provided!</p>
]]></description><link>https://forum.magicmirror.builders/topic/15678/mmm-aqi-stopped-working</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 21:55:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15678.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 Oct 2021 17:04:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-AQI stopped working on Mon, 04 Oct 2021 05:38:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I must have made a mistake when using your script command to upgrade:</p>
<p dir="auto">bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh</a>)”</p>
<p dir="auto">After I backed-up altered files and modules, I used the command:</p>
<p dir="auto">git pull &amp;&amp; npm install</p>
<p dir="auto">and the MMM-AQI module works again.  Thanks for pointing me in the right direction!</p>
]]></description><link>https://forum.magicmirror.builders/post/95177</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95177</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Mon, 04 Oct 2021 05:38:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AQI stopped working on Sun, 03 Oct 2021 19:14:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> u can also view the files at</p>
<p dir="auto">~/.pm2/logs</p>
<p dir="auto">note the dot in front of pm2</p>
<p dir="auto">use a good editor, then u can search the files</p>
]]></description><link>https://forum.magicmirror.builders/post/95160</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95160</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 03 Oct 2021 19:14:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AQI stopped working on Sun, 03 Oct 2021 19:13:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/95154">MMM-AQI stopped working</a>:</p>
<p dir="auto">pm2 log --lines=100</p>
<p dir="auto">OK…now I get it.  I used:<br />
pm2 log --lines=100<br />
to view the log.  Lots of red text having to do with the RTSP MM module.  I’ll keep looking for errors having to do with expired certificates.</p>
]]></description><link>https://forum.magicmirror.builders/post/95159</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95159</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Sun, 03 Oct 2021 19:13:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AQI stopped working on Sun, 03 Oct 2021 19:02:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Yes…I use pm2 to start/stop MM2.</p>
]]></description><link>https://forum.magicmirror.builders/post/95155</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95155</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Sun, 03 Oct 2021 19:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AQI stopped working on Sun, 03 Oct 2021 19:01:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> did u say yes to PM2 when u installed MM?</p>
<p dir="auto">or</p>
<p dir="auto">grep version ~/MagicMirror/package.json</p>
<p dir="auto">or review the ~/MagicMirror/installers/upgrade.log</p>
]]></description><link>https://forum.magicmirror.builders/post/95154</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95154</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 03 Oct 2021 19:01:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AQI stopped working on Sun, 03 Oct 2021 19:00:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks so much for the reply!  Unfortunately, I only understood the first part.  OK…“request” still works.  How do I view mm messages?  I used your script to update to the latest version earlier.  How do I go about determining whether 2.17.1 was installed properly?</p>
]]></description><link>https://forum.magicmirror.builders/post/95153</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95153</guid><dc:creator><![CDATA[dwburger]]></dc:creator><pubDate>Sun, 03 Oct 2021 19:00:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AQI stopped working on Sun, 03 Oct 2021 17:16:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dwburger" aria-label="Profile: dwburger">@<bdi>dwburger</bdi></a> said in <a href="/post/95144">MMM-AQI stopped working</a>:</p>
<p dir="auto">In recent days, the MMM-AQI module on my MM2 has stopped working.</p>
<p dir="auto">request still works.</p>
<p dir="auto">there was a problem with a certificate authority expired cert starting on Friday.</p>
<p dir="auto">u should see that in your mm messages</p>
<p dir="auto">2.17.1 had a fix for that problem</p>
]]></description><link>https://forum.magicmirror.builders/post/95146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95146</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 03 Oct 2021 17:16:17 GMT</pubDate></item></channel></rss>
