<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Could not load config file.]]></title><description><![CDATA[<p dir="auto">I hope someone can help with this error.<br />
This is a new installation on a Raspberry Pi 4 2GB<br />
Latest Buster OS and MagicMirror v2.17.1<br />
I am getting this and other similar errors with certain Third Party modules. I have tried the manual and script install of MagicMirror.<br />
Same errors.<br />
Any help would be greatly appreciated.<br />
This is the error using the MMM-MyScoreboard module.<br />
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘json-parse-async’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/MMM-MyScoreboard/providers/SNET.js</li>
<li>/home/pi/MagicMirror/modules/MMM-MyScoreboard/node_helper.js</li>
<li>/home/pi/MagicMirror/js/app.js</li>
<li>/home/pi/MagicMirror/js/electron.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/15768/could-not-load-config-file</link><generator>RSS for Node</generator><lastBuildDate>Sun, 06 Sep 2026 12:32:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15768.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Oct 2021 04:25:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Could not load config file. on Thu, 21 Oct 2021 10:38:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/01zerosones01" aria-label="Profile: 01zerosones01">@<bdi>01zerosones01</bdi></a> said in <a href="/post/95684">Could not load config file.</a>:</p>
<p dir="auto">Cannot find module ‘json-parse-async’</p>
<p dir="auto">looks like you didn’t do step 2 of the module install<br />
MMM-MyScoreboard/</p>
]]></description><link>https://forum.magicmirror.builders/post/95687</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95687</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 21 Oct 2021 10:38:38 GMT</pubDate></item><item><title><![CDATA[Reply to Could not load config file. on Thu, 21 Oct 2021 14:34:00 GMT]]></title><description><![CDATA[<p dir="auto">Thanks so much for your help. That was my mistake. I didn’t run the command (npm install) inside the MMM-MyScoreboard folder.<br />
Thank you. That did it.</p>
]]></description><link>https://forum.magicmirror.builders/post/95696</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95696</guid><dc:creator><![CDATA[01ZerosOnes01]]></dc:creator><pubDate>Thu, 21 Oct 2021 14:34:00 GMT</pubDate></item><item><title><![CDATA[Reply to Could not load config file. on Thu, 21 Oct 2021 10:38:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/01zerosones01" aria-label="Profile: 01zerosones01">@<bdi>01zerosones01</bdi></a> said in <a href="/post/95684">Could not load config file.</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/95687</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95687</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 21 Oct 2021 10:38:38 GMT</pubDate></item></channel></rss>
