<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Microphone problem]]></title><description><![CDATA[<p dir="auto">Google Assistant is fully installed, but when I run a magic mirror, the microphone is not recognized. Is it a problem with the config file?</p>
]]></description><link>https://forum.magicmirror.builders/topic/15716/microphone-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 20:58:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15716.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Oct 2021 15:15:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Microphone problem on Fri, 08 Oct 2021 16:12:24 GMT]]></title><description><![CDATA[<p dir="auto">Solved! I forget to install MMM-Detector 🤣<br />
I’ve tryed everything including arecord -l…!</p>
]]></description><link>https://forum.magicmirror.builders/post/95392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95392</guid><dc:creator><![CDATA[kkilook]]></dc:creator><pubDate>Fri, 08 Oct 2021 16:12:24 GMT</pubDate></item><item><title><![CDATA[Reply to Microphone problem on Fri, 08 Oct 2021 15:32:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kkilook" aria-label="Profile: kkilook">@<bdi>kkilook</bdi></a> no idea</p>
<p dir="auto">from a terminal window do</p>
<p dir="auto">arecord -l (L for list)</p>
<p dir="auto">to list the recording devices</p>
<p dir="auto">does that match the GA config?</p>
]]></description><link>https://forum.magicmirror.builders/post/95390</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95390</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 08 Oct 2021 15:32:27 GMT</pubDate></item></channel></rss>
